Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Oct 13, 2022 at 9:18 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
  2. Oct 13, 2022 at 9:33 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    My guy won’t throw anything away. He put the broke blade on the cart, the scrap bin is beside the saw. Almost made it :frusty:
    When he goes to lunch, it will make it.
  3. Oct 13, 2022 at 9:36 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Been thinking about how to make this piece. I tried to make it in one piece with the hot wrench. Fail.
    2 piece it is.
    @prise this is the latest mini creation, started on it in June.
    Real one I'm replicating.
  4. Oct 13, 2022 at 9:44 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Hi guys!
    The "non rod side" of a cylinder will always win because there is more area on the base side of a cylinder piston.
    What you have is probably trapped pressure in the cylinder, between the control valve and the cylinder itself. I doubt the reliefs are adjustable so you are gonna have to somehow cycle the valve until that trapped pressure is vented. Watch out cracking pressure lines or you can take a bath (or worse) like your buddy.
    Why would the relief crack both ways? Air does strange things lol. start bleeding at the pump and work out to the functions.
    Worst beating I ever got was from a 1/4" hose. I was underground in a tunnel doing testing in a confined space. At 5K psi the fitting let go and that hose about beat me to death before I managed to hit the e stop. I needed lots of stitches and I had welts and bumps all over me. Never mind the oil was around 125 F. Had to wait 45 minutes to get a ride to the surface.
    Fun times. Be careful.
  5. Oct 13, 2022 at 9:51 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Thank you for the info, sir :hattip:
  6. Oct 13, 2022 at 10:02 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    This never even occurred to me... :crazy: D'ohhhh!!!!!! Thank-you!!!
    My plan is to support the bucket with the forklift and bleed from the pump back, and yes, well aware of the entertainment that can arise from a hose when it suddenly has a place to let the pressure escape to... my hope is not to take a bath or a face-full.
  7. Oct 13, 2022 at 10:08 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I did some digging on Eaton Compressors a few years ago for a work related purchase of a 75hp machine, even spoke to them on the phone, we ultimately went with a Sullair based on both the machine and the support available.
    For Eaton piston units in the 5-7.5 hp range I found it complicated... :confused:
    Sticking with our flagship Saylor Beall compressor for a moment, go to their website and look around. Try to answer questions about the performance, construction, valves, bearings and where the pump is actually manufactured.
    I can save you the effort -- it is all readily available right there, easy to find and easy to understand - "transparency" in business terms.
    Now try to answer the same questions about an Eaton product -- not very easy to the point of not really possible - although there are a lot of "words" available. Notice I said "product" - Eaton, the parent, is marketing units under several brands through different avenues.
    Now let's turn to marketing. I have a real issue making a major and long term purchase through any box store/mass marketer/web only business. Take the example of a Kubota tractor over one purchased through Northern Tool or TSC.
    If your Kubota has an issue you can take it to a local dealer, or the one in the next town or next state even. Even if the unit is several years old the dealers can still get parts and service it. If you purchased from TSC they don't service anything and for information you might get told "we don't sell that one anymore, sorry". :notsure:
    A quality compressor will last decades in a busy shop with regular maintenance, for the smaller shop it might be a lifetime purchase so spending a bit more on the front end isn't quite so difficult.
    https://www.saylor-beall.com/
  8. Oct 13, 2022 at 10:13 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    At the old job the policy was "do anything you can to improve the process..." :)
    "...but don't spend more then $200..." :frusty:
    And then
    "we spent a lot of money on that, is it done yet???" :annoyed:
  9. Oct 13, 2022 at 10:16 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    We have a Sullair here at work, it’s 3 phase, 7.5HP, and been pretty good to us. It’s not really that quiet though.
  10. Oct 13, 2022 at 10:29 AM
    My Name is Rahl
    @Hobbs!!!
  11. Oct 13, 2022 at 10:57 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No problem, glad I can help. If any of you have any questions just tag me. I know a bit about a few things.
  12. Oct 13, 2022 at 11:23 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That only took…..too long :bananadead:
    Slashaar, 80yotaguy, NoOne and 6 others like this.
  13. Oct 13, 2022 at 11:24 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :rofl::rofl::rofl:
  14. Oct 13, 2022 at 12:11 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :rolleyes::rolleyes::rolleyes:
  15. Oct 13, 2022 at 12:32 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Here is the largest compressor I have in the archives, Quincy QR 325, Rolls Royce class.
    This is a giant, the pump body is about 28" tall, it has a Wisconsin twin for power. Entire unit weighs just under 1200 pounds.
    It was a 500 mile round trip to fetch this one. Sorry for the poor photo, it is kind of boxed in.
  16. Oct 13, 2022 at 12:37 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The gadgets on top are pneumatic unloaders. As this machine has a gasoline engine the pump spins all the time, these vent the pump when the tank is at full pressure.
  17. Oct 13, 2022 at 12:50 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I put some 12 oz soda cans in for scale, this is a massive unit, 60" tall to the top of the air cleaner.
  18. Oct 13, 2022 at 12:55 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Congrats. You should've just sent them the golf course scoreboard posts.. close enough. :D
  19. Oct 13, 2022 at 1:04 PM
    tirediron
    That baby can squeeze some air!
  20. Oct 13, 2022 at 1:15 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Everyone posting pics of compressors. Here is ours:
    Five gal bucket for reference in behind it. 193 psi 20hp. Very quiet.
    I won't post mine from my personal shop. I think I am the 5th owner. It sounds like a hailstorm on a tin roof when it runs. I am ready to shoot it and put it out of it's misery. I would show you a tag but there is none, even under the 36 coats of paint.
    Gonna break down and get a simple 5hp 20 gal vertical tank when I have a minute.
    Seriously, I cringe when I have to use air tools. My wife cannot be at home. My neighbors 900 feet away will duck with this thing starts. My streetlights dim.
