Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Nov 9, 2022 at 7:03 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Same here. Give me old man Michilins and I'm happy.
  2. Nov 9, 2022 at 7:04 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    That's what I have on the other truck :fistbump:
    RustyGreen and Fargo Taco like this.
  3. Nov 9, 2022 at 7:04 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I ditched my factory ones at 20,004 miles. They were ok, but was starting to loose traction in inclement weather. Threw a new set on here before winter. I gave the old tires away to a member on here, so they'll run them to the bars and then some :rofl:
  4. Nov 9, 2022 at 7:06 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
  5. Nov 9, 2022 at 7:10 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    My tire dealer if you bought the tires from them . A $10.00 flat repair remove the tire and patch the life of the tire.
    To many failed attempted plug repairs over the years.
    I worked for one employer as long as the tire held air it was run.
  6. Nov 9, 2022 at 7:10 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    they got lots tread left
  7. Nov 9, 2022 at 7:12 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    My dads motto...."if it's round and holds air....run it" :eek:
  8. Nov 9, 2022 at 7:12 AM
    koditten
    Kirk
    Central Michigan
    I find that odd.
    Been plugging tires for 30 years. I can't remember any plugs that didn't hold.
  9. Nov 9, 2022 at 7:14 AM
    Bivouac
    In the winter it took at least 20 miles for those tires to become almost round again.
    Talk about shaking and bouncing down the road.
  10. Nov 9, 2022 at 7:16 AM
    wilcam47
    Will
    Bourbon state
    Yep i only had one i didnt try because the hole was oblong but any nail or screw plug held
    RustyGreen and six5crèéd[OP] like this.
  11. Nov 9, 2022 at 7:16 AM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    Really? I've probably plugged 20 or 30 tires and never had one leak. I think it's pretty common, but I use contact cement to lube the plug. :notsure:
  12. Nov 9, 2022 at 7:19 AM
    Bivouac
    Where you doing just small vehicles like cars and pick ups??
    If it was a tire they serviced them all just became a policy to patch them all to not confuse the techs.
  13. Nov 9, 2022 at 7:19 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Same here, been watching dad plug tires since I can remember. If the plug will stay, I'll run it as long as it's not in the sidewall :thumbsup:
  14. Nov 9, 2022 at 7:21 AM
    wilcam47
    Will
    Bourbon state
    I know ive plugged tires that many times. All held air till tires wore out.
  15. Nov 9, 2022 at 7:24 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    o_O o_O o_O
    Sorry, I'm just way too picky about my tires :laugh:
  16. Nov 9, 2022 at 7:27 AM
    Bivouac
    Another thing a failed plug resulted in a service call to the vehicle or a call subcontracted if the vehicle was more then 100 miles away.
    After a few service calls at the dealers expense it was decided to just patch all flat repairs this policy started in the mid seventies . This policy might have only been on the tires sold by them.
    A flat repair on the Ford F550 a few years ago was like 50.00 inside rear tire.
  17. Nov 9, 2022 at 7:47 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    New poll*. I understand every situation is different, if it's a simple nail or screw, I'm plugging it and forgetting about it. If it's anything to do with the sidewall, it's going into mulch.
    *The poll is meant for the simple stuff, not the over complicated thing that only happens to other people and causes multiple vehicle accidents.
  18. Nov 9, 2022 at 7:49 AM
    koditten
    Kirk
    Central Michigan
    I know a guy who may have plugged a sidewall and drove back and forth to work for another year:anonymous:
  19. Nov 9, 2022 at 7:51 AM
    My Name is Rahl
  20. Nov 9, 2022 at 7:52 AM
    koditten
    Kirk
    Central Michigan
    I've even got free tire repair warranties on my tires and I still plug my tires.
