Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Nov 13, 2023 at 3:12 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I would think that opens up liability issues for the first responding agency…
    All things drone according to the FAA:
    https://www.faa.gov/uas
  2. Nov 13, 2023 at 3:12 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Nothing like a good Rat pie that Grandma made.
    i loved them having no idea just what kind of meat was in them.
  3. Nov 13, 2023 at 3:13 PM
    PzTank
    Above the Notches
    That’s terrific! Congratulations :thumbsup:
  4. Nov 13, 2023 at 3:18 PM
    Bivouac
    Does that bring back the nightmares .
    Installing AC ducts in dwellings with Hot water heat.
    Not for the faint of heart. If i recall Shane also did this type of work.
  5. Nov 13, 2023 at 3:32 PM
    Bivouac
    Well woke up to another loud crash.
    It is bad enough I only sleep for brief periods until the evil Cat is making noise about something.
    My try at cat proofing did not work . It dug under the sheet metal and clawed through the insulation panels..
    Yes the loud crash was my Microwave bouncing off the floor . My best guess the Cat fell behind the Microwave in the panic of being trapped pushed the Micro Wave off the counter. Then things went Dark.
    No sense looking for a used one. I can use the one from out in the shop even though the wattage is much lower.
    How can people afford all this damage . Buying Rat Chow would be cheaper.
  6. Nov 13, 2023 at 3:58 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :eek:
  7. Nov 13, 2023 at 4:01 PM
    Bivouac
    All the K-9`s I had my whole life did not destroy this much $$$$ .
  8. Nov 13, 2023 at 4:03 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Jebus :rofl:
    All 4 of my cats aren't nearly this destructive. No rug is safe in the house from being scratched, but my microwave stays intact :rofl:
  9. Nov 13, 2023 at 4:18 PM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    For my department we have to have are part 107 so they sponsor it and I went.
  10. Nov 13, 2023 at 4:19 PM
    Jtcmedic
    Jeff
    Florida
    2014 prerunner sr5
    Same for my department.
  11. Nov 13, 2023 at 4:23 PM
    Jtcmedic
    Jeff
    Florida
    2014 prerunner sr5
  12. Nov 13, 2023 at 4:31 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The one on the upper right is the one I just hooked up, the whole shebang is straight, I was bent over standing on the hill.
    Starting to look like a furnace that might stand a chance of working. :notsure:
    Enough for the day, I'm going to go sit in the chair with Daisy the tough cat. :)
  13. Nov 13, 2023 at 4:34 PM
    Jtcmedic
    Jeff
    Florida
    2014 prerunner sr5
    Found a truck I don’t want to ride but do great work IMG_7262.jpgwas first time seeing this
  14. Nov 13, 2023 at 4:37 PM
    PzTank
    Above the Notches
    I knew it! You’re the world famous, former governor Skink. From the Carl Haisson’s novels…
    https://en.m.wikipedia.org/wiki/Clinton_Tyree
  15. Nov 13, 2023 at 4:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Aren't those pan head?
  16. Nov 13, 2023 at 4:47 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Correct, I should have said slotted.
    What a p-i-t-a, I've removed about 100 of the damn things... :annoyed:
    Just some of them -- even being notoriously cheap I'm tossing them with great satisfaction.
    mit88, 80yotaguy, Jtcmedic and 6 others like this.
  17. Nov 13, 2023 at 5:00 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    they were probably put in by hand and pilot drilled with a hand drill given the age of the old system
    mit88, six5crèéd[OP], NoOne and 3 others like this.
  18. Nov 13, 2023 at 5:01 PM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    I said that in jest mostly because of the python problem happening in south and central Florida. They've killed them in the county I live in recently. And also because that's a huge black bear.
    mit88, six5crèéd[OP], NoOne and 5 others like this.
  19. Nov 13, 2023 at 5:28 PM
    Bivouac
    just shared recipes of Roadkill we have in Common.
    When we crossed paths when I was working in Florida years back
  20. Nov 13, 2023 at 5:44 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Alright, bench build update:
    Got skirt cut and all the 90 bracing too. Here is a pic of the test fit before I screw and glue tomorrow night. Legs are not ready for a pic yet but maybe by the weekend. This is getting close to chair building territory...
    Vmax88, 80yotaguy, Jtcmedic and 12 others like this.
