Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
How do you rinse when brushing your teeth?
  1. Mouth under spigot
    28.0%
  2. Hand(s)
    32.0%
  3. Cup
    16.0%
  4. I don’t rinse
    24.0%
  1. Sep 23, 2022 at 10:23 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    What?
    six5crèéd[OP] and RustyGreen like this.
  2. Sep 23, 2022 at 10:29 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    I love the push start
  3. Sep 23, 2022 at 10:32 AM
    Jtcmedic
    Jeff
    Florida
    2014 prerunner sr5
  4. Sep 23, 2022 at 10:52 AM
    Key-Rei
    Key
    Florida
    Spent 24hrs more or less straight on cleaning up, organizing, and improving in the shop, replaced my highest fluorescent lights with LED, the rest will come eventually though I did swap out some dead tubes in the other housings, and hung a ceiling fan that was bumped from the house for being too early early 90's. (Probably original to the house...)
    Ah the ceiling fan saga...
    So you can see here it has an aluminum angle brace...
    It has a brace because it clears the lift by only 4" and I didn't want any potential standing oscillations to allow it into a collision pattern with the lift especially potentially generated by either blade droop from humidity, extra lift on the one side from close proximity to the lift, or induced from pulling the long long speed pull chain.
    I wanted the fan dropped off the ceiling a bit so it had "breathing room" for circulation meaning it's super stubby drop rod that it came with was too short (and short enough that the blades would be very close to the pitches of the roof) and my quick dirty measurements would have had it perfect when using the silver spare old drop rod I had laying around, appropriately 7" of clearance.
    Except the fan was too old so the drop rod was incompatible something I didn't consider and I didn't have anything else sized appropriately so I did what's natural to a figure it out'er and put a magnet to both the original 3" rod and my 2' rod, both ferrous so I figured I could weld them, (it's 3am mind you) so I cut the old 3" rod in half ground all the ends and welded the 1.5" ends to the long rod but in my infinite wisdom and good shop practice of measure once cut twice (and the damn thing is still too short!) I somehow forgot to carry the frog (Egyptian algebra reference) and that perfect length rod was now 5" longer. I was considering 1" into the ball and 1" into the fan of the new rod but didn't remove that from it when adding the 3" of original rod which was further modified slightly adding to length again.
    Ultimately though, it works so maybe one day it will be rehashed appropriately, however function far supercedes appearances for the time being.
    It's just a blessing to have space to work at all for the first time ever.
    Thank God.
    Space which I took full advantage of when I used it to put new (used and refreshed) Camburg arms on to replace my old clapped out All-Pro's.
    It's incredible to me how that little bit of pivot position relocation drastically improved handling and ride quality.
    And it's so nice to be able to work inside in the shade out of the rain and bugs.
    Still deathly humid though.
    :bananadead:
  5. Sep 23, 2022 at 11:24 AM
    My Name is Rahl
    Beautiful country down there, and the best coffee in the world!
    No. I mean less than $20k.
  6. Sep 23, 2022 at 11:52 AM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Sweet! I love coffee.
  7. Sep 23, 2022 at 11:58 AM
    My Name is Rahl
    You can import the coffee, from Café Ruíz, which is the coffee roasters we visited.
    https://www.ruizcoffee.com/
    Their roasting factory and gift shop are amazing, they even have a coffee taste testing course. They have extensive tropical gardens, a koi pond and a 4 story fire tower kind of thing to see the surrounding area.
  8. Sep 23, 2022 at 12:50 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I put Schlage in my own house. I used to reykey those and Kwikset at my old job, and the Schlage was definitely built better. Reminds me I need to order a rekey kit as I have one lock that isn't the same key.
  9. Sep 23, 2022 at 12:53 PM
    07RedTacoDawg
    07RedTacoDawg Well-Known Member
    Danny
    Jamestown , NC
    07 Red Tacoma
    2 inch lift , tires and wheels
    Sure could have used Cole to ride this lawnmower around for a few hours today.
    :spending:
  10. Sep 23, 2022 at 12:53 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Same... :pout:
  11. Sep 23, 2022 at 1:30 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Time for spray on insulation and an air conditioner. :cool:
  12. Sep 23, 2022 at 1:47 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Heh, I could do without the AC, but I need the heat! Luckily I have that big torpedo heater!
  13. Sep 23, 2022 at 2:53 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'd go mini split.
    Can heat and supply chilled air.
  14. Sep 23, 2022 at 3:45 PM
    Jtcmedic
    Jeff
    Florida
    2014 prerunner sr5
    Well bees are strapped in will see what this storm wants to do, on shift tommorow so wanted to get all live stock squared away and Sunday will know the main track and board up for the family got all the prep work done. I’ll be on duty Tuesday and will most likely be held over till it passes. @Hunterdc1 you guys park that bird in the garage yet
  15. Sep 23, 2022 at 4:15 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :fingerscrossed::fingerscrossed:
  16. Sep 23, 2022 at 4:22 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    He has a fairly big space, being cheap he could get a used mobile home package unit, 3 wires and 2 ducts and you are cooling. They are usually rated around 2 tons (24,000 btu) and have a powerful blower.
    I scored one at an auction years ago, never got around to installing it naturally. :laugh:
    The garage is made of block so those projects are a bit more complicated.
  17. Sep 23, 2022 at 4:29 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Well, the things that make you want to say :censored:...
    We were sitting in the living room last night about 9 and heard a tremendous thump like someone hit the roof with a sledgehammer.
    Wife gave a surprised yell, I gave a knowing swear.
    It didn't fall on the roof in the lumberjack "timber" way, it blew out of the tree and planted butt first, I heard it -- "bam" (the butt) then slap "fwoosh" (the greenery)...
    Punched a good fist size hole in the roof, guess I know what is on the agenda for tomorrow...
    Roof should have been replaced about 15 years ago...
  18. Sep 23, 2022 at 4:31 PM
    wilcam47
    Will
    Bourbon state
    You have some kind of rabid squirrel beaver there?
  19. Sep 23, 2022 at 4:41 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :rofl:
    There are 2 maple trees that tower over the house in the back, the bases are almost 4 feet across. They aren't "good" trees from the lumber standpoint as in nice and straight, they have all sorts of random direction limbs, probably from being broken by the wind so many times over the years.
    The wind routinely tears parts out of them, I have been cleaning it up for years.
    The bit that fell isn't rotten, it just lost out to the wind up here on the top of the hill.
  20. Sep 23, 2022 at 4:47 PM
    My Name is Rahl
    Cousin to the Jackalope?
