Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Jan 27, 2023 at 10:08 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
  2. Jan 27, 2023 at 10:10 AM
    MGMDesertTaco
    Brush fire truck I think? Scottsdale has everything, side x sides for EMS, horseback police, ect.
    RustyGreen and six5crèéd[OP] like this.
  3. Jan 27, 2023 at 10:15 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    New toy at work.
  4. Jan 27, 2023 at 10:27 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :eek:
    :101010:
  5. Jan 27, 2023 at 10:27 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    But it also included “iconic replica movie items such as a Hoverboard, a pair of "self-lacing" shoes, a Gray's Sports Almanac and two sleeping bags.”
  6. Jan 27, 2023 at 10:30 AM
    Superdave1.0
    SoCal
    Some other ones, that I don't know how to use ha.
  7. Jan 27, 2023 at 10:49 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Not that I'll ever own Nike's again but I am generally aware those self lacing Nikes at retail are $7500-10k if they are one of the 1500 created in 2011.
  8. Jan 27, 2023 at 11:12 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :drool:
  9. Jan 27, 2023 at 11:16 AM
    Superdave1.0
    SoCal
    Sorry for being a post wh*** today. 55 series Land Cruiser with an LS swap just came in.
  10. Jan 27, 2023 at 11:19 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    You can be a post wh**e if you are going to provide Land Cruiser porn!:eek:
  11. Jan 27, 2023 at 11:24 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That’s awesome! Keep the photos coming :D
  12. Jan 27, 2023 at 11:29 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
  13. Jan 27, 2023 at 11:40 AM
    MGMDesertTaco
    I think I'd prefer a new one made to look like that one though. A lot of vehicles in the staging lane are having the batteries boosted with chargers before they roll across the block. Then there's the old belts, hoses, tires, paint and body imperfections, old brake and fuel systems, ect. Some deals to be had and things you wouldn't find for sale elsewhere, but you really have to know what you're buying.
  14. Jan 27, 2023 at 11:54 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I like the one on the right, because of the grain.
  15. Jan 27, 2023 at 12:00 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    You lost me at "LS Swap"! :(
  16. Jan 27, 2023 at 12:03 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I'm on my second toolbox because I cracked the first one on the inside corner, jumping my truck on the dirt track. It's held on by two bolts through the plastic mount from Lowes. When I put the bed slide in I needed more room under the toolbox, so I added these aluminum pieces as spacers. The toolbox is still held onto the truck with the same plastic mount. But they also let me get a better mounting surface for the toolbox, so it's less likely to crack again. This one's been like this for five years, and I haven't cracked it yet. :thumbsup:
  17. Jan 27, 2023 at 12:15 PM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    I have hazmat for fire, with the move to the new station they are sending me to tech school so hay it is out of the office and free school so I get to wear them again
  18. Jan 27, 2023 at 12:19 PM
    AncaGrind80
    AncaGrind80 Well-Known Member
    Robert
    2022 MGM TRD Off Road
    I can speak accurately to this, I make cutting tools for a living, including coolant-thru drills. Carbide is made by pressing a cobalt/tungsten mixture into molds. At that stage it's in it's "green" state. For coolant-thru material, wire is laid in the molds that correlates the the proper diameter coolant hole. For material that is destined to have straight holes, that is the last step before sintering, which hardens the green carbide into its final hardness. For material that is destined to have helical holes, after it comes out of the mold, while still in it's green state, the material is twisted to give the desired helix before sintering. In either case, the wire that was laid in during pressing melts from the high temps required for sintering leaving coolant ducts. When coolant-thru material is purchased the pitch of the holes (which correlates to helix) is provided. This allows the manufacturer of the cutting tool being made to program the helix of the flutes being ground in the tool to match the helix of the coolant holes so as not to grind through them. As someone mentioned, it is possible to EDM drill holes in carbide, but certainly not in a helix. Additionaly, while in the green state, carbide can be readily machined. On the occasion that I have to make a custom tool that an off the shelf carbide blank won't easily accommodate, I can get what is called a pre-form. This is simply a piece of carbide machined to rough specs while green, including any coolant holes that may be needed.
  19. Jan 27, 2023 at 12:41 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Makes perfect sense, thank you for taking time to explain :hattip:
  20. Jan 27, 2023 at 12:43 PM
    AncaGrind80
    Robert
    You are quite welcome, Sir.
