Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Nov 28, 2022 at 7:41 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    What the customer wants (and pays for) the customer gets... :notsure::crazy:
  2. Nov 28, 2022 at 7:52 AM
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    Thank You!
    Thank You!
  3. Nov 28, 2022 at 7:57 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    I'm finally back. I think. After a long, very drawn out series of events I'm back at it. @koditten was kind enough to send me some magnets for the flywheel on my 23hp Kawasaki powered Ferris IS1000Z. She's an oldie but a good one. I promised I'd post a video of it running, my apologies for this being so short but I have no idea what happened to the longer video I took. Weird.
    Backstory since this thread moves fast:
    Around late July I was mowing at dusk, pulled a turn and saw a cloud of oil smoke. I shut the mower down. Used my loader to move it closer to the house so I could work on it easily. After some investigation, it seems that the upper crank seal had basically nothing left to it. I finally found the correct seal, replaced it, got it running again. I mowed a tiny section where the tent was going to be for my kid's first birthday party, backed down the slope off my "patio" area and the mower stopped dead. I thought for sure that I'd locked up the motor. Pulled it back apart and found that a magnet let go from the flywheel and jammed up in the stator. Cool. Ordered a new stator (mine was shorted), and posted in here about it. @koditten was kind enough to send me some magnets to try for the flywheel. I found one that worked, epoxied it in, off to the races!
    I get half way through the shakedown run of mowing my back yard which was WILDLY overgrown at this point, the mower shut down as if I turned off the key. WTF!? No grinding, no squealing, nothing. Just like it lost power altogether. Weird.
    Pulled it back apart, both coils died at the exact same time- my guess? Oil soaked and fried them? Very weird. Zero spark. Ordered some cheap eBay coils, slapped them on, fired it up. Shakedown run. Ten minutes in, grinding sound. Shut the mower down. Pull everything back apart.
    Likely from all the oil from that seal, several of the 10mm bolts backed out and one was starting to contact the flywheel. :facepalm:
    Pull the flywheel, pull the bolts, clean out the threads, loctite, reassemble.
    This video is super short, and it's from before the loose bolt issue, but I did mow my entire yard at night in 28* weather because the mower ran and I was afraid to shut it down.
    Thanks again to Kurt for sending me those magnets, and if anyone finds themselves in this predicament and needs some Kohler or Kawasaki flywheel magnets to try, send me a PM and I'll ship them your way.
    https://youtube.com/shorts/L93jOMxDv28?feature=share
    https://youtube.com/shorts/quPi7asDpV0?feature=share
  4. Nov 28, 2022 at 8:26 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    @Fargo Taco
    Whilst you're contemplating your donut choice (that @RustyGreen was so kind enough to purchase), please leave this one alone. Thank you!!
  5. Nov 28, 2022 at 8:30 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Thanks for the follow up. We all love picture!
    Glad you got it straightened out
  6. Nov 28, 2022 at 9:45 AM
    shaeff
    Hudson Valley, NY
    You bet! Had to follow through, albeit a bit late, on my promise! :)
  7. Nov 28, 2022 at 11:01 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
  8. Nov 28, 2022 at 11:04 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    @FishnTx they was checking the transmission lines by work.
  9. Nov 28, 2022 at 11:06 AM
    FishnTx
    South East Texas
    ‘17 OR
    :eek::eek::eek::eek:
    :101010::101010::101010:
    we had three jets fly over yesterday in formation… knothead freaked out!!!
  10. Nov 28, 2022 at 11:07 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  11. Nov 28, 2022 at 11:38 AM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    That's perseverance! :thumbsup:
  12. Nov 28, 2022 at 11:53 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    My mom pulled a 6 point out of the woods in VA this weekend as well!
  13. Nov 28, 2022 at 11:56 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Congrats to her!!!
    Was she wearing Christmas britches too :rolleyes:
  14. Nov 28, 2022 at 12:01 PM
    Gunshot-6A
    Conner
    Everett, WA
    Camo shirt and purple carhartt-esqe coveralls (Berne?)
    Edit: As I was...8 point!
  15. Nov 28, 2022 at 1:16 PM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    I put it on and was expecting it to look a lot more "flush" then I realized I don't have the plastic bed rail caps. I'm happyish with it, did take a month to get.
  16. Nov 28, 2022 at 4:40 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Sorry for the delayed response… The answer is that both are acceptable. There is ZERO specification for a requirement or standard. However Unions typically teach A is correct. Which means Hospitals, Venues, etc will have A. Others typically have B. If you have A, chances are a union electrician did the work!
  17. Nov 28, 2022 at 6:58 PM
    koditten
    Kirk
    Central Michigan
    That last pic is amazing! How you were able to snap it when the rotors where perfect right angles to the body, I'll never know.
    :101010:
  18. Nov 28, 2022 at 9:02 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
  19. Nov 29, 2022 at 2:41 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Morning all have a good day
    Back to the shift today
  20. Nov 29, 2022 at 3:15 AM
    POOLGUY
    JEFF
    ALABAMA
    Good morning everyone, have a great and blessed day.
