Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Sep 7, 2022 at 8:37 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Here is the tool that I was suggesting. But I would get a drum brake kit. It includes other specific tools that make the job much easier.
    https://www.amazon.com/Performance-Tool-W175-Spring-Pliers/dp/B00BR1BV8Q?keywords=Drum+Brake+Tool&qid=1662564757&sr=8-3-spons&th=1
    Full kit:
    https://www.amazon.com/ABN-Universa...eywords=Drum+Brake+Tool&qid=1662564757&sr=8-7
    And a youtube video of how the tool works:
  2. Sep 7, 2022 at 8:39 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    If you are not doing so already my drum brake trick is to crank the adjuster almost completely closed .( Works great for removing the drums as well.)
    makes installing new springs much easier.
    Making sure shoes are seated correct install the drum adjust up as needed.
  3. Sep 7, 2022 at 8:45 AM
    Bivouac
    just somewhat jealous are you?
    Some of us just have better hand eye coordination.
  4. Sep 7, 2022 at 8:45 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    My dad had 1 of these as well for measuring the inside of the drum and the outside of the brakes before reassembly. I need to get one, to go with the other brake tools. I've always hated adjusting them through that small slot.
    RustyGreen, Taco critter and Slashaar like this.
  5. Sep 7, 2022 at 8:52 AM
    Bivouac
    That gauge tells you back in the old days to throw out the drums they are already to thin to cut again.
    I guess adjusting the drum brakes is just one of those things Backing them off is a habit to remove drums i never thought adjusting them up was difficult or a pain.
    Going back together it was always serviced adjusters or brandy new which makes it easier at least to me.
  6. Sep 7, 2022 at 8:54 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I tried that, got the spring on, then realized the adjuster had fallen out of the slot. :annoyed: I had to pull the dang spring back off and reset everything and pull like my life depended on it. My hands are bruised today... :bananadead:
    RustyGreen and six5crèéd[OP] like this.
  7. Sep 7, 2022 at 9:00 AM
    Bivouac
    It takes a little practice the adjusters slip out now and then it happens since everything is clean nothing wrong with a piece of tape holding things in place.
    till you get your technique figured out The downside is most people might do drum brakes every few years.
  8. Sep 7, 2022 at 9:03 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    What was your first clue? :rofl:
  9. Sep 7, 2022 at 9:04 AM
    tirediron
    That's exactly the unit I have - VERY handy for dialing in drum brakes.
  10. Sep 7, 2022 at 9:07 AM
    Slashaar
    Josh
    Kansas City, MO
    I'm pretty sure those drums were factory. I'm just shy of 150k. The front shoes on both sides were getting thin, but the rear shoes still had life, and I but I could've turned the drum, but it was crusty and rusty so in the bin it went. all the springs on the driver side looked alright, but the passenger side was on the verge of rusting, dark colored and little paint left. All the other parts shined up with some brake cleaner. Threw on all new springs anyway since I had em. New drums and shoes and I greased up all the spots that rub metal on metal per instructions and put never seized on the adjuster screw. I wanted to do the fronts too, but I planned to do the drums first because I knew they'd take longer than I thought. and they did. I was out there for like 8 hours. :censored:
    I had to make a drum puller out of a 2x4 and my gear puller kit. Didnt think it was gonna hold as my washer stack started to sink in, then, POW. The sucker came loose with some smoke. I got out my Ingersoll grinder and cleaned all the rust off the mating surfaces and threw on anti seize there too. Cleaned a ton of dust out of there too. Now that I think about it, I forgot to sweep out the garage... :facepalm:
    First time working on drums. I never replaced the ones on the Pontiac Grand Am I used to drive.
  11. Sep 7, 2022 at 9:21 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
  12. Sep 7, 2022 at 9:21 AM
    Bivouac
    First time then you did really good my first time was in 1972 !
  13. Sep 7, 2022 at 9:25 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Friend of mine ask me to make him a pin for this blade, have no idea what it’s supposed to look like and this is just a guess. If it don’t work we’ll punt.
    Cole ask what are you doing with that stick? I said I’m using it as a tape measure to set the depth, marked it with my pen :D
  14. Sep 7, 2022 at 9:28 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Huh. I was thinking the hook tool I use for snowmobile exhaust springs was good for these, I had no idea these pliers existed. These look like they’d work way better!
  15. Sep 7, 2022 at 10:27 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Good brake tools make drums easy.
  16. Sep 7, 2022 at 10:49 AM
    Hunterdc1
    Hunterdc1 Propane and Propane Accessories
    Brrrrother
    No I will not press 1 for English
    13 8 lug ltz gasser
    Wdr 9/17 Launch 9/21 tentative of LAS -recerted. Waiting on word of that, and of course thats a one way street conversation from Eastern Range.
    RustyGreen, 80yotaguy, PzTank and 3 others like this.
  17. Sep 7, 2022 at 10:58 AM
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    Afternoon Shane & Co. :hattip:
    Friendly PSA to check and double check.. and then triple check to make sure all wire harnesses and plugs are out of the way when reinstalling a transmission. I didn't and ended up smoking the passenger side O2 sensor plug yesterday. :anonymous::bananadead:
    Sometimes being in a rush bites you in the butt. :frusty:
  18. Sep 7, 2022 at 11:05 AM
    My Name is Rahl
    Good to know! @PzTank
  19. Sep 7, 2022 at 12:32 PM
    My Name is Rahl
    You got married on 09/10/11?
    Not gonna lie, that's pretty cool!
    23Skidoo, Slashaar, 80yotaguy and 4 others like this.
  20. Sep 7, 2022 at 1:25 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :101010:
    Nice job!
    Surprised it isn't lime green. :laugh:
    Slashaar, MQQSE, PzTank and 6 others like this.
