Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Jun 3, 2022 at 7:31 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I spent lots of time up in that area in the early seventies.
    Memorial Day Skiing in Tuckermans Ravine
  2. Jun 3, 2022 at 7:32 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    He said with all the commercial buildings going up in the county they made a change to the size of the letters because people plant so much shrubbery around them they eventually can't see the smaller numbers. They consider our store commercial even though it's less than 1,000 sq. ft. and has zero shrubbery. It is what it is and we'll put some numbers on it although they won't be that large.
  3. Jun 3, 2022 at 7:32 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Sounds perfect, carry on and keep up the good work. :thumbsup::thumbsup::thumbsup:
  4. Jun 3, 2022 at 7:36 AM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    5.5 inches just to bite your thumb at them!
  5. Jun 3, 2022 at 7:40 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    It's still a ritual for the hardy..
    six5crèéd[OP] and RustyGreen like this.
  6. Jun 3, 2022 at 7:40 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Old iron economics... makes perfect sense until you try and have it blessed by SWMBO! :rofl::fistbump:
  7. Jun 3, 2022 at 8:00 AM
    Bivouac
    I wonder it has to be a local thing. Here many commercial buildings have no numbers.
    Unless it is one of those things never enforced
  8. Jun 3, 2022 at 8:04 AM
    Kilo Charlie
    Iowa
    Hard to find any building in an emergency without numbers on it.. unless it's obviously on fire of course LOL
  9. Jun 3, 2022 at 8:09 AM
    Bivouac
    I can understand the not wanting to sell it took me a few years to come to terms that the projects I have are never going to get finished.
    Now of course no one really has extra money . Then for what ever reason it seems no one is into the 4x4 pick ups is any place close to me.
    RustyGreen and six5crèéd[OP] like this.
  10. Jun 3, 2022 at 8:11 AM
    Kilo Charlie
    Iowa
  11. Jun 3, 2022 at 8:15 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  12. Jun 3, 2022 at 8:25 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    That reminded me of the sunrise on Mt. Haleakala, almost 17 years ago. Time flies when you get older!
  13. Jun 3, 2022 at 9:05 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Don't hate on me cause I weld on the clamp. I do a lot of welding on table legs that are painted and sometimes I don't get the paint ground off enough to get an arc so I touch it to the clamp. The contacts are burnt pretty bad anyway so it needed a replacement.
    Luckily there's magic.....
    And voilà....
  14. Jun 3, 2022 at 9:41 AM
    Bivouac
    You and very many others .
    Why not weld a tab to the clamp for your output and work connection test??
    I could send you a nice new clamp.
    I put a 500 amp clamp on the table with quick connects. If I need to move the work clamp I have a few different length extensions.
  15. Jun 3, 2022 at 9:42 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Me, me, me, and not tuning my voice to sing either
    :rofl:
  16. Jun 3, 2022 at 9:47 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    A customer brought this by to see if we could get the 3 broken bolts out.
    2 of them shouldn't be a problem, there is enough to put some vice grips on.
    Put a little hot wrench on them and turned them enough to grind the first bit off and took em back out the back.
    The last one didn't have enough to grab so I ground it flush and a little heat and what is left of a left handed center drill.
    A blind squirrel finds a nut every now and then :D
    The customer said "I started to try and get them out myself but figured I'd let yawl do it". I said thanks cause most people bring us stuff like this with a broken easy out in the bolt :rant:
  17. Jun 3, 2022 at 9:48 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Because by the time they get to this point the contacts are burnt pretty bad anyway so they need to be replaced anyhow. Boss mans brother in law owns the local hardware and he supports him with the purchase of a new one and gets a small tax write off :D
  18. Jun 3, 2022 at 9:49 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    This was actual idea that was floated whilst I was working that outage in Michigan earlier this year. Their thought was to run the cutoff wheel slow enough that it didn't make sparks:rofl:
    Whatever....I went and looked at the situation and think with a little luck that I may be able to just enlarge the bezels and make the unit fit. This work is right inside the control room. Work in there....so intense you can almost hear the pucker:burp:
  19. Jun 3, 2022 at 10:00 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Last time I replaced the ground clamp was March 2020. 2 years with a lot of welding and $11 for a replacement ain't too bad to me.
    cory02taco, PzTank, 80yotaguy and 6 others like this.
  20. Jun 3, 2022 at 10:01 AM
    DonNH
    DonNH Well-Known Member
    Don
    Southern NH
    90 xcab>01dcsb>14dclb sport
    Cool!
    I'm about 3 hours from there, and haven't been there for several years.
    I remember white knuckles on the steering wheel for some of the stretches of the road up there. Can't believe people actually race up that road.
