Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Sep 12, 2023 at 11:02 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I think this might just be a dream.
    Glad to know your alive and doing the best you can!!:thumbsup::thumbsup::thumbsup:
    I can say i missed you! Plus everyone else!
  2. Sep 12, 2023 at 11:04 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    CPVC is notorious for getting brittle and then cracking if you mess with it. Flo-Gard CPVC is supposed to be better, but I won't use it. Been transitioning to PEX for the water lines and SCH40 PVC for the drain lines in my house. The old thin copper drain lines are starting to rot very quickly. They're close to 10 years over their expected life span of 50 years...
    NoOne, PzTank, mit88 and 5 others like this.
  3. Sep 12, 2023 at 11:05 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Just occasionally? :boink:
  4. Sep 12, 2023 at 11:08 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Rusty,
    I have seen 180 psi on farming wells, so 90 psi is probably fine
  5. Sep 12, 2023 at 11:16 AM
    Bivouac
    Not so much the pressure but what it is being pushed through
    Old PVC does get brittle!!
  6. Sep 12, 2023 at 11:16 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I grew up in town, don't know jack about farm stuff. :D
    NoOne, Delta09, Fargo Taco and 4 others like this.
  7. Sep 12, 2023 at 11:18 AM
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    Rusty suggested that earlier too. I gave up and called the pool place to send a maintenance guy.
  8. Sep 12, 2023 at 11:19 AM
    Bivouac
    Just what qualifies as a kitchen ?
    I have always had what I call a kitchen in the Shop.
  9. Sep 12, 2023 at 11:32 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yea, my neighbor has 180 psi and my house has 90 psi. I changed switches to 40-60, just because I don't need that pressure.
    Another reason is line length. Further you push fluid, the more pressure required, and 90's and Tee's take a bunch!
    mit88, Fargo Taco, Cwopinger and 3 others like this.
  10. Sep 12, 2023 at 11:34 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I have no idea how deep our current well is, we live on the top of a hill now. The well to the house is maybe 75'.
    I'll have to look and see if there are any papers that say anything about the well, the previous owner kept pretty good records and didn't take them when he left (passed away).
    80yotaguy, mit88, Fargo Taco and 6 others like this.
  11. Sep 12, 2023 at 11:39 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It also really,really matters where you take the pressure reading. At the well head? At the tank? Best place to take it is at the furthest device that uses water, for example a sink or a outside hose bib. It might be 60 psi at the tank and only 20 psi at the hose bib. Normal houses have 35-45 psi depending on where you take the pressure. 30 psi is minimum you should expect.
    NoOne, mit88, Fargo Taco and 4 others like this.
  12. Sep 12, 2023 at 11:39 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    All the usual amenities, I have seen apartments less well equipped. ;)
    I used to make pretty ambitious meals there, not so much anymore.
    NoOne, PzTank, Fargo Taco and 4 others like this.
  13. Sep 12, 2023 at 11:44 AM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    Chicken! :stirthepot:
    80yotaguy, NoOne, StayinStock and 4 others like this.
  14. Sep 12, 2023 at 11:55 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    Glad everything worked out for you. Welcome back Sir.
    My choice for the poll is: I don't know
    But I did think of it for sure. I even posted a line on April fool day spreading rumors of your returned :rofl:
  15. Sep 12, 2023 at 12:09 PM
    BussinGus
    No rust or corrosion anywhere I can see except the outside of the casting. This is the bore after a good soak in the cleaner. The pictures make it look a lot worse than it does in real life.
    The piston has a couple of tiny wear marks right at the skirt. This is the bigger one.
  16. Sep 12, 2023 at 12:22 PM
    mit88
    Planet earth
    :amen:, it's lively! :typing:
  17. Sep 12, 2023 at 12:37 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I must’ve missed it. :notsure:
    Things really perked up here today :burnrubber:
  18. Sep 12, 2023 at 12:48 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    All this high pressure well talk and here I am stuck with a 40/60 switch and I know damn well (pun intended) I'm not getting that outta my faucets. All the piping needs upgraded to 3/4 I imagine. Heck, even my cistern pump with a 30/40 has better pressure than the well... :annoyed:
  19. Sep 12, 2023 at 12:54 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    A 1/2" copper line comes up from the basement and serves everything, the switch is a 30/50. It all works good enough.
    Fortunately there is very little plumbing in the house, the water heater is located between the kitchen and BR, hot water only takes seconds to arrive at either.
  20. Sep 12, 2023 at 12:58 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I think my issue could be the old water softener. However funds are at an all time low and I just found more termite damage in the basement. Thought I had old damage, but there's some new that I hadn't seen before. Gotta call in the pros on this one I think :annoyed:
