Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
Electrical outlet cover screws MUST be......
  1. Horizontal
    10.0%
  2. Vertical
    46.7%
  3. Not matching, ain't nobody got time for that
    16.7%
  4. Over torqued so the fake plastic cracks, then back off just a tad
    43.3%
Multiple votes are allowed.
  1. Oct 23, 2023 at 7:22 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Set a trap outside the house next to the vent and see what you get.
  2. Oct 23, 2023 at 9:28 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  3. Oct 23, 2023 at 9:55 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    Dunk trap is what I use in my shed. Sits on a 5 gallon bucket. Put a board up to it and fill the bucket half full with antifreeze. You can catch mice all winter long without having to re-set it.
  4. Oct 23, 2023 at 12:37 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So, once I looked at everything closer, there's a lot more small openings than you would think. The vent stack for the kitchen going through the floor had some good gaps. Sealed around with rodent spray foam. Makes sense they could be going from the attic all the way to the floor via pipe. Also need to pick up steel wool. The 1x6 planks have gaps that go over the rim joist. Sounds weird, but it's openings. Couple old electrical holes filled too.
  5. Oct 23, 2023 at 1:28 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    It is a nice day to get the wagon out...
    ...and I'm in the cellar. :(
    These bottles were between the furnace and wall - a space I never had been in, it was too small or I'm too large, take your pick. ;)
    Perhaps a long ago owner was a mountain moonshiner?
    Hauling the heat exchanger away to the metal pile.
  6. Oct 23, 2023 at 1:33 PM
    Kilo Charlie
    Kilo Charlie One flat foot on the Devil's wing
    Iowa
    2017 Inferno Off Road
    Were they full when you found them?!?!?
  7. Oct 23, 2023 at 1:37 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I can refill those 'shine bottles for ya :anonymous:
  8. Oct 23, 2023 at 1:44 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Dry... :pout:
  9. Oct 23, 2023 at 1:44 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Do you know a guy ??
  10. Oct 23, 2023 at 1:46 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Looking less bad, that peat moss has probably been down here since Bill Clinton was president.
  11. Oct 23, 2023 at 1:51 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    This is the view under half of the kitchen. :eek:
    Eons ago there must have been a trap door in the floor, you can see the remains of concrete steps.
    That rectangular hole in the upper right leads to the other half.
  12. Oct 23, 2023 at 1:52 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I may or may not be the guy... I mean yea I know a guy... :anonymous:
  13. Oct 23, 2023 at 2:14 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Next up on the fun project list:
    Remove this oil tank, I put it down here around 25 years ago but never got around to hooking it up.
  14. Oct 23, 2023 at 2:16 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    When we replace the oil furnace with a natural gas at our first house, the oil tank was drained and left in the corner. :D
  15. Oct 23, 2023 at 3:51 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Whilst dreading the oil tank I removed all this shale that was piled around down there.
    :militarypress:
  16. Oct 23, 2023 at 4:01 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Well, planning will only get you so far.
    :pout:
    Better get to it - find some wood.
    Add some skids.
    Attached with some "mending plates" with all the holes.
    Need a bit more to clear the tank bottom.
  17. Oct 23, 2023 at 4:03 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    That last board probably should’ve been an over rather than an under. This might get hung up in “the big pull”…
  18. Oct 23, 2023 at 4:07 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    They say "if you want to get ahead, get a hat"...
    I say "if I want to get something done, get the Ford".
    This tank doesn't know who it is dealing with...
    So there, goal for the day achieved.
    Boy my back hurts...
    I dragged it round the back of the house as a courtesy to the neighbors.
    Empty space! :taco:
    There is lots more work ahead, that tank was the worst bit.
  19. Oct 23, 2023 at 4:12 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Needed the height to clear the tank bottom. I thought about attaching the 2x4 in the tall direction but thought they might break off.
  20. Oct 23, 2023 at 4:24 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Bravo, @RustyGreen!
    And I thought I was doing good getting the patio stuff put away and the lawn mowed after work because we have rain coming and the temps are dropping. :laugh:
    Looks like there's snow in the forecast, too... :annoyed:
