Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Jun 5, 2022 at 11:18 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Ugh.. projects....
    -Probably a dozen+ trees to drop, buck and clear up
    -Two retaining walls to replace
    -Replace master bedroom window
    -Finish current tractor ('53 Farmall Super A), and hopefully acquire others
  2. Jun 5, 2022 at 11:19 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Got the parts to wire the winch, only reason I didn’t go with wireless @koditten is I won’t use it much and the batteries in the remote would go bad before I did use it. I bought a water proof electrical box yesterday at lowes but it’s just a tad too small.
  3. Jun 5, 2022 at 11:27 AM
    07RedTacoDawg
    07RedTacoDawg Well-Known Member
    Danny
    Jamestown , NC
    07 Red Tacoma
    2 inch lift , tires and wheels
    Glad I don't work with y'all. I'm getting tired just reading all the stuff y'all do.o_O
  4. Jun 5, 2022 at 12:07 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    :101010:
  5. Jun 5, 2022 at 12:25 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I seen that :infantry:
  6. Jun 5, 2022 at 12:31 PM
    07RedTacoDawg
    Danny
    Jamestown , NC
    07 Red Tacoma
    We have a crab apple tree out back. Funny watching the deer trying get at them.
    I was banned from trimming that tree. My wife sits in the dining room and watches them all day.
    :anonymous:
  7. Jun 5, 2022 at 12:52 PM
    Tacoma Mike
    Southern Maine
    So much easier on the wiring though.
  8. Jun 5, 2022 at 1:07 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    My reference says this is a 14mm tapered seat extended tip .708 reach, 5/8 hex, hotter side of the heat range but not hottest.
    Looking at specs, I’d venture that threads were accurate (14MM), but taper seat likely isn’t correct as most small engines are flat/washer seat.
  9. Jun 5, 2022 at 1:16 PM
    tirediron
    Excellent - thanks! Taper seat is definitely NOT correct - any chance you could pull up a flat-seat equivalent?
  10. Jun 5, 2022 at 1:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I have the wireless system on my anchor winch on the fishing boat. It's been in service 5 years. There has been no sign of the remote batteries failing. In fact my buddy has the same system on his boat for about the same amount of time.
    I don't think remote batteries are an issue.
    Water intrusion into the relays or solinoid is are more the weak link in my opinion.
  11. Jun 5, 2022 at 3:25 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    That looks fantastic! Nicely done!!
  12. Jun 5, 2022 at 3:26 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    'My' project...
    My kid just bought his first house not long ago, he's been keeping the old man pretty busy so far.
    :duh:
  13. Jun 5, 2022 at 3:29 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Need to find this book...
  14. Jun 5, 2022 at 3:30 PM
    Tacoma Mike
    Southern Maine
    Or dads phone number
  15. Jun 5, 2022 at 4:17 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    He'd hand it to me and tell me to read it.
    Dad needs to change his phone number.
  16. Jun 5, 2022 at 5:20 PM
    wilcam47
    Will
    Bourbon state
    Block
  17. Jun 5, 2022 at 6:29 PM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    5ADBCA48-2DB5-45F2-BDB5-129A05266D15.jpg Caught a decent pickerel tonight. I dropped my needlenose in the stream while trying to get the hook out, that was a bummer. As for projects, yeah I got them. But fishing is my main concern for the summer!
    Vmax88, Delta09, tacotoe and 9 others like this.
  18. Jun 5, 2022 at 6:59 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Doing a Champion code construction
    RC prefix (14mm, .750 length, flat seat 5/8) (Resistor 3k ohm /10k ohm)
    8-12 heat range (8 is equivalent to original)
    H or Y tip projection (Y is a bit longer, check clearance (rotate piston cycle))
    a C (copper) designation is ok
    so RC8YC would be where I would start.
  19. Jun 5, 2022 at 7:15 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Seems somewhere along the way I have read that a resistor plug doesn't work well/shortens the life of a magneto on the older engines.
    Champion D plugs are no resistor. Maybe a D16 for a Wisconsin? :confused:
    My old forklift with a Continental calls for D21.
  20. Jun 5, 2022 at 7:18 PM
    tirediron
    :hattip: Thanky gents! Have to see what's in the spark plug bin...
