Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
How do you rinse when brushing your teeth?
  1. Mouth under spigot
    28.6%
  2. Hand(s)
    38.1%
  3. Cup
    19.0%
  4. I don’t rinse
    14.3%
  1. Aug 9, 2022 at 2:08 PM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    Remember, the old Easy Bake oven just used a 100W light bulb to cook things!
    MarX, 80yotaguy, Fargo Taco and 4 others like this.
  2. Aug 9, 2022 at 2:08 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    That is the reason the double sided tape gives up. Usually the machines can't get enough air to cool them because the fan grill is covered in debris...or worse the front crank seal is leaking and the fan is pushing oil into the head/jug fins along with dust. Fins clog up, then head gaskets go.
    A clean fan grill will ensure the engine stays cool. The flywheel should never be heat soaked because it is always in the stream of the coolest air.
  3. Aug 9, 2022 at 2:11 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    This is easy. Anytime it moves take it back to Toyota & get ‘em to fill it. :tinfoilhat:
  4. Aug 9, 2022 at 2:16 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I forgot about the ole easy bake oven :D
  5. Aug 9, 2022 at 2:16 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I was wondering why they come off. Thanks for the explanation :hattip:
    MarX, Fargo Taco and RustyGreen like this.
  6. Aug 9, 2022 at 2:20 PM
    07RedTacoDawg
    07RedTacoDawg Well-Known Member
    Danny
    Jamestown , NC
    07 Red Tacoma
    2 inch lift , tires and wheels
    That's the guys that pick up my recycling :rofl:
    MarX, Fargo Taco, RustyGreen and 2 others like this.
  7. Aug 9, 2022 at 2:35 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Little fixture plate I made a while ago coming in clutch again for this quick 1 piece job. .078" thick 416 stainless. Rough cut on the waterjet and left .020" per side. So having to jump clamps and finish OD and ID features and multiple size chamfers along edges. Then flip, pick up, and finish some Cbores and chamfers on the other side.
    tirediron, MarX, 80yotaguy and 8 others like this.
  8. Aug 9, 2022 at 2:36 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Dealing with Engine Drive Welders is completely different then lawn machines .
    then some people mount them in the dumbest places .
  9. Aug 9, 2022 at 2:40 PM
    FastEddy59
    Eddie
    Reminds me of a Jag. Why the only one I ever saw in Winter was bein’ Towed.
    tirediron, MarX, Fargo Taco and 3 others like this.
  10. Aug 9, 2022 at 3:02 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    MarX, MQQSE, wilcam47 and 2 others like this.
  11. Aug 9, 2022 at 3:04 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Can't like that...
    MarX, wilcam47, FastEddy59 and 2 others like this.
  12. Aug 9, 2022 at 3:09 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Incandescent lamps are really good heaters that happen to give off some light with about 15% of the energy they consume. :laugh:
    shaeff, MarX, wilcam47 and 4 others like this.
  13. Aug 9, 2022 at 3:13 PM
    FastEddy59
    Eddie
    http://centennialbulb.org/
    Always got a kick outta this one.
  14. Aug 9, 2022 at 3:27 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Friend ask me to hot glue this back together, it’s already been hot glued once.
    shaeff, MarX, Kilo Charlie and 5 others like this.
  15. Aug 9, 2022 at 3:42 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Dealership said they couldn't undo what they did the first time so gauge still no worky.
  16. Aug 9, 2022 at 3:44 PM
    FastEddy59
    Eddie
    Koho Rocker hook. You’re still good just a red one below the H.
  17. Aug 9, 2022 at 3:49 PM
    Tacoma Mike
    Southern Maine
    Not in the same spot so GTG…
    MarX, 80yotaguy, RustyGreen and 4 others like this.
  18. Aug 9, 2022 at 3:50 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    It’s time for a new can!
  19. Aug 9, 2022 at 3:51 PM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Are brush truck f250 has had 4 wiring harness , says they are faulty
  20. Aug 9, 2022 at 3:54 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Looks like it gets a lot of heat, maybe add a support piece in there?
