Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. May 26, 2022 at 3:03 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Might been preggo...now deado
  2. May 26, 2022 at 3:17 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    There is no code required orientation for a receptacle.
    I have always installed ground up or ground left.
    This reduces the odds of an object, a coin for example, bridging the hot and neutral in the event it was to fall and contact the prongs of a slightly dislodged cord.
    The exception is a cord with an immediate turn (wall hugging) plug such as furnished on air conditioners or refrigerators. The receptacle should be installed so the cord hangs as intended.
  3. May 26, 2022 at 3:18 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :yes: Good to hear!
  4. May 26, 2022 at 3:19 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :censored:
  5. May 26, 2022 at 3:31 PM
    Tacoma Mike
    Southern Maine
    Mine is also in the bathroom for the water pic height. Couldn’t plug in the hair dryer also.
    She needs her hair dryer..
  6. May 26, 2022 at 3:39 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Cat sitting there staring at it....this doesn't look
    Thanks Rusty. This is pretty much the explanation I've gotten from a couple of different guys. They seem upside down to me as well and as I've changed several out, put them in right-side up:rofl:
    I've vacuum about 4' x 5' area several times with the carpet cleaning machine. Thing with that water...something about path of least resistance so once it starts leaking it's going to keep coming in until it's done. Starting to dry out now.
    I'll be sure and put those down spout back on from now on:anonymous:
  7. May 26, 2022 at 3:48 PM
    Tacoma Mike
    Southern Maine
    Getting dirty.
    Feels pretty good lol
    Delta09, 80yotaguy, Rezkid and 10 others like this.
  8. May 26, 2022 at 3:53 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    I've got two lower ball-joint to put on the old 4runner. The driver side is a little more sloppy than passenger but both need replaced. Looks like should be easy after removing cotter- keys been in there 32 years.
    They might need drilled out.
  9. May 26, 2022 at 3:56 PM
    Tacoma Mike
    Southern Maine
    I just cut them off flush with the nut and wind them out with the impact gun
  10. May 26, 2022 at 4:00 PM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    #peoplearedumb
    First sunshine late this afternoon since Sunday. Mowed the yard and tossed wings on the grill!
  11. May 26, 2022 at 4:45 PM
    My Name is Rahl
    That's still upside down...
    tirediron, Vmax88, Rezkid and 4 others like this.
  12. May 26, 2022 at 5:07 PM
    Kilo Charlie
    Iowa
    The finish on the Thai Chili Wings
    tirediron, Delta09, tacotoe and 13 others like this.
  13. May 26, 2022 at 5:55 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Mmmm looks good! :hungry:
  14. May 26, 2022 at 6:00 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    That’ll work for now.
    TomTwo, Bivouac, tirediron and 17 others like this.
  15. May 26, 2022 at 6:01 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Looks like it came that way!
    :101010::101010::101010:
    tirediron, Cwopinger, tacotoe and 3 others like this.
  16. May 26, 2022 at 6:09 PM
    Kilo Charlie
    Iowa
    Thank you!
    I told you so! Haha
  17. May 26, 2022 at 6:24 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I live by a philosophy of "If it's stupid and it works, it's not stupid."
  18. May 26, 2022 at 7:27 PM
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    400MPH duct tape as we call it around here.
  19. May 26, 2022 at 7:30 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Hit it with some white spray paint. It'll be fine.
    TomTwo, Cwopinger, tacotoe and 3 others like this.
  20. May 26, 2022 at 7:40 PM
    Rezkid
    TJ
    WTX
    '08 DCSB TRD RT
    Agreed, ground pin always goes on the bottom IMHO.
