Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Feb 4, 2023 at 6:44 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Good morning everyone, have a great and blessed day. It’s 45* where I am at my sister’s place in Northern California.
  2. Feb 4, 2023 at 7:01 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :annoyed:
  3. Feb 4, 2023 at 1:27 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Past Tech with Rusty,
    1940's heating edition - our forefathers went to the cellar every day all winter to deal with this stuff... :bananadead:
    (Actually it was the stay-at-home lady of the house who did more furnace tending back then usually. ;))
    Just finished the daily stove service, the Warm Morning stove is easy if a bit fiddly to service. Coal is always burned from the bottom up, the combustion air comes in under the fire. Eventually you need to shake down the ashes and add fresh coal.
    Some stoves and all furnaces/boilers I have ever seen have what are called "rocker grates", these are made of cast iron and have either a linkage or separate handles to turn (rock) the grates breaking up the what is left of the coal after all the carbon is burned out of it, it then falls in the ash pan below.
    High quality (Reading brand) coal will burn down to just about dust. Lower quality coal has more impurities which remain behind in the form of what is called "clinker" which can jam up in the grates. Cheaper coal is not only a PITA for a hand fired stove but also produces less heat, it is the carbon that burns (86-97%), the more impurities per pound the less carbon to burn.
    Below is the fire box of a large furnace or boiler showing the rockers. The white on the sides is fire brick.
    Rocker grates and the frame they sit in - all cast iron.
    The Warm Morning stove has a slider grate, it takes more fiddling to shake down.
    In theory you slide the movable section in and out - in practice doing that causes you to wake up to a cold house the next day because the ashes tend to form a solid funnel around the sliding section. :censored::rant:
    Now you dump all 100 pounds of partially burned coal out and start again. :annoyed:
    I use a combination of the slider and angled pick rod to agitate the ashes through the grate.
    With almost 30 years of practice it doesn't take long.
    The literature supplied with the stove states you can use any size coal that won't fall through the grates.
    Experience has taught me with this stove "bigger is better" ( queue @Delta09 for a wise guy comment ;)) and my coal dealer will pick my shipment off the top of a pile (with a loader), I usually end up with coal significantly larger than the "Stove" grade below.
    One ton of good Anthracite has about 25,000,000 Btus = about 180 gallons of #2 grade fuel oil.
    "Stove" size coal isn't too common anymore as very few people use the large hand fired furnaces common back in the 40's & 50's, one year after my usual order for "the biggest you have" he said he was worried what he had was too large.
    By mistake he had received one load of industrial furnace coal, about 3X larger than the Stove size, much of it was the size of 1/2 a football and a few pieces I had to break with a hammer to fit in the stove.
    It was the best burning coal I ever had.
  4. Feb 4, 2023 at 2:29 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    I don't know that I've ever seen the coal that we use for the boilers on campus but I do know that we burn through a rail car and a half each day when they are getting run hard.
    This picture doesn't really do it justice but here's the stockpile they have.
    https://goo.gl/maps/zqiXAKLCvWA1fivw8
  5. Feb 4, 2023 at 2:39 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Kid's new car wouldn't start. Yanked the battery and brought it home because it's a little frosty.
  6. Feb 4, 2023 at 2:42 PM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    Damn guys it’s like 80 degrees here :anonymous:
  7. Feb 4, 2023 at 2:49 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    There is a trick to shaking the grates and each stove can be different!1
    To much the fire falls into the ash tray not enough to much ash the fire tends to not burn well or go out.
    We always used Chestnut .
    When the switch to an oil furnace Mom said the first floor was now always cold.
    Never changed or sized any of the Duct work which did not help
  8. Feb 4, 2023 at 2:50 PM
    Bivouac
    They call it Hell`s waiting room for a reason!!
  9. Feb 4, 2023 at 3:09 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Lasering some wood right now
    CF3FC58A-7149-4381-B5BA-59C75B7959D3.jpg 763B6520-9504-4750-BC0D-81DFBD75CBF7.jpg
  10. Feb 4, 2023 at 3:10 PM
    wilcam47
    Will
    Bourbon state
    Nice! What size are those?
  11. Feb 4, 2023 at 3:13 PM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Awesome
  12. Feb 4, 2023 at 3:13 PM
    308savage
    Adam
    East Tennessee
    Flag is 11.5”x6”, other is 9.25”x7.5”
  13. Feb 4, 2023 at 3:13 PM
    MulletTaco
    Kevin
    Somewhere in AZ
    You’re not wrong! But if I drive a bit north it cools off dramatically
  14. Feb 4, 2023 at 3:18 PM
    wilcam47
    Will
    Bourbon state
    Looks like it cuts the shape also?
  15. Feb 4, 2023 at 3:24 PM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    Since I finally got my big compressor in the garage I can now replace this noisy guy in my shed shop
    Much better!!
  16. Feb 4, 2023 at 3:55 PM
    308savage
    Adam
    East Tennessee
    Yep!
  17. Feb 4, 2023 at 4:04 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    80s in February is for tourists and snow birds :rofl:
  18. Feb 4, 2023 at 4:22 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Right about now, I'd be pretty okay with those temps.
  19. Feb 4, 2023 at 5:02 PM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    Sweet! :101010:
  20. Feb 4, 2023 at 5:16 PM
    BussinGus
    Another single coyote day. We had another one up that took some #4 buckshot, but still managed to run us in circles until the tracks were indecipherable. We'll catch up with him later.
    The Tacoma was a champ today. The snow was a good 12" - 14" deep, and the drifts were quite a bit deeper, but I had no problem bombing through it. I don't think the pictures show it very well since the tire looks like it's sitting in 2" of snow, lol.
