Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
How do you rinse when brushing your teeth?
  1. Mouth under spigot
    28.6%
  2. Hand(s)
    38.1%
  3. Cup
    19.0%
  4. I don’t rinse
    14.3%
  1. Aug 12, 2022 at 11:28 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I made a box filled with just normal play sand works good for post weld heat control .
    When your a little person without a fancy computer controlled induction heater.
    It depends on temperature fiberglass might melt!
  2. Aug 12, 2022 at 11:30 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I’ve even heard of guys using salt.
  3. Aug 12, 2022 at 11:30 AM
    Bivouac
    A shop I worked at this was a everyday lunch time heating food with the oxy -fuel torch.
  4. Aug 12, 2022 at 11:32 AM
    FastEddy59
    Eddie
    :crapstorm:Nothin’ like Turbo baked beans. Just be sure to puncture the can.
  5. Aug 12, 2022 at 11:34 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Fiberglass insulation won't melt unless the temperature is over 1000 degrees.
    wilcam47 and six5crèéd[OP] like this.
  6. Aug 12, 2022 at 11:36 AM
    Bivouac
    Wow I had not thought of that for years.
    Turbo manifold cooking !
    Never fails someone always forgets and you have a mess all over the engine!
  7. Aug 12, 2022 at 11:38 AM
    FastEddy59
    Eddie
    Boss man could even tell the Brand. :smack:
  8. Aug 12, 2022 at 11:38 AM
    Bivouac
    Sometimes the temperatures could be !
    Off the top of my head I can not remember the real numbers .
  9. Aug 12, 2022 at 11:43 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Might try the heat gun next time, got a bit charred for my liking
  10. Aug 12, 2022 at 11:45 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Fun fact, if your welding helmet has a low battery light on, do not crank the 480v MIG welder to 11. I'm still seeing spots... o_O
  11. Aug 12, 2022 at 11:45 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    :angrygirl::angrygirl::eek::eek:
  12. Aug 12, 2022 at 11:48 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    When I worked at windixe I used a wrapping machine hot plate turned up all the way. We always had something wrapped up in foil cooking in there
  13. Aug 12, 2022 at 11:49 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    "..it seemed like a good idea at the time..." :facepalm:
  14. Aug 12, 2022 at 11:51 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I wanted to save the 5 minutes... welp that was a bad idea :laugh:
  15. Aug 12, 2022 at 11:56 AM
    Bivouac
    No worse then having that unexpected bright light turned on !
    Kinda like the flash on cameras in the good old days!
    unprotected eyes are different when your coworker gets you.
  16. Aug 12, 2022 at 12:00 PM
    FastEddy59
    Eddie
    Explains why the flashing lights behind me were Red & Blue. Opposite sides of the spectrum. Kinda butters up the eyes before the Big White light appears at the door.
  17. Aug 12, 2022 at 12:01 PM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Yeah man, I figured it would cost me $150-$200/day to rent one when I need it, why not just buy this for less than that cost. I haven't had much time to play with it but I did get a video of it working before I purchased it. Good to know, I have a PDF download but I'd pay $20 for a book in a heartbeat. I'll snag one.
    And yep, you're dead on 9hp and I'm fairly certin it's an AEN. Got a Fairbanks Morse magneto on it. No spark but shouldn't be too bad to get that figured out. The points are absolutely shot so that doesn't help.
  18. Aug 12, 2022 at 12:02 PM
    Bivouac
    Speaking from experience I see.
  19. Aug 12, 2022 at 12:04 PM
    FastEddy59
    Eddie
    :anonymous: Twice or three times a month. When you leave @ 3AM it’s prime time downtown.
  20. Aug 12, 2022 at 12:12 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
