Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Jan 31, 2023 at 11:57 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    My dad, too.
    I only started questioning it when I came across posts about messing up the tires but I think that was only for changing sides with directional tires.
    That and the owner's manual shows front to back only, but who reads that pesky thing?
  2. Jan 31, 2023 at 11:58 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Only directional tires can't be crossed without remounting.
  3. Jan 31, 2023 at 12:25 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    They're not directional tires, and they're all the same size. I go 'X' then side to side, then back to front, then 'X'. IIRC, the manual says side to side, but... who reads manuals? :confused:
  4. Jan 31, 2023 at 12:27 PM
    tirediron
    Was it front to back? Okay, I knew it was all preachy about it, couldn't remember which direction though.
  5. Jan 31, 2023 at 12:46 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :facepalm:
    :worthless:
  6. Jan 31, 2023 at 12:52 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    You first o_O
    :boink:
  7. Jan 31, 2023 at 1:04 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Pretty sure my phone is listening to me. :laugh:
  8. Jan 31, 2023 at 1:06 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I always cross the fronts and move them to the rear, with rears straight to the front.
    But I found this diagram, so I guess it should depend on the type of vehicle.
  9. Jan 31, 2023 at 1:06 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    I haven't hunted it down myself in the manual but I've seen plenty of screenshots diagramming front to back only.
  10. Jan 31, 2023 at 1:09 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    I was planning on the bottom-right, not dually rotation. :)
    six5crèéd[OP] and RustyGreen like this.
  11. Jan 31, 2023 at 1:10 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Something is funky, I got this today too...
    :rofl:
  12. Jan 31, 2023 at 1:12 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My last set of Michilins went 90k.
    I only rotated them once:anonymous:
  13. Jan 31, 2023 at 1:30 PM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    Same here. If they're not directional I cross them.
  14. Jan 31, 2023 at 1:33 PM
    Benjy
    Benjy Member
    Ben
    15’ Tacoma
    Old man truck
    I build precision rifles.
  15. Jan 31, 2023 at 1:35 PM
    BussinGus
    :bananadance::101010::woot::woot:
    :worthless:
  16. Jan 31, 2023 at 1:35 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :popcorn::popcorn:
  17. Jan 31, 2023 at 2:36 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    No.
    230 volt 3 phase is common in older or smaller industrial buildings, still 3 phase though.
    Most 3 phase motors have 9 wires allowing them to be wired for high or low voltage.
  18. Jan 31, 2023 at 2:44 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    In the early days of steel belted radial tires the superstition was that rotating tires in the X fashion that was common with bias ply tires would cause the steel belts to fly apart. Keeping the radial tires on the same side of the car "prevented" this. :crazy:
    It is more important that they get rotated regularly then where they get positioned.
    That said I still keep them on the same side. :rolleyes:
  19. Jan 31, 2023 at 2:48 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Welcome to the forum :hattip:
  20. Jan 31, 2023 at 3:27 PM
    Benjy
    Benjy Member
    Ben
    15’ Tacoma
    Old man truck
