Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Nov 10, 2022 at 6:03 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Just got a quote for snap-in dentures for my wife.... 25k. Need 12k more to get it done.... :bananadead:
    Our siding just cost 12k a couple months ago...
  2. Nov 10, 2022 at 6:07 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :pray::pray:
  3. Nov 10, 2022 at 6:40 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    :eek: I think you could have done VA on that unit with your eyes!!!! Damn... I'm guessing that shaft ain't exactly soft material, either?
  4. Nov 10, 2022 at 6:41 AM
    tirediron
    Took you a bit (and way too much effort), but you got there in the end!
  5. Nov 10, 2022 at 6:45 AM
    tirediron
    Put a snap gauge in there.. you'll find (I bet) that the hole ain't so much round any more. The heat treat pulled it oblong. My guess would be poor quality steel.
  6. Nov 10, 2022 at 6:47 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I was thinking the same.
    I've never had good luck using the veneer gauges for measuring small diameter holes when getting that far past the decimal.
    RustyGreen and six5crèéd[OP] like this.
  7. Nov 10, 2022 at 6:48 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I told my boss maybe the steel was mislabeled which affected the heat treat.
  8. Nov 10, 2022 at 6:51 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    110V is just a tingle. Wait till you try and remove a phase of 480V (so 277v) on a breaker and accidentally hit the #3 phase on the live breaker beside it with an un-insulated screwdriver... :anonymous:
  9. Nov 10, 2022 at 6:52 AM
    tirediron
    Possibly, but I would expect it to symmetrical. This almost seems like some sort of inclusion in the metallurgy. That bit expanded at 'X' because it was proper A2, the other side touched on an area which contained contaminants and expanded at 'Y'? :notsure: Just a WAG...
  10. Nov 10, 2022 at 6:53 AM
    koditten
    Kirk
    Central Michigan
    I'll pass on that experience!
  11. Nov 10, 2022 at 6:53 AM
    tirediron
    Instant stubby screwdriver?
  12. Nov 10, 2022 at 6:56 AM
    My Name is Rahl
    Uh, why would you do that?!
  13. Nov 10, 2022 at 6:56 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I don't recommend it... Luckily I didn't have too good of a grip and not much of a connection and the screwdriver bounced outta my hand...
    Didn't even put a burn mark on it! o_O
    Just a reminder it's what happens when people are forced to get in a rush. Bad things couple happen. I also now carry an insulated screwdriver in my "crash" tool bag...
    tacotoe, 80yotaguy, Cwopinger and 8 others like this.
  14. Nov 10, 2022 at 6:58 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    When operations is yelling at you over the radio to get it up and running and you don't have the balls to say "go eff yourself, we gotta do this safely" and get in a hurry o_O
  15. Nov 10, 2022 at 7:00 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Met a few guys who got acquainted with 347V. They didn’t have much to say.
    Mornin Gents :hattip:
  16. Nov 10, 2022 at 7:02 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    :rant:Shane >> :laser: :boom:<< Murphy
  17. Nov 10, 2022 at 7:06 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Reminds me of that time I couldn't figure out which breaker this wire was on, turns out it was a 30 amp 220V and my pliers got a wire skinning addition :anonymous:
  18. Nov 10, 2022 at 7:08 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Telling them what your thinking comes with knowing you can leave the job anytime with no worries.
    It makes going to work so much easier as well. It made working fun for me the last 15 years.
    NoOne, tacotoe, Cwopinger and 5 others like this.
  19. Nov 10, 2022 at 7:10 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Well, I would have roared out of the house at 6:30 -- if it weren't so much work... :yawn:
    The temperature is up 25 degrees already, 63 in November. :woot:
    tacotoe, 80yotaguy, Cwopinger and 6 others like this.
  20. Nov 10, 2022 at 7:21 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    We had a guy in another plant touch 2 phases together in a small local disconnect.
    Somehow it not only tripped the 800 amp main breaker for the building but also blew one of the transformer fuses on the pole out front. That caused quite a mess -- fortunately not in my plant... :devil:
    As usual his
    @$$#ole
    boss (who had no skills other than a loud voice and knew nothing about equipment) was pushing.
    So, how did that work out for you today pal? :rofl:
    tacotoe, 80yotaguy, Cwopinger and 9 others like this.
