Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Aug 9, 2022 at 10:07 AM
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    Easily it will be the nicest part of whatever it’s going on.
  2. Aug 9, 2022 at 10:08 AM
    MarX
    Mark
    NE Kansas
    From where? Can it be ordered?
  3. Aug 9, 2022 at 10:08 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I'm dreading taking my 2021 in. It is starting to feel like a pretty good misfire under light tip in throttle under a load. Which in turn makes the transmission act all goofy :annoyed:
  4. Aug 9, 2022 at 10:09 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol. definitely somewhat saddening knowing that most parts we make will never see light and appreciated, and or get coated or painted and covered up..
  5. Aug 9, 2022 at 10:09 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
  6. Aug 9, 2022 at 10:10 AM
    MarX
    Mark
    NE Kansas
    Re poll: Think I’ve been called once a long time ago but due to my military orders couldn’t do it and got out of it. Wouldn’t of had a problem doing it.
  7. Aug 9, 2022 at 10:10 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Big difference between Maple flavouring & the Real McCoy for those that have never tried it. :burp:
  8. Aug 9, 2022 at 10:11 AM
    MarX
    Mark
    NE Kansas
  9. Aug 9, 2022 at 10:13 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Yes sir it is, the syrup from there is good too. My wife found that company a while back somehow.
  10. Aug 9, 2022 at 10:15 AM
    FastEddy59
    Eddie
    :anonymous: Keep it right handy.
  11. Aug 9, 2022 at 10:18 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
  12. Aug 9, 2022 at 10:19 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Milling some hex, shop is warm. How is it on the west side?
    RustyGreen, MarX and Fargo Taco like this.
  13. Aug 9, 2022 at 10:20 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've been using the basic JB weld.
    I don't want the high temp version. I'm always worried that might screw up the orientation if the magnets.
    If I do have to remove a magnet, I know I can heat up the flywheel on my gas grill pan ring and get the mags off.
    Those mags are installed with double side tape when new, so the low temp epoxy is perfect for the job.
    My present tubes of JB weld is about gone.
    I picked up an epoxy that uses the double seringe style applicator. This should make the portions more uniform. this is the Gorilla Glue brand.
    RustyGreen, MarX, FastEddy59 and 3 others like this.
  14. Aug 9, 2022 at 10:20 AM
    SACTOWN
    Greg
    its actual pretty nice right now, in the 70's, BUT its supposed to get into the 90's later today.
  15. Aug 9, 2022 at 10:27 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  16. Aug 9, 2022 at 10:30 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    He's a character, that's for sure!
    That is always my primary concern with epoxies, accurate portions of each base and catalyst. Good idea on sticking with low temp stuff, I hadn't considered having to potentially remove it if I screw it up. My father does a lot of woodworking, he uses the Gorilla epoxy you mention with good success, though for completely different applications.
    RustyGreen, MarX, Fargo Taco and 3 others like this.
  17. Aug 9, 2022 at 10:38 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Green for life huh? :rasta::rasta::rasta:
  18. Aug 9, 2022 at 10:41 AM
    FastEddy59
    Eddie
    Just a Front name for sure.
    RustyGreen and six5crèéd[OP] like this.
  19. Aug 9, 2022 at 10:54 AM
    MarX
    Mark
    NE Kansas
    What do you use it on?
  20. Aug 9, 2022 at 10:55 AM
    FastEddy59
    Eddie
    Pretty much like everyone says. Put that shit on everything. :)
