Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
How do you rinse when brushing your teeth?
  1. Mouth under spigot
    28.6%
  2. Hand(s)
    38.1%
  3. Cup
    19.0%
  4. I don’t rinse
    14.3%
  1. Feb 13, 2023 at 12:54 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    KRAMERICA, soundman98, Wadar and 5 others like this.
  2. Feb 13, 2023 at 3:06 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :rolleyes::rolleyes::rolleyes:
  3. Feb 13, 2023 at 3:10 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Bigger kids seemed to be normal in the fifties I heard women complain all the time about 12 and 13 pound birth weights .
    Mom said I was 12 pounds maybe all the fur added weight.
  4. Feb 13, 2023 at 3:12 PM
    Bivouac
    Your talents are outstanding !:thumbsup::thumbsup::thumbsup:
  5. Feb 13, 2023 at 5:19 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    My favorite airplane story is when I was on a puddle hopper (an isle with single seats on both sides, about 24 total). The greeter was in fact the pilot. He went to start the right engine and all was well. He went to start the left engine and it didn’t start. He tried again… nope. He got out the plane, went turn the prop about 45 degrees and came back… started. We proceeded to fly through the worst storm clouds and turbulence I have ever experienced. Made those movies and AIRPLAINE! look like make believe. The flight home was uneventful…
  6. Feb 13, 2023 at 5:42 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So basically...
  7. Feb 13, 2023 at 5:59 PM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
  8. Feb 13, 2023 at 6:02 PM
    Wadar
    Wade
    A few.
    And cordless! :D
  9. Feb 13, 2023 at 6:07 PM
    Wadar
    Wade
    A few.
    :rofl:
  10. Feb 14, 2023 at 3:20 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Good morning everyone, have a great and blessed day.
    Delta09, wilcam47, Cwopinger and 3 others like this.
  11. Feb 14, 2023 at 4:13 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Good morning friends! Have a grand day, grand I tell ya!!!!
  12. Feb 14, 2023 at 4:27 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Finally got around to getting some plumbers putty and resetting the kitchen sink drains. When I put it in I used Vaseline cause that’s all I had. Wanted to fix it before the 10 year mark that is coming up :anonymous:
  13. Feb 14, 2023 at 4:51 AM
    lynyrd3
    Bill
    East Central Upstate NY
  14. Feb 14, 2023 at 4:53 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    :pccoffee:
    @Fargo Taco hasn't been around since getting "sinus junk", hope everything is OK.
    StayinStock, PzTank, wilcam47 and 4 others like this.
  15. Feb 14, 2023 at 5:19 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Aircraft mechanic here. That tape is what we refer to as "speed tape" and is used as a temporary repair until the aircraft can make it into a permanent repair facility. Its designed to be chemical resistant, UV resistant and pressure sensitive. It won't leave a gummy residue when you remove it like Duck Tape for instance. Sure it looks scary to see tape over a seam but it's not that bad. Some of our applications that we use it for are to cover sealant that hasn't cured the allotted time but the aircraft has to meet its scheduled departure time. It'll handle the freezing cold rain and temperatures up at altitude and sitting on a sunbaked airfield for weeks and still have the same hold as it had when it was initially applied.
    Most prop-job aircraft have either a hydraulically or oil pressure held prop brake that helps to slow and prevent the prop from wind-milling when the aircraft is stationary. The type I'm familiar with is held open with pressure applied to the system. In the event of a engine failure, system loss, the brake prevents the motor from spinning in flight. As a ground guy, we go out and 'X' the prop to ensure that the prop brake is not holding the prop preventing the motor from stopping. Since it was a smaller aircraft, it's normal that the pilot went out and disengaged the prop-brake prior to flight depending on what the checklist called for. Most of the time when the starter is engaged, it pressurizes the system enough to disengage the prop but if it fails, it's not generally a grounding condition.
    -J
    StayinStock, mit88, KRAMERICA and 9 others like this.
  16. Feb 14, 2023 at 5:22 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  17. Feb 14, 2023 at 5:35 AM
    My Name is Rahl
    Been okay. Just been lots of life stuff and stress and I had to cut out some things that I realized took up too much time.
  18. Feb 14, 2023 at 5:37 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Good to hear from you, hang in there brother :fistbump:
    StayinStock, PzTank, wilcam47 and 3 others like this.
  19. Feb 14, 2023 at 5:53 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Howdy Creed and Crew! Hope you all have a blessed day!
  20. Feb 14, 2023 at 5:54 AM
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    God morning Shane and friends. Have a awesome Tuesday
