Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
Electrical outlet cover screws MUST be......
  1. Horizontal
    10.3%
  2. Vertical
    44.8%
  3. Not matching, ain't nobody got time for that
    17.2%
  4. Over torqued so the fake plastic cracks, then back off just a tad
    44.8%
Multiple votes are allowed.
  1. Jan 31, 2023 at 7:05 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Me as well 4 years to install the input cord on my dryer !
    The cord coiled on top the dryer That has 4 years worth of interesting goodies piled on top.
  2. Jan 31, 2023 at 7:11 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  3. Jan 31, 2023 at 7:16 AM
    PzTank
    Above the Notches
    Guess he doesn’t like to WFH :notsure:
    Or not get paid for work :D
  4. Jan 31, 2023 at 7:16 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    "Being done is more important than being perfect"... :anonymous:
  5. Jan 31, 2023 at 7:19 AM
    Bivouac
    :thumbsup::thumbsup::thumbsup: We all plan to get around to finishing things .
    As long as it works why bother.:anonymous:
  6. Jan 31, 2023 at 7:22 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Sounds like it is time for the monthly meeting of the COUP Club! (Collectors Of Uninstalled Parts).
  7. Jan 31, 2023 at 7:28 AM
    Kilo Charlie
    Kilo Charlie One flat foot on the Devil's wing
    Iowa
    2017 Inferno Off Road
    Or adopt the 5 minutes rule.
    If it can be done in 5 minutes or less.. just do it.
  8. Jan 31, 2023 at 7:31 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    One Christmas day the threaded section of the kitchen sink drain crumbled away, I was about 13 at the time and "fixed" it with a funnel made out of a gallon jug attached with an old piece of radiator hose.
    About 25 years later my mother had a plumber in to replace the old galvanized pipes, he looks under the sink and says "that's interesting"... :laugh:
  9. Jan 31, 2023 at 7:32 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I'm the President... :anonymous:
    ...and also...
    :frusty:
  10. Jan 31, 2023 at 7:36 AM
    ACEkraut
    Aaron
    Durham, Maine
    Well, elections have not been held and I would expect a full slate of nominees for President with many valid claims to the title. Then again, it is more of a default position than an elected position. OK, Prez, all you!
  11. Jan 31, 2023 at 7:39 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The problem is the "5 minute jobs" always bite my
    and turn into multi-day extravaganzas requiring disassembling major portions of the house, warmed up credit cards and much swearing. :rant:
  12. Jan 31, 2023 at 7:42 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    You have never seen "the archives" first hand, trust me on this one - I've got y'all beat for sheer amounts of stuff... :pout:
  13. Jan 31, 2023 at 7:59 AM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    Several years after my dad died, my mom's kitchen tap needed replacing. Working under the sink was nasty because there was only one cupboard door with the accompanying width. After I shoehorned my way thru the tap I tried it and the drain leaked ( I had noticed it was wet when I started). I followed the leak to that thread tailpiece and found that years earlier my dad had "rebuilt" it with silicone. o_O Much of the pipe underneath was now gone and about a 3" section was nothing but silicone. The strainer assembly was installed before my parents bought the house some 45 years earlier. I ended up having to cut the retaining nut off with a Dremel to replace the strainer assembly. It was a ton of fun working under there! :rofl:
  14. Jan 31, 2023 at 8:03 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yea, that was me replacing my bathroom faucet. Faucet was easy, but replacing the pop-up drain... well...
    Stuff gets real when you break out the saw-zaw.... :rofl:
  15. Jan 31, 2023 at 8:07 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    It’s definitely fine, when I brought the mill home I was excited to get it working and it became temporarily permanent. There is no cable management option with this vfd, I’ll have to mount a junction box underneath and run wire between. When I get time. Someday.
  16. Jan 31, 2023 at 8:07 AM
    cory02taco
    Cory
    Maine
    Thanks!!
  17. Jan 31, 2023 at 8:17 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    For years I had problems with the sink drain getting clogged up with a gel like substance - it would adhere to the vertical pipe (plastic). I would remove the pipe, take it out doors and clear it with a whipping motion. This occurred every 3 months or so. :confused:
    The pop up assembly started leaking so I replaced it with a commercial style with no pop up -- the gelling issue went away and hasn't returned in about 10 years. The only part I replaced was the drain tailpiece. :notsure:
  18. Jan 31, 2023 at 8:21 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Status Update: Dean is taking a break from TW. A few of us got ahold of him in the past couple days and he is doing well, just a lot on his plate.
  19. Jan 31, 2023 at 8:21 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Wonder if it's toothpaste causing the gel on the plastic? Ours does the same thing.
  20. Jan 31, 2023 at 8:22 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Good to hear, thanks for letting us know.
    @My Name is Rahl I know life can get tough, we're here for you if you need anything, friend :fistbump:
