Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Sep 19, 2020 at 11:02 AM
    #761
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Does "making things" count if I'm working on something for my Tacoma at my kitchen counter? :p
  2. Sep 19, 2020 at 12:39 PM
    #762
    Fargo Taco
    Fargo
    2019 TRD Pro
    Well that kind of sucked. I wanted to also do the TRD in charcoal to match the factory badge on the doors but after that I'm undetermined. o_O
    StayinStock and six5crèéd[OP] like this.
  3. Sep 19, 2020 at 2:08 PM
    #763
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Guy I bought this mower from gave me a spare engine, got the starter off of it and replaced mine today on the mower after the wife got back from hunting and took over the store.
    Tailgate tested on the back of the taco.
    Replaced the pump belt while I was under it.
    Had two standing by to test drive for me.
    DBCEB775-CBE2-418E-A6A3-43299E722734.jpg 2B298F55-3667-475B-BD7B-85B3424C39D2.jpg
    Went ahead and put the vacuum on and mowed the yard.
    9FEB3855-DC33-4F16-BD9C-163C6818FE29.jpg 3BBA2501-857D-4E79-8E09-5F922CCC61E9.jpg
    They drilled holes and stuff while I replaced starter. Made sure they both had safety glasses this time.
    31E5E9FE-8218-4B5C-8F93-1FC19372FC04.jpg 7C57BC50-22A4-4DE3-9EF0-2965A33E3149.jpg D8BEE796-F05E-4005-931D-817EFF919A6B.jpg DC1B3A4B-E0C7-4D0A-A79A-A83135AB2870.jpg
  4. Sep 19, 2020 at 2:17 PM
    #764
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Creed, it is awesome that you involve your kids in the shop! :thumbsup:
  5. Sep 19, 2020 at 2:35 PM
    #765
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Helps me with my patience, I don’t have much to begin with :rofl:
  6. Sep 19, 2020 at 2:44 PM
    #766
    Fargo Taco
    Fargo
    2019 TRD Pro
    Teaching my kid to drive reminded me just how short my fuse can be sometimes. :pout:
  7. Sep 19, 2020 at 4:55 PM
    #767
    Gregthespy
    Gregthespy Well-Known Member
    Greg
    Orlando
    2015 Blue Ribbon Metallic TRD Sport 4X4
    Welp, spent part of the day with my boy finishing up the last details of his go kart project.
    Runs and stops great when I tested it at full throttle range, but running into an issue setting the throttle low for him to get used to it. With the throttle restricted for him the centrifugal clutch won’t engage. Seems like all of these clutches engage at 2,000-2,600 RPM which is pretty high with the current gearing.
    This will be his first gas powered vehicle, so he’s slightly intimidated by it (which is a good thing in my book, I like the idea that he respects the speed/power).
    He said he might try it out tomorrow.
    :burnrubber:
  8. Sep 19, 2020 at 5:11 PM
    #768
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Good luck and be sure and get some pictures :thumbsup:
  9. Sep 19, 2020 at 6:07 PM
    #769
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Wonder why he wanted it milled like that kinda odd and doesn't leave much to put a connector on it unless he's going to weld some sort of new offset tube to it or something. That'll be a cool car once it's done especially if it's a way older caprice.
  10. Sep 19, 2020 at 6:14 PM
    #770
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    He was welding a short flange on it to change the angle because of the way it set :thumbsup:
  11. Sep 20, 2020 at 8:04 AM
    #771
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    The joys of owning your own business. Our cooler should be on 34, found out why it’s not :annoyed:
    Biscuits, Hobbs, StayinStock and 2 others like this.
  12. Sep 20, 2020 at 8:16 AM
    #772
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Mr. Creed:hattip:
    six5crèéd[OP] likes this.
  13. Sep 20, 2020 at 8:24 AM
    #773
    My Name is Rahl
    Uh...that's not supposed to do that...
  14. Sep 20, 2020 at 8:25 AM
    #774
    Hobbs
    Yep…
    It's always something... I hope you get it sorted out quickly.
  15. Sep 20, 2020 at 8:32 AM
    #775
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Odd place for an ice maker. Turn the heat up?
    -J
  16. Sep 20, 2020 at 8:40 AM
    #776
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Been using the torch to thaw it out but every time I turn it back on it freezes up again. The man that helped me install it a few months ago is on his way to check it out.
  17. Sep 20, 2020 at 9:01 AM
    #777
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Nice!
    Dats not good!
  18. Sep 20, 2020 at 9:05 AM
    #778
    Fargo Taco
    Fargo
    2019 TRD Pro
    It doesn't fix the underlying problem but short term can you put a fan on it to circulate some air to keep the ice from building up?
  19. Sep 20, 2020 at 9:15 AM
    #779
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I talked to my Refrigiration guy and he told me to turn it off and heat it with a torch to unthaw it. It’s gotten it a lot better and seems to be cooling. He should be here shortly, he lives about an hour away.
    From this.
    To this.
  20. Sep 20, 2020 at 12:40 PM
    #780
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    What would cause it to freeze like that? I know in automotive if we had an issue with the orifice tube or expansion valve it could cause some issues like that. Heard guys talk about this on home AC but never seen it. It's got my curiosity, but I don't know how they work really in this format.
