Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
Electrical outlet cover screws MUST be......
  1. Horizontal
    10.7%
  2. Vertical
    46.4%
  3. Not matching, ain't nobody got time for that
    17.9%
  4. Over torqued so the fake plastic cracks, then back off just a tad
    42.9%
Multiple votes are allowed.
  1. Aug 3, 2022 at 9:49 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I'll bring the 1100 to work next week and take it apart, probably needs a good cleaning anyway :thumbsup:
    https://youtu.be/YBOreNAvSwE
  2. Aug 3, 2022 at 9:50 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    They are nice shooters! I just miss out on the deals when i see one.
    StayinStock, RustyGreen, MarX and 2 others like this.
  3. Aug 3, 2022 at 9:51 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    The one I have was my great uncles, dad inherited it when he passed many years ago and I "borrowed" it for my wife to shoot 10 years ago and never returned it. He knows I still have it :rofl:
  4. Aug 3, 2022 at 9:53 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Sorry kids, use a flashlight :eek:
  5. Aug 3, 2022 at 9:57 AM
    07RedTacoDawg
    07RedTacoDawg Well-Known Member
    Danny
    Jamestown , NC
    07 Red Tacoma
    2 inch lift , tires and wheels
    Speaking of the USPS, they sent my blower parts on a tour of the USA recently. :annoyed:
    Bivouac, Delta09, StayinStock and 6 others like this.
  6. Aug 3, 2022 at 9:57 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That's more like it :goingcrazy:
  7. Aug 3, 2022 at 9:58 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeeeeeah I think I remember him swapping it out one time for my grandma.. and then it stayed like that.
    I think he's till got it. I'll grab some pics next time I'm up there.
  8. Aug 3, 2022 at 10:15 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    "My name is Fargo and I have a problem..."
  9. Aug 3, 2022 at 10:15 AM
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    Let me check some LE parts sites I know, think my login is still good.
  10. Aug 3, 2022 at 10:18 AM
    tirediron
    :rimshot:
  11. Aug 3, 2022 at 10:21 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Dropped off my current part in QC.. just a basic tight tolerance tooling plate from some 17-4.
    ..saw that some of my other parts were back from OSP.
    Then my part finished up checking flatness. Was told to leave extra on the Overall for Bossman to grind to hit the .001" flatness. I left it just over Nominal.. and tried my hand at hitting it or close to. (Since we're kinda slow, why not take some time)
    Showed him my report card.. lol. He said well.. you're definitely the flat guy. No grind needed.
    Delta09, Vmax88, StayinStock and 5 others like this.
  12. Aug 3, 2022 at 10:22 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Would love to know if you do have access.. if the old Sig 556 in any of the variants are available or parts for them.
  13. Aug 3, 2022 at 10:27 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :101010::101010::101010:
  14. Aug 3, 2022 at 10:28 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :popcorn:
  15. Aug 3, 2022 at 10:34 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Now onto the next part of this assembly. Just one of these from this round stock. Going to dovetail then grab it in the 5th Axis centering vise in the UMC (5th axis) for one dumb side hole. Lol.
    My coworker programmed some of the other components and passed them off to one of the guys here.
  16. Aug 3, 2022 at 10:45 AM
    Cwopinger
    Blevin
    Florida
    Remmy parts only, sorry.
    @wilcam47 No luck on the stud. Is the stud itself actually broken or is it just a loose fit with the interceptor latch?
    I was a Remington armorer for my agency so I have some inside info. They make thicker retainers to correct a loose fit from use. If it’s just wear causing problems the fix is to replace the interceptor retainer with a thicker retainers to snug it up. You want a slight amount of play when reassembled.
    Brownells has the retainers in stock. Last listing is a 3 pack with all sizes.
    https://www.brownells.com/shotgun-parts/receiver-action-parts/receiver-action-hardware/interceptor-latches/remington-1100-11-87-interceptor-latch-retainer-prod19499.aspx
  17. Aug 3, 2022 at 10:46 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Powder coater ask if I could tack one of these brackets on so they can be broken off after painting the other side. I said I’ll try, the only problem is burn through when you grind the welds off.
    They tried glue but it failed in the oven.
    Nasty spool gun tack.
    Burn through from small tack.
  18. Aug 3, 2022 at 11:12 AM
    My Name is Rahl
    Stainless or aluminum? They make weld cleaner machines that takes the carbon off the metal.
    RustyGreen, wilcam47, MarX and 2 others like this.
  19. Aug 3, 2022 at 11:15 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Aluminum. It's the burning of the paint on the opposite side when they grind the weld off to make it flat again is gonna be the problem. Get it too hot and it'll blister the finish.
  20. Aug 3, 2022 at 11:22 AM
    My Name is Rahl
    Ah. I misunderstood.
