Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Dec 6, 2022 at 8:31 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I could prob do it if i had to...but nope any other day
  2. Dec 6, 2022 at 8:40 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Guess the Prime membership pays off. :)
    Morning Gents :hattip:
  3. Dec 6, 2022 at 8:43 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
  4. Dec 6, 2022 at 8:45 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Temps in the South Africian mine were around 105-110 F. The scary part of that was I was there in 1991, during apartheid. I had a guy with a machine gun escort me everywhere outside the mine.
    For Boston, they used a boring machine that poured a 2ft thick slip form tunnel right behind the tunnel boring machine. When it was done, they angled it down, sunk it and poured concrete over it since it was too big to fit back through the hole.
  5. Dec 6, 2022 at 8:45 AM
    wilcam47
    Will
    Bourbon state
    Id drive off with his truck with back door open for that
  6. Dec 6, 2022 at 8:50 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Just slide a section of bulk heat shrink tube on there if it really bothers you.
    Me: I like it that way. It allows lubrication to get into that section of the cable. This way you oil both ends and the middle.
  7. Dec 6, 2022 at 9:15 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    Sorry if I missed it but did you work in this tunnel? My father in law worked in it and was showing me pictures of it. He was up there in the union. Randal Hurley
  8. Dec 6, 2022 at 9:18 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I was there several months as a contractor. We provided the mucking solution and an additional car on the Tunnel Boring machine.
  9. Dec 6, 2022 at 9:30 AM
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    All fixed up, it’s like we read each other’s minds :rofl:
    I put a few drops of oil in the break before I taped it up. Also rerouted it to the outside of the spindle and let the spindle cover hold it in place. Seems like a much more natural position than before. The zip tie at the frame bracket, nothing appears to have been mounted there and vibrated off. The holes seem perfect for a zip tie.
    Time to bag some leaves
  10. Dec 6, 2022 at 9:30 AM
    williams63
    chili
    nh
    2011 dblcb
    I knew it was a big tunnel but I didn’t realize how big until he showed me a picture of a tractor trailer in it. With room to turn around!
  11. Dec 6, 2022 at 9:32 AM
    Cwopinger
    Blevin
    Florida
    They sacrificed a 32’ boring machine to Neptune. Must have been a fed govt contract lol
    tacotoe, 308savage, Bivouac and 6 others like this.
  12. Dec 6, 2022 at 9:33 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    It's better than new, it's repaired :D
    soundman98, tacotoe, Delta09 and 5 others like this.
  13. Dec 6, 2022 at 9:36 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
  14. Dec 6, 2022 at 9:39 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    tacotoe, Delta09, RustyGreen and 3 others like this.
  15. Dec 6, 2022 at 9:50 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Most times with a blind tunnel they design the TBM to be sunk at the end. They are pretty much worn out so all they are sinking is steel.
    Did it in Chicago too. Most people don't know there is a seven mile long lake under Chicago that is 32 ft in diameter and 800 feet below them. It was part of the Calumet project, so when it really rains hard and the storm drains are full, the overflow goes down to this tunnel and is gradually pumped out back to the lake, usually at night when energy is cheaper.
  16. Dec 6, 2022 at 9:56 AM
    FastEddy59
    Eddie
    Been to the bottom of Big Nickel. They have a research project mapping Neutrino’s. Understand very little of it other than it’s waaay deep.
  17. Dec 6, 2022 at 10:32 AM
    My Name is Rahl
    That's because it's pretty much the only place on Earth that doesn't have any stray radiation.
    tacotoe, RustyGreen, hiPSI and 2 others like this.
  18. Dec 6, 2022 at 10:34 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I guess your not really into caving then ?
    tacotoe, RustyGreen, hiPSI and 3 others like this.
  19. Dec 6, 2022 at 10:35 AM
    FastEddy59
    Eddie
    Ah, I get it. Mighty quiet down there. :lalala:
  20. Dec 6, 2022 at 10:48 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I've cut up a garden hose to use as a sleeve in certain scenarios. Had to use tin snips to cut through the rubber, but it works pretty good in certain heavy abrasive areas.
    -J
