Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
Electrical outlet cover screws MUST be......
  1. Horizontal
    10.7%
  2. Vertical
    46.4%
  3. Not matching, ain't nobody got time for that
    17.9%
  4. Over torqued so the fake plastic cracks, then back off just a tad
    42.9%
Multiple votes are allowed.
  1. Oct 30, 2023 at 4:57 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    A lot of the people who came by our old place, the police were looking for them :rofl:
  2. Oct 30, 2023 at 5:05 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    The riff-raff in that trailer is gone finally. The drug dealer moved out and Randy (dubbed Crackhead Randy) passed away a couple months ago. They finally hauled away his truck and they're going to pull the trailer out of there. I assume the property owner is gonna build a house there. Everything is already permitted and has a new sand mound septic system.
    Squirt, 80yotaguy, RustyGreen and 7 others like this.
  3. Oct 30, 2023 at 5:08 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Paradise right there! Congrats to you and the family!!
    80yotaguy, mit88, RustyGreen and 6 others like this.
  4. Oct 30, 2023 at 5:10 AM
    Gen1TacoLady
    Gen1TacoLady Local favorite
    Pond Princess
    Washington County, MD
    '95 Red Tacoma
    :hattip:
    RustyGreen, Cwopinger, PzTank and 4 others like this.
  5. Oct 30, 2023 at 5:12 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Thanks, it's such a blessing :hattip:
    NoOne, 308savage, RustyGreen and 6 others like this.
  6. Oct 30, 2023 at 8:10 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Question for the plumbers in the shop:
    Recently replaced the supply side of our plumbing with pex. It is all fastened to the joists in the crawlspace (about 18 inches above the dirt floor of said crawlspace). Should I buy the foam pipe insulation and put it on? Could I cause any problems by doing so?
    koditten, RustyGreen, hiPSI and 4 others like this.
  7. Oct 30, 2023 at 8:19 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Trying to put these .020” deep grooves in tool steel.
    Almost got one done :bananadead:
    NoOne, Cwopinger, RustyGreen and 6 others like this.
  8. Oct 30, 2023 at 8:20 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Are you wanting to do it because of possible freezing? I'm not a plumber but I don't see what it would hurt.
  9. Oct 30, 2023 at 8:20 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Wouldn't hurt. PEX will freeze, but shouldn't bust like copper or PVC.
    NoOne, Cwopinger, RustyGreen and 5 others like this.
  10. Oct 30, 2023 at 8:56 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    In Nebraska? Probably need to. And be sure your house is closed up underneath during the winter.
    NoOne, Cwopinger, RustyGreen and 2 others like this.
  11. Oct 30, 2023 at 9:03 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Which reminds me I need to close the vents on ours, supposed to be getting cool this week.
    NoOne, Cwopinger, RustyGreen and 3 others like this.
  12. Oct 30, 2023 at 9:25 AM
    Evostaco
    Nebraska
    Yea, just for freeze protection, I know nothing about Plumbing either
  13. Oct 30, 2023 at 9:26 AM
    Evostaco
    Nebraska
    Do I do the hot and cold? Or what?
  14. Oct 30, 2023 at 9:29 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I'd do all of it if possible, or let you faucets drip on really cold nights.
  15. Oct 30, 2023 at 3:44 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    In Nebraska yes. However I am a nerd so I can't quit there.
    Avg water temp out of the ground is 58 degrees all year long and that is for water that moves through the pipes. If your average air temp is 25 degrees for several days, then, no matter how much insulation you have your pipe will freeze if you don't run water a bit like a trickle. What insulation will do is keep that 58 degrees and protect it for longer before it freezes. Key is a trickle at your furthest sink all night.
  16. Oct 30, 2023 at 5:23 PM
    Evostaco
    Nebraska
    Appreciate the science !
  17. Oct 30, 2023 at 6:05 PM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    It only gets better from here out.
    Love rual life .
  18. Oct 30, 2023 at 6:15 PM
    Jtcmedic
    Jeff
    Florida
    2014 prerunner sr5
    Well did an experiment with the venison. Never have we hung one. Always did ice in cooler, drain water every day and repacked for 7 day, processed day 7 never had a problem. Now with the cooler we hung it at 35degree for 10 days. Came to 10 after reading a couple articles said it was the sweet spot. Well we processed the buck this morning and did grinds, and had to make a burger to test for science, oh my:jellydance::kona: the venison tasted so clean and almost like grass fed beef but richer. Was really tasty.
    BussinGus, 308savage, NoOne and 12 others like this.
  19. Oct 30, 2023 at 6:33 PM
    Hunterdc1
    Hunterdc1 Propane and Propane Accessories
    Brrrrother
    No I will not press 1 for English
    13 8 lug ltz gasser
    Rip to crackhead Randy
    BussinGus, NoOne, RustyGreen and 8 others like this.
  20. Oct 30, 2023 at 6:52 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Down side - It finally stopped snowing so now I have to go shovel.
    Up side - I finally get to try out the new snow boots I bought in April. :laugh:
