Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Mar 13, 2022 at 8:13 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Yes, I did see a nice looking flare tool for a couple hundred dollars. I could see if that line didn't hold tight it wouldn't work good. Before ordering anything I sure need to investigate where the fluid is going. However that old of a truck they're probably toast.
    I've had some bending training and experience (limited) with SS tube and swagelock fittings so I don't think getting a line routed good enough will be an issue.
    Son sure seems to like the old K5 and they don't get much easier to work on than something like that.
    Maybe he can learn something. He seems to listen a little better lately.
  2. Mar 13, 2022 at 9:58 PM
    Vmax88
    Vmax88 Well-Known Member
    Clint
    Joshua, TX
    20 MGM DCSB TRD Off Road 4X4
    What is this? A rain gauge with a cover to keep the rain out?
  3. Mar 13, 2022 at 10:20 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Up here in the rust belt we replace a lot of brake lines. It is quite disheartening to make the perfect replacement piece and then discover that you neglected to put the fitting on before you made your double flare... :mad::rocket::rant:
    My method is to snip the line off with a small sharp chisel right at the fitting, then you can use a 6 point socket to remove the fitting.
    You also can form your new piece side by side to match the one you cut out. The tube is easy to form over whatever item will give you the profile you need, just take your time.
  4. Mar 14, 2022 at 2:36 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Outdoor cat food cover :thumbsup:
  5. Mar 14, 2022 at 2:36 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Good Monday morning friends, hope everyone had a great weekend :hattip:
    Rezkid, tacotoe, Cwopinger and 5 others like this.
  6. Mar 14, 2022 at 2:37 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That is beautiful :101010:
  7. Mar 14, 2022 at 2:46 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Happy Monday all. Get on up and give'r heck.
    tacotoe, Cwopinger, wilcam47 and 3 others like this.
  8. Mar 14, 2022 at 3:03 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I bought stainless pre bent ones from Summit for my Duramax, they weren’t as bad as I thought they would be.
  9. Mar 14, 2022 at 3:04 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  10. Mar 14, 2022 at 3:32 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  11. Mar 14, 2022 at 3:37 AM
    07RedTacoDawg
    07RedTacoDawg Well-Known Member
    Danny
    Jamestown , NC
    07 Red Tacoma
    2 inch lift , tires and wheels
    tacotoe, wilcam47, Cwopinger and 3 others like this.
  12. Mar 14, 2022 at 4:52 AM
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    Morning Shane and crew
  13. Mar 14, 2022 at 5:58 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    Goodmorning crew:pccoffee:
    I did see brake lines available pre-bent and also didn't think the price was horrible bad. They seem more readily available now than in the past. Couple decades ago the place I purchased from before was called Classic Tube iirc, and they were more expensive then. I really want to learn how to do it really, wife's friend n coworker has a bad brake line too, I could fix.
    @RustyGreen , those are good ideas for getting the old fitting off and using the old for a template. I've seen before enough times things like forgetting to put the fitting on first. I think I'd be good there, but never say never, just jinxed myself.
    A good one for out of order steps is shrink fit coupling that requires outer cover/driver put on first.
  14. Mar 14, 2022 at 6:21 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
  15. Mar 14, 2022 at 6:30 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :eek::eek::eek:
    Guess who came in to work this morning?
    Sorry about all that stuff I threw away off of your work bench :anonymous:
  16. Mar 14, 2022 at 6:31 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Id be like, i dunno what happened.....:notsure:
  17. Mar 14, 2022 at 6:34 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    It must have been the temp
  18. Mar 14, 2022 at 6:38 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    His self diagnosis is "covid toe". It's a real thing if you look it up, still hasn't been to the doctor.
  19. Mar 14, 2022 at 6:39 AM
    wilcam47
    Will
    Bourbon state
    Also known as sandy vagina...
  20. Mar 14, 2022 at 6:44 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Is that similar to Kneezles, Toelio and of course, Small cox
