Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Jan 17, 2022 at 2:34 PM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    Harbor Freight wheels for the save
  2. Jan 17, 2022 at 2:38 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Got they grey ones bc hardwood floors. Glad I swapped ‘em outside as all the graphite & bearing shrapnel fell out when I turned the chair upside down. Mrs. woulda been some sore staining the floor.
  3. Jan 17, 2022 at 2:42 PM
    FastEddy59
    Eddie
    Railway conductor “Wide Body” version.
  4. Jan 17, 2022 at 2:46 PM
    Kilo Charlie
    Iowa
    Picked this up at HF too.. craptastical picture tho.
    Only base I can find that's long enough for the drum sander. The weight rating is super close tho.. the machine weighs like 289 pounds.
    Also.. who the heck designs something that uses 1 1/4 inch wood? Stupidest dimension ever needed for a project.
  5. Jan 17, 2022 at 3:15 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    You know it’s deep when it’s up to the grader tires :rolleyes:
  6. Jan 17, 2022 at 3:27 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :rofl:
  7. Jan 17, 2022 at 3:36 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    My Amazon desk legs showed up, welding job doesn't look pretty, but they are stout. I climbed on top with all 210lbs of my weight on each leg and they didn't budge. They also sent like 4 sizes of screw with each, but I'll probably source my own. My set is bolted together, if I had a welder I'd weld it all solid.
    The way you mount them to the desktop though is running screws through the tube up into the desktop, so I may make a flange to seat it better if it doesn't seem like it'll hold.
  8. Jan 17, 2022 at 4:01 PM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Not bad. Lots of new stuff after the crew change. I’m on a 5 day quarantine after a close contact so I’m going to miss out on some interesting things this week, but those are the times we’re living in. Hope everything is well with you all.
  9. Jan 17, 2022 at 4:10 PM
    My Name is Rahl
    I've always wanted a heated SxS with a plow blade.
    :drool: I bet it's super comfortable!
  10. Jan 17, 2022 at 4:14 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    That could be a chassis for a heck of a custom "overlanding rig". :laugh:
  11. Jan 17, 2022 at 4:16 PM
    My Name is Rahl
    Ever watched this kind of competition?
    https://youtu.be/6wmSJwJ0BAo
  12. Jan 17, 2022 at 4:17 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Most be a North Carolina thing Up here it would be gone in someones shed in a few hours .
    A little Army Green Paint no questions asked
  13. Jan 17, 2022 at 4:17 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    You have cash flow -- it is just in a negative direction. :pout:
  14. Jan 17, 2022 at 4:18 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  15. Jan 17, 2022 at 4:25 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Classic.
    Mundane utility products, timelessly and elegantly styled, designed and built for 3 lifetimes of use. It is sad that never again will we see products built that way.
  16. Jan 17, 2022 at 4:28 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You sure do use your mouth pretty...
  17. Jan 17, 2022 at 4:29 PM
    koditten
    Kirk
    Central Michigan
  18. Jan 17, 2022 at 4:31 PM
    FastEddy59
    Eddie
    If I didn’t know any better I’d bet the guy had sandpaper coveralls. The ass part is definitely not machined butt rather massaged.
  19. Jan 17, 2022 at 4:35 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Well, sometimes a plan works out even if you don't remember it..
    Started to deal with the 12" of :censored: snow here on the hilltop and needed a shear bolt.
    Seems like I had some... Actually found them right where I thought they should be.:yes:
    3 hours later I was done -- up here. 6 hours later I was back home. :bananadead:
  20. Jan 17, 2022 at 4:36 PM
    Bivouac
    I don`t think I would have worded it quite like that!
