Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Nov 17, 2022 at 6:55 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Thanks for the info, I'll keep that in mind :thumbsup:
  2. Nov 17, 2022 at 6:57 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Hopefully this one holds :D
  3. Nov 17, 2022 at 6:59 AM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    :rofl:... and what's the best oil for it? :rofl:
    tacotoe, RustyGreen, wilcam47 and 2 others like this.
  4. Nov 17, 2022 at 7:05 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hmmmm an up weld? Nice!
  5. Nov 17, 2022 at 7:06 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    10w30 ftw:rofl:
  6. Nov 17, 2022 at 7:06 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I started at the top and went down :D
    tacotoe, Bivouac, RustyGreen and 2 others like this.
  7. Nov 17, 2022 at 7:11 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I almost said something but I don't want to catch a Critter :anonymous:
    tacotoe, Rezkid, Bivouac and 6 others like this.
  8. Nov 17, 2022 at 7:17 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :rolleyes::jpow:
  9. Nov 17, 2022 at 7:20 AM
    wilcam47
    Will
    Bourbon state
    :rofl::rofl::101010::101010:
    tacotoe, PzTank, BussinGus and 3 others like this.
  10. Nov 17, 2022 at 7:21 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :rofl::rofl::rofl::rofl::fistbump:
  11. Nov 17, 2022 at 7:22 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    FFS, I even have a new pair of contacts in! :annoyed:
  12. Nov 17, 2022 at 7:23 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I think they're hiring at the rocket place.... @Hunterdc1 :rofl:
  13. Nov 17, 2022 at 7:27 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Must have them in upside down.
    tacotoe, Cooldood, FastEddy59 and 5 others like this.
  14. Nov 17, 2022 at 7:27 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :cool:
    :rofl:
  15. Nov 17, 2022 at 7:29 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    tacotoe, Rezkid, PzTank and 4 others like this.
  16. Nov 17, 2022 at 7:57 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Well fellers my internet seems to have finally woke up for the day, as awake as the ancient copper wires of a rural DSL line get. :turtleride:
    Yesterdays Past Tech mystery device is an alternator full field tester.
    Up until the early 1960's cars came with generators which worked only tolerably well.
    1) They didn't charge very well at an idle - you could run the battery dead idling for a long time with the lights and heater fan on.
    2) The mechanical voltage regulators of the day weren't very accurate and could over charge the battery causing it to boil (and stink) on long high speed runs.
    3) As more powerful lights and accessories like air conditioning became common the generator systems were further taxed.
    Chrysler introduced the first standard alternator in 1960 on the Valiant model which although unusually styled and poorly marketed had many class leading innovations.
    The other manufacturers trickled in alternators into the mid 60's, some starting out on commercial, high performance and luxury models first.
    Early alternator equipped cars had a separate regulator box mounted mounted on the firewall, they were mechanical like the generator versions.
    Later ones were electronic, Chrysler went electronic in 1970, GM cleverly built the regulator into the alternator in 1969 calling it the "Delcotron SI" alternator, SI standing for "system intrigrated". These are the alternators people still put on vintage cars, old tractors, heavy equipment, etc. - the perfect device: cheap, reliable, easy to repair.
    What our device does is replace the regulator making the alternator go to full output for testing, this is called "full field".
    An alternator has to have some power applied, called "field excitation" to make power. By controlling the excitation voltage the regulator controls alternator output.
    Naturally the Wrenchmen of the day knew how to jump regulator wires to do this, however an oops when jumping wires sometimes lets the magic smoke out. :censored: The tool is just an easy way to test the alternator without jumping any wires.
    The rubber coated hook on the tool is used on the Delco SI alternator to push a tab built into the internal regulator just for testing purposes -- again a brilliant design.
    You can see the middle "D" shaped hole with the regulator tab at about 11 o'clock.
    This is what the GM SI regulator looks like. You can see the tab at 3 o'clock.
    tirediron, tacotoe, Cwopinger and 8 others like this.
  17. Nov 17, 2022 at 8:05 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    What we got here Rusty? I personally enjoy the crusty patina look.
  18. Nov 17, 2022 at 8:05 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
  19. Nov 17, 2022 at 8:07 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Looks a lot nicer than the neighbor at the (appropriately) bottom of the photo. :thumbsup:
  20. Nov 17, 2022 at 8:20 AM
    BussinGus
    tOlaRenCes aRE tOo tiGhT on THoSe nEw enGInEs!!! :duel:
    tacotoe, Delta09, StayinStock and 5 others like this.
