Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
How do you rinse when brushing your teeth?
  1. Mouth under spigot
    26.1%
  2. Hand(s)
    34.8%
  3. Cup
    17.4%
  4. I don’t rinse
    21.7%
  1. Oct 12, 2022 at 2:49 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    My one and only time deer hunting…..that’s a lie :rofl::rofl::rofl:
  2. Oct 12, 2022 at 2:56 PM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    My one and only time this afternoon? o_O
    Same corner, different tree... I'm liking the climber. 16656116642683111551225125235659.jpg
    Delta09, Slashaar, Hunterdc1 and 7 others like this.
  3. Oct 12, 2022 at 3:06 PM
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    They really do not want a kaboom in there. :eek:
  4. Oct 12, 2022 at 3:16 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
  5. Oct 12, 2022 at 3:19 PM
    308savage
    Adam
    East Tennessee
    Looks like raccoons are starting to ride the stalks over in that corner.
  6. Oct 12, 2022 at 3:19 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :infantry:
  7. Oct 12, 2022 at 3:22 PM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Any recommendations on air compressors?
    I’m going need a more air for another CNC machine and I also need to get a blast cabinet for blasting parts.
    Trying keep the budget under $2k and would like something on the quieter side because the kids bedroom is above my garage and I do a lot of my work at night.
    Looking at this option currently.
  8. Oct 12, 2022 at 3:22 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Yes sir, you’ve got it!
  9. Oct 12, 2022 at 3:24 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    The biggest thing is the CFM’s to what the compressor puts out and the sandblaster uses. I know they eat a lot of air!!!
    NoOne, Fargo Taco, RustyGreen and 2 others like this.
  10. Oct 12, 2022 at 3:32 PM
    308savage
    Adam
    East Tennessee
    I just asked him what the thread pitch was on the handle, he said probably JB Weld pitch! I told him I could grind off the chrome and weld it.
  11. Oct 12, 2022 at 3:38 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :popcorn::popcorn::popcorn:
  12. Oct 12, 2022 at 3:40 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :popcorn::popcorn::popcorn::popcorn:
  13. Oct 12, 2022 at 3:40 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Or take it apart and have a guy make a whole new one :oldglory:
  14. Oct 12, 2022 at 5:05 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    You and me both!
    :popcorn::popcorn::popcorn::popcorn::popcorn:
  15. Oct 12, 2022 at 5:08 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Compressor Tech with Rusty, part 1
    Blast cabinets take huge volumes of air and will work consumer grade compressors to death in fairly short order. A true 5 hp, 2 stage, 80 gallon unit is a good start.
    A good commercial grade 2 stage reciprocating compressor will produce 3-4 cfm per horsepower at 175 psi, note many consumer compressors show a cfm at 40 psi, this is a worthless number used to try to look good -- you show me an impact gun that runs on 40 psi.
    Below please find an example of the Rolls Royce of air compressors, this is a Saylor Beall 705, made in St. Johns Michigan. This is a design standard that you can compare all others to, most will fall short.
    1) Valves: The valves are the #1 thing that requires service on an air compressor, this unit (all SB compressors) uses air operated disk valves, they wear virtually forever and are easy to service. Notice the threaded plugs for access. Lower grade units use reed valves.
    2) Bearings: The crankshaft (ductile iron) rides on tapered roller bearings, lesser compressors ride on ball bearings. Both ends of the connecting rods have replaceable bearings.
    3) Cast iron block and heads: Even the intercooler is cast iron on a SB, lesser compressors use aluminum heads, many consumer grade units use aluminum blocks too.
    4) Other: Note the centrifugal unloader, this is a standard item on a commercial grade compressor, it allows the pump to come up to speed before pumping air, it makes the electric motor last longer and saves electricity too.
    Finally, observe that this is a splash lubricated compressor, although "pressure lube" sounds nifty it really isn't needed in all but the most severe service, all SB compressors have a pressure lube option.
  16. Oct 12, 2022 at 5:12 PM
    308savage
    Adam
    East Tennessee
    I don’t think he’ll ever use it again, but I’d like to fix it right.
  17. Oct 12, 2022 at 5:30 PM
    My Name is Rahl
    I'm not kidding. I've only been deer hunting once.
  18. Oct 12, 2022 at 5:38 PM
    Tacoma Mike
    Southern Maine
    Oil less compressors are noisy as fuck.
    Have not heard a quiet one yet.
    belt driven compressors are lower rpm and the pulse is a lot more calm.
    It’s going to be noisy anyway but much more manageable.
    I’m still looking for a vertical belt driven I can snag.
    Can’t hear anything when mine is running.
  19. Oct 12, 2022 at 5:42 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Me too. :anonymous:
  20. Oct 12, 2022 at 5:44 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Compressor Tech with Rusty, part 2
    Bullet points:
    • Disk valves
    • Roller bearings
    • Cast iron block & head
    Although all Saylor Beall compressors meet this list they aren't the only units built this way. In the past there were many, the list has dwindled over the years.
    Quincy QR series: This is the top of the Quincy line and their only model checking all 3 of our points.
    FS Curtis Masterline series: Checks all 3 points. These have been in production since 1897! Built in St. Louis, Missouri. I have one built in 1944.
    The CA & CT series also feature cast iron construction, the literature is a bit vague on the bearings and valves. Curtis used to be 100% US owned, in 2005 they were purchased by Fusheng Industrial (FS) who is the largest manufacturer of air compressors in China.
    Tier twos:
    Champion R series: These have disk valves and roller bearings however they use an aluminum cylinder with a cast iron liner and perhaps an aluminum crankcase.
    Ingersoll Rand: Personally I'm not a fan for a few reasons.
    The famous V style Type 30 is a good unit with a long history, it is a reed valve, ball bearing unit however. You will work on the valves long before a disk valve pump.
    The mono block units you see at TSC are consumer grade units.
    Personally, IR is a giant p-i-a to get quotes, information or parts from and expensive for what you get too.
    https://www.saylor-beall.com/
    https://www.quincycompressor.com/products/reciprocating-piston/
    https://us.fscurtis.com/product-category/reciprocating-air-compressors/
    https://www.championpneumatic.com/en-us/products/reciprocating-compressors
    https://www.ingersollrand.com/en-us/air-compressor/reciprocating-air-compressors
    tirediron, PzTank, Bivouac and 9 others like this.
