Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Oct 29, 2022 at 5:27 PM
    Tacoma Mike
    Southern Maine
    It would peel
  2. Oct 29, 2022 at 5:30 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Then rust:anonymous:
    Zebinator, Delta09, BussinGus and 6 others like this.
  3. Oct 29, 2022 at 5:35 PM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    That is one I have not seen yet. Ive seen, Ford, GM, Chrysler, and Nissan like this so far.
    six5crèéd[OP] and RustyGreen like this.
  4. Oct 29, 2022 at 5:46 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Who is making these?
    I really do like them and I know, no 2 would ever be the same.
  5. Oct 29, 2022 at 5:47 PM
    wilcam47
    Will
    Bourbon state
    @phillstill ;)
  6. Oct 29, 2022 at 5:51 PM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    This is the Spyderco Mule Team knife. I make and sell a handles for it.
  7. Oct 29, 2022 at 5:55 PM
    koditten
    Kirk
    Central Michigan
    I guess I better check out your add.
    Thanks.
    Kirk
  8. Oct 29, 2022 at 5:57 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Delta09, BussinGus, Bivouac and 4 others like this.
  9. Oct 29, 2022 at 5:59 PM
    koditten
    Kirk
    Central Michigan
    "Man made horrors" yeah, Ohio State Police.
    Ask me how I know...
  10. Oct 29, 2022 at 6:01 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    I'll have to check them out! This was the harness they gave us when we picked him up, we're planning on replacing it with something that handles the pulling better.
  11. Oct 29, 2022 at 6:02 PM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    I also have a few of my own fixed blade designs I make, and some more of this Fordite material. My Instagram is in my signature below if you want to check out more work. You can also send me a DM here if you are interested in more.
  12. Oct 29, 2022 at 6:03 PM
    koditten
    Kirk
    Central Michigan
    Thanks, I will be checking out the knives.
  13. Oct 29, 2022 at 6:29 PM
    Gunshot-6A
    Conner
    Everett, WA
    *troopers, they'll correct you :rofl:
  14. Oct 29, 2022 at 8:56 PM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    Well, I'm sleeping in a bit tomorrow. :) He came out at last light about 15 minutes after a couple of doe bleats and cut a diagonal across the field right to me. I had just finished packing up all my stuff and was looking at a possum that walked out when I saw him. He was already half way across the field and in a little gulley. With the light fading I thought it might have been a coyote until he got closer and on higher ground. He was across a drainage ditch from me at about 30 yards quartering slightly towards me when I shot. Heard that satisfying thwack, he turned and ran about halfway back across the field and piled up. Double lung.
    He's super old, only has a few bottom front teeth, nothing else! I doubt he would have lasted long after the rut.
    He's got a little sticker for a total of 11 points, and I'm pretty sure he'd be over 250 on the hoof. IMG_20221029_191303.jpg IMG_20221029_201020.jpg
  15. Oct 29, 2022 at 9:03 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I don't know if I would go as far as monumental...
    They looked great and had an array of fine engines from the leaning tower of power to the 440 and the legendary TorqueFlight automatic.
    They also had:
    - ridiculously small brakes that didn't stop for jack and a hand brake that would stick unless you took the linkage apart and greased it every 3 months
    - the wonky unit bearing front end with the stunningly expensive press bearings that nobody remembered to grease -- until they replaced them once that is
    - the 2 speed heater that emitted more noise than heat -- all winter your feet were always wet and freezing, the floorboards just wet
    - the defroster sucked too
    - typical Chrysler wipers that left half the passengers view un-wiped, you had to crane your head to the left to see what you were about to hit
    - lets not forget the constantly leaky windshield that was cunningly designed to drip right on the main electrical bulkhead connector
    and then drip on the floor boards
    - the handy included ammeter passed the full load of the charging system, they had a habit of melting down
    - talk about handy, how about the fuse box (glass fuses) under the glove box lid in the middle of the dash, at least water didn't drip on that
    - they were completely devoid of sound insulation, driving on a gravel road sounded like you were in a metal shed
    - they used a floor hinged accelerator pedal, until the floor rusted away around it - just for comparison my 1966 Ford has a suspended pedal
    - and they rusted a bit too...
    Well, they did have great engines and transmissions... :notsure:
    Yeah, I spent a lot to time in and under 70's Dodge trucks.
    tirediron, NoOne, Delta09 and 8 others like this.
  16. Oct 29, 2022 at 9:21 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    That is awesome, I love it when a shelter dog gets a good home.
    Smart looking fellow too! :101010:
    NoOne, wilcam47, StayinStock and 3 others like this.
  17. Oct 30, 2022 at 1:34 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    All that time paid off, congratulations, that is an awesome deer :101010:
  18. Oct 30, 2022 at 1:37 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    We Don`t speak of the Ohio State Police!!
    They cost me much money over the years when the state was at 55mph.
  19. Oct 30, 2022 at 1:42 AM
    Bivouac
    I am not sure what I did!!
    Sound asleep and it felt like so one hit my left knee with a baseball bat!
    It was all I could do to hobble over and make Coffee,
  20. Oct 30, 2022 at 2:31 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Congrats on that nice buck:yes::yes:
