Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Feb 2, 2022 at 4:06 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I tend to be the same way then most times it is a Labor of Love.
    The free jobs over the years is how I give back the things i learned for free over the years
  2. Feb 2, 2022 at 4:10 PM
    Bivouac
    It never fails farm work out it gets messed up.
    The first Job does not bode well for the skilled trades!
    What ever happened to the stainless pieces that kept cracking?? Did I miss it?
  3. Feb 2, 2022 at 4:16 PM
    Bivouac
    Time to hire a Good Lathe person.
    Would your Boss hire a Qualified Woman?
    The last place I worked would only hire Women for office jobs even if they had excellent fabricating skills.
    One had grown up in the shop of her father No not qualified.
  4. Feb 2, 2022 at 4:21 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    This is part of that job, it’s 1045 hot rolled material :thumbsup:
    They are going to make some of them too :eek:
    RustyGreen likes this.
  5. Feb 2, 2022 at 4:24 PM
    Bivouac
    For the most!!!! the youngins have never learned to really think or trouble shoot not like in my misguided youth .
    I had to figure things out for myself No internet to ask your questions no digital photos No fancy videos showing you everything !
    I never looked I wonder is there a video for trouble shooting a John Deere Baler knoter?? Been to long I can`t remember the model #
  6. Feb 2, 2022 at 4:25 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    It snowed last night, only got a couple inches of accumulation. Roads were clear and I had to go to work. :pout:
  7. Feb 2, 2022 at 4:26 PM
    Bivouac
    That is most every place!
  8. Feb 2, 2022 at 4:30 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Friend of mine took some hoses off of some pumps recently and ask if I wanted them. Yes sir! We got checked by the state today for a pump inspection and to make sure they are all reading correctly. Thank goodness they all passed :bananadance:
    tirediron, Cwopinger, Vmax88 and 9 others like this.
  9. Feb 2, 2022 at 4:35 PM
    Slashaar
    Josh
    Kansas City, MO
    Nothing beats freebies!
  10. Feb 2, 2022 at 4:50 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Well, it was an uncomfortable afternoon with my not very agile self either stuffed under the kitchen sink or crawling in and out of the cabinet 67 times.
    The drain has been flunky for a little bit (no more than 5 years or so) flunky finally turned to stationary. Found a clog of stuff in a (relatively) convenient fitting and - no.
    Ran my 25 foot drum auger the full 25 feet, I actually have at least 2 of these as I can never find the damn things when I need them. After I bought the second one I found the missing one in the back of the daily van, probably put 5,000 miles on it. So ran the auger and -- no..
    The last trick in my magic bag is called a Drain King - a nifty widget that goes on the end of a garden hose. Water pressure expands the tool against the pipe and then full hose pressure is applied to the drain.
    With the greatest of trepidation I put the Drain King in the PVC pipe that is close to 40 years old, opened the hose valve and ---
  11. Feb 2, 2022 at 4:54 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
  12. Feb 2, 2022 at 4:57 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    My boss would hire anyone who could run a lathe I would say :thumbsup:
  13. Feb 2, 2022 at 4:57 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  14. Feb 2, 2022 at 4:57 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    --- it worked! :woot:
    And even better there isn't water dumping into the crawlspace under the kitchen! :woot::woot:
    Drain King, they come in different sizes. No handy guy should be without a few.
    tirediron, Cwopinger, Vmax88 and 7 others like this.
  15. Feb 2, 2022 at 4:59 PM
    Bivouac
    Don`t leave us Hanging!!! Just where did it fail? Never mind!!
    Have you ever used the really Good Acid you get at HVAC and Plumbing Vendors I have had good luck.
  16. Feb 2, 2022 at 5:01 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
  17. Feb 2, 2022 at 5:01 PM
    Bivouac
  18. Feb 2, 2022 at 5:04 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    I'm sure you could figure something out to have them both on at the same time.
    For absolutely no reason whatsoever...
  19. Feb 2, 2022 at 5:07 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    This is the only drain cleaner acid I ever used all the years in the factories, my favorite I guess.
    I avoid using these kind of products in a residential application if at all possible. Also I have a well and septic so I am beyond conservative about any chemical use.
    tirediron, Vmax88, Slashaar and 2 others like this.
  20. Feb 2, 2022 at 5:09 PM
    Bivouac
    Put one on the front everyone needs a Class III hitch up front
