Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Jan 8, 2024 at 10:03 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    One extension cord away for maintenance, correct?
  2. Jan 8, 2024 at 10:07 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
  3. Jan 8, 2024 at 10:12 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    It would be great if they supplied one of those with an end that you could take off and put back on. The size hole that you need to drill to get that cable in/out of a building is a PITA.
  4. Jan 8, 2024 at 10:14 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Well wife said I bought a new toilet bowl brush. Says what happened to the handle I thought it would be longer :rofl:. Then she says here's the owners man
    Inside the garage.
    RustyGreen and six5crèéd[OP] like this.
  5. Jan 8, 2024 at 10:16 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Agreed. It's the same way with the camera system I put in, the plug is twice as big as the cable. Time to break out the caulk.
  6. Jan 8, 2024 at 10:19 AM
    ACEkraut
    Aaron
    Durham, Maine
    I would use a hole saw to cut an oversized hole. Save the hole plug and cut out a small circle on the edge of it. Then run the cable through the big hole and put the hole plug in with the small hole just around the cable. Seal and caulk and you are good to go. Did I explain that well enough? Need a drawing?
    mit88, PzTank, Bivouac and 5 others like this.
  7. Jan 8, 2024 at 10:36 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  8. Jan 8, 2024 at 10:41 AM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    When I dug my trench, I ran 2 conduits and string in them so when I pull something through the string assists and another string replaces the original one... hopefully that makes sense. Work smarter not harder.
    PzTank, Bivouac, RustyGreen and 2 others like this.
  9. Jan 8, 2024 at 10:42 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I know a guy who has one for his skidsteer but I don't know where the septic tank lines are for my shop. I know where the tank is but not the lines. They must be deep though cause you can't see green strips of grass. I'll get Cole to help me with a shovel, I may run it in some plastic pipe to protect it a little.
    PzTank, Hunterdc1, 80yotaguy and 3 others like this.
  10. Jan 8, 2024 at 10:43 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That's a great idea!
  11. Jan 8, 2024 at 10:45 AM
    Fargo Taco
    Fargo
    2019 TRD Pro
  12. Jan 8, 2024 at 10:45 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I had an idea. I’ll get it installed when I get home.
    mit88, 308savage, PzTank and 7 others like this.
  13. Jan 8, 2024 at 10:46 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :fistbump:
  14. Jan 8, 2024 at 10:56 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Glad I didn’t drive the Honda today :anonymous:
    mit88, PzTank, Gen1TacoLady and 8 others like this.
  15. Jan 8, 2024 at 11:02 AM
    Fargo Taco
    Fargo
    2019 TRD Pro
    That fake wood grained steel is getting more and more realistic every day.
  16. Jan 8, 2024 at 11:11 AM
    ACEkraut
    Aaron
    Durham, Maine
    Yeah, my hand drawing was so bad that I threw it away. That looks much better and I must have done a decent job explaining it as your CAD drawing matched the image in my head.
    mit88, Bivouac, RustyGreen and 2 others like this.
  17. Jan 8, 2024 at 11:41 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Lacking a trencher, last time I needed to bury a line. I used one of tines on the box blade set at it's lowest level to dig a narrow trench in the dirt. It didn't get it very deep, but it was deep enough for my needs.
  18. Jan 8, 2024 at 11:51 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Dowsing rods will tell you where your septic lines run you think about trying that?
  19. Jan 8, 2024 at 2:12 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    1st Op on this last part number is about done.. deburring now then onto Op2. This one wasn't nearly as bad as the other part numbers. Program ran great with hardly any adjustments needed this go around.
  20. Jan 8, 2024 at 3:06 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
