Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Dec 16, 2023 at 7:01 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I probably should edit that. I vacation in Ft. Mill, but live in Michigan.
  2. Dec 16, 2023 at 7:02 PM
    koditten
    Kirk
    Central Michigan
    I'm wondering if it because of that solar flare from the sun. It was predicted it could cause communication issues.
  3. Dec 16, 2023 at 7:03 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    That's odd, the doctor told my parents I'd have that problem for life :rofl:
  4. Dec 17, 2023 at 2:45 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Morning all still here not floating away. Have a great day
  5. Dec 17, 2023 at 2:56 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I use my 10" miter saw with a 60 tooth blade... :anonymous:
  6. Dec 17, 2023 at 3:03 AM
    Tacoma Mike
    Southern Maine
    if you only have those tools it’s gonna suck every which way but I would try this.
    Make a jig out of flat steel. Drill a hole in the flat steel as a centering hole and try a hole saw.
    Once you get the first one done then it’s just swapping work material.
    Sending it out is going to cost you a bundle.
    The only issue is the lack of material at the start of drilling.
    Outside of that I don’t have a clue..
  7. Dec 17, 2023 at 3:10 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Good morning all :hattip:
    I hope you have a pleasant Sunday.
  8. Dec 17, 2023 at 3:50 AM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    you know.. you can turn all that stuff off right?
  9. Dec 17, 2023 at 4:15 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Good morning everyone, have a great, safe and blessed day. :hattip:
  10. Dec 17, 2023 at 5:30 AM
    BananaMan
    Speaking of rv's and weather incoming. Time to tear this thing down to the frame before it's buried in snow.
  11. Dec 17, 2023 at 8:09 AM
    BananaMan
    2 1/2 hour in update. Wiring stripped, appliances removed, siding off, and down she goes. Now to separate the insulation from the wood and start burning.
  12. Dec 17, 2023 at 10:39 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    The weather here is confusing our trees. They are trying to grow leaves...20231217_111753.jpg
  13. Dec 17, 2023 at 11:03 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :annoyed::annoyed:that happened to my apple trees early this year
  14. Dec 17, 2023 at 11:13 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yea walking out to get the mail yesterday and there's buds on my maple trees... o_O
    Edit: I also got some bulb plants trying to peek through...
  15. Dec 17, 2023 at 11:27 AM
    BananaMan
    I've filled the fire ring twice now, pretty good size pile of ashes behind it. Doesn't feel like I'm making much progress on this camper demo :eek:
  16. Dec 17, 2023 at 11:45 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Hate to say it but your right. Toss a match on the whole pile.
    :nuclear:
    Gone in 60 seconds.
  17. Dec 17, 2023 at 11:46 AM
    koditten
    Kirk
    Central Michigan
    Just need to call the squad over for a kegger. They'll feed the fire for you.
  18. Dec 17, 2023 at 11:53 AM
    Evostaco
    Nebraska
    And in April when they should be coming alive it will likely be in the negative temps..
  19. Dec 17, 2023 at 11:55 AM
    koditten
    Kirk
    Central Michigan
    Why aren't you using a chain saw?
  20. Dec 17, 2023 at 11:58 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Seems the way the climate has been shifting. My bulb plants have been doing crappy the past couple of years being here... :annoyed:
