Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Feb 19, 2023 at 12:10 PM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    It's a habit of mine to always look at peoples lugs at stop lights or really just where ever. That old Jeep- guy was super proud-and he should be..she was fresh underneath the crust. But he was missing a lug and had 2 others on his right rear 3/4 of the way off. Maybe I should've said something, didnt want to beat the guy up...
  2. Feb 19, 2023 at 2:05 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Random home-heating question, Mother-outlaw’s house is heated with an old (60s era) oil-fired hot water boiler. Occasionally it will turn in even though the thermostat setting is well above the call for heat temperature and it’s done the same thing with both its original and a brand-new digital thermostat. It was originally fitted with a domestic hot-water heater, but that’s been long removed. Any idea what might cause this? With the price of #2 oil and the house being vacant quite often, I’d like to figure this out.
    RustyGreen likes this.
  3. Feb 19, 2023 at 2:11 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    I am far from even remotely knowledgeable but on my thermostat, I need to tell it what kind of heating system it is (heat pump, boiler, etc.) so that the can cycle correctly. Since the same thing was happening with the old thermostat, I'm sure it's not that but it's at least worth a check.
    Edit: Is there possibly a draft that's blowing on it causing it to register cooler?
    tirediron[QUOTED] and RustyGreen like this.
  4. Feb 19, 2023 at 2:20 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Since it doesn’t sound like air temperature is causing a demand, I’d explore the water heater avenue. A demand call for water temperature could trigger the heat. Water items often corrode due to metal/mineral mixes, so this seems plausible in my head…sight unseen.
    tirediron, RustyGreen and Fargo Taco like this.
  5. Feb 19, 2023 at 2:32 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    cold air draft inside the wall
    damaged t-stat wires touching triggering a heat call
    boiler has some form of de-scale/reboil function
    tirediron and RustyGreen like this.
  6. Feb 19, 2023 at 3:07 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It's keeping the water to a certain temperature at all times. They never modified or updated the control. Mine was doing the same thing as it used to be the only source of hot water. Since I've added a water heater I don't use the tankless coil in the boiler anymore. I disconnected one of the wires in the control box and turned it into a cold start boiler. Your boiler being so old, I doubt has a control like that. No idea what they used in the 60's. You can probably adjust the low limit as low as you can go, but that might be it. Honestly that old beast needs replaced...
  7. Feb 19, 2023 at 3:25 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    If I was up close and in person I could figure it out
    No doubt the boiler control is still keeping a long gone hot water coil up to temperature.
    There should be an adjustment at the boiler for domestic hot water that was never disconnected .
    It might be piggy backed with the thermostat control wires . Just a guess.
    No doubt a Big Monster I hated removing them from basements.
  8. Feb 19, 2023 at 3:34 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Most likely there is an aquastat on the boiler. Older boilers require the water to stay above 130* to prevent condensation from developing on the cast iron heat exchanger.
    Your boiler is doing exactly what it was designed to do.
  9. Feb 19, 2023 at 3:40 PM
    Bivouac
    Valid point!
  10. Feb 19, 2023 at 7:04 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Birthday present project for father-in-law today, 11 layers
    E623EBA0-1671-43D7-9BA4-61B5D36D6DC0.jpg 12D6449B-E4BD-46E1-85E4-9EB19CBFE3F0.jpg 65782C0F-FA9B-4D34-B708-6AEA31CDBAC7.jpg
    srspicer, KRAMERICA, MarX and 16 others like this.
  11. Feb 19, 2023 at 7:09 PM
    koditten
    Kirk
    Central Michigan
    Um, gonna need deets!
    This is awesome, but you gotta give us some info on how it's done.
    I'm pretty sure I know, but I know lots of other peeps want to know the details.
  12. Feb 19, 2023 at 7:42 PM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    Cool! :101010:
    PzTank, wilcam47, Cwopinger and 2 others like this.
  13. Feb 19, 2023 at 7:56 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    That is so cool. :thumbsup::thumbsup:
  14. Feb 19, 2023 at 8:05 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    so cool. now cut 1/16" acrylic to the same shapes, layer it between the wood panels, and perimeter light it!
    PzTank, wilcam47, BussinGus and 3 others like this.
  15. Feb 20, 2023 at 3:09 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Good morning everyone, be safe and have a great and blessed day.
    MarX, Delta09, wilcam47 and 4 others like this.
  16. Feb 20, 2023 at 3:32 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :hattip: Manly men
    Monday is upon us, still 41 degrees outside, I hope the sunshine finds you today. :)
    MarX, PzTank, Delta09 and 6 others like this.
  17. Feb 20, 2023 at 4:51 AM
    308savage
    Adam
    East Tennessee
    Laser!
    First modification was adding what they call air assist. You basically blow air where the laser is hitting to help blow out dust/debris/smoke. It also helps to blow out any flames.
    Aquarium pump, some copper and silicone tubing, and a mount. I need to find a bigger drag chain and run the silicone tubing through it.
    Wadar, MarX, RustyGreen and 9 others like this.
  18. Feb 20, 2023 at 4:52 AM
    308savage
    Adam
    East Tennessee
    I bought some the other day to work with.
  19. Feb 20, 2023 at 4:57 AM
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    Good morning fellas, hope it was a great weekend for you. Bonus day for some, enjoy it if that’s you!
    Nice job! That’s what I’m trying to do with 3D maps. But on a Cricut, with card stock :anonymous:
    In my case it involves a lot of :frusty:
  20. Feb 20, 2023 at 6:13 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Morning all
    Have a great day
    MarX, RustyGreen, StayinStock and 5 others like this.
