Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Sep 26, 2022 at 9:03 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The unusual shaped light bulb is a Westinghouse "Eye Saver", the shape is called T-19, the regular lamp we are familiar with is an A-19.
    The T-19 shape was designed so that it permits a broader light distribution onto the lamp shades producing more light out of the lamps and makes light easier on the eyes.
    Introduced by Westinghouse in 1958, discontinued by Phillips in 1997.
    Delta09, Cwopinger, 80yotaguy and 2 others like this.
  2. Sep 26, 2022 at 9:08 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Yep we board up and it’s fine, so I’ll do it so that it will be fine.:p I’ll post some pics in between calls ​
    Delta09, Cwopinger, 80yotaguy and 3 others like this.
  3. Sep 26, 2022 at 9:09 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    As long as wifey is OK with how you spend your anniversary you are golden - congratulations!
    :gossip: Flowers, chocolate, shiny stuff, nighttime stuff, etc are never a bad idea though...
  4. Sep 26, 2022 at 9:14 AM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    I've never torqued a drain plug in my life. :anonymous:
    Pretty much everything I torque is for uniformity, like wheel lugs and heads, scope mounts and rings. I have a ½" drive for most stuff and a ¼" drive for scope mounts and rings. I guess I skipped ⅜"... o_O
  5. Sep 26, 2022 at 9:14 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Those are almost as expensive as the one I bought and I'd need two of them to cover the torque range.
    The HF torque wrench would have been a more fiscally responsible purchase, but that damn Amazon is just so easy!
  6. Sep 26, 2022 at 9:16 AM
    Fargo Taco
    Fargo
    2019 TRD Pro
    I wasn't so worried about the oil pan drain plug, it was more about the oil filter housing and the associated drain plug.
  7. Sep 26, 2022 at 9:23 AM
    BussinGus
    That makes sense. :thumbsup: Definitely don't pay any attention to what I'm doing! :rofl: I learn the most through breaking things. :anonymous:
  8. Sep 26, 2022 at 9:25 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Only thing I use mine for is lug nuts plus one ugga dugga and head bolts :anonymous:
  9. Sep 26, 2022 at 9:31 AM
    Jtcmedic
    Jeff
    Florida
    2014 prerunner sr5
    7769714B-7CF8-4C41-924E-398DE6E9DD9B.jpg Filled up some extra washing water
    , got a well just don’t like using the generator to run it
  10. Sep 26, 2022 at 9:39 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :woot::woot:
    One of my all time favorites, a GMC F model commonly called "The Crackerbox" for a more or less obvious reason.
    Built from 1959 to 68 the all aluminum cab Crackerbox was a truck built to address a specific issue - the length restrictions for trucks back then, especially in the eastern states. By making the tractor both as short and light as possible it allowed pulling a longer and heavier trailer -- that is where the money is after all.
    With the single rear axle a wheel base short as 108" could be had -- remember last weeks 68 Camaro? It also has a 108" wheelbase.
    Trucking companies of the day weren't really worried about driver comfort (or safety) and the 48" cab of the CB made that obvious, the model pictured is equipped with the optional luxurious sleeper, it offered 30" shoulder room on the passenger side and narrowed down to 22" on the driver side.
    Below is the non sleeper version, note the truck on the left has a setback axle, a configuration popular with straight trucks like refuse packers, etc.
    Notice also the engine popping out the back - for part 2.
  11. Sep 26, 2022 at 9:41 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
  12. Sep 26, 2022 at 9:43 AM
    BussinGus
  13. Sep 26, 2022 at 9:57 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The engine is the legendary 6-71 Detroit diesel, first introduced in 1938.
    The 71 series can be immediately identified by the removable oval covers in the side of the block, the 53 series doesn't have them.
    Up to about 1970 the engines were branded "General Motors Diesel", in later years the company was renamed "Detroit Diesel".
    Re-post from when Cory teased us about this truck:
    The Detroits are 2 stroke diesels, since they fire every stroke of the piston they sound like they are turning twice as fast as a conventional 4 stroke engine thus the nickname Screaming Jimmy - Jimmy being slang for GMC.
    The 2 stroke Detroit engines were quite revolutionary when introduced in 1938, a compact modular design using parts commonality across a variety of models based on a 71 cubic inch per cylinder displacement. 53 cubic inch models were introduced in 1957 along with V configuration engines. 1, 2, 3, 4, 6, 8, 12 and 16 cylinder versions were produced.
    These 2 strokes are all equipped with a supercharger (Roots blower) and have no intake valves, the cylinder liner has ports that are uncovered when the piston is at the bottom of the stroke, the supercharger forces in a fresh air charge while simultaneously scavenging the cylinder when the exhaust valves (2 on early engines or 4 on later ones) open.
    Detroits also do not have a conventional high pressure injection pump. A low pressure pump provides fuel to individual unit injectors that are operated by the camshaft.
  14. Sep 26, 2022 at 10:01 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I needed a higher range torque wrench and bought a Tekton, I was stunned how nice it was for the price. Came with a nice blow molded case too. :thumbsup:
  15. Sep 26, 2022 at 10:05 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Experience: That thing you have right after you needed it... :rant:
  16. Sep 26, 2022 at 10:06 AM
    BussinGus
    • My pneumatic gun was dying, so I bought this impact this summer. It was on sale, found out out afterwards that it's one of the strongest ones the torque chanel has ever tested... 16642115847553649542479831463079.jpgso I bought these to (hopefully) stop myself from breaking stuff
    Turns out the gun has high, medium and low torque settings and will shut off at whatever you set it to. :rolleyes:
  17. Sep 26, 2022 at 10:08 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    John Deere built 4,626 435 tractors in 1959-1960 with a 2-53 GM diesel, they scream as well.
    https://youtu.be/0sCLVdBGlBo
    Oliver also had a GM diesel in the 990 made in the late 1950's.
    https://youtu.be/y9CcNs-6Les
    Massey Furgeson also had one.
    https://youtu.be/Ht5HUwwGzeM
  18. Sep 26, 2022 at 10:09 AM
    BussinGus
    Very cool! Never heard of them.
  19. Sep 26, 2022 at 10:09 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
  20. Sep 26, 2022 at 10:20 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    A bit more Detroit trivia:
    6-71 engines can be configured in many ways to meet different design requirements.
    They can rotate right or left, popularly used in twin marine applications and also be in a lay down configuration as used in busses.
    If you grew up on the West coast you might have ridden to school in a Crown Super Coach powered by a mid mounted lay down 6-71 Detroit.
