Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
Electrical outlet cover screws MUST be......
  1. Horizontal
    7.7%
  2. Vertical
    42.3%
  3. Not matching, ain't nobody got time for that
    19.2%
  4. Over torqued so the fake plastic cracks, then back off just a tad
    46.2%
Multiple votes are allowed.
  1. Feb 2, 2024 at 8:41 AM
    Hunterdc1
    Hunterdc1 Propane and Propane Accessories
    Brrrrother
    No I will not press 1 for English
    13 8 lug ltz gasser
    Gun room at the Biltmore is legendary. Pretty amazing property. I just marvel at all the handmade trim work all over the house. I'd like to visit in all 4 seasons, I think we've been in spring and fall.
  2. Feb 2, 2024 at 8:52 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I gotta do this!
  3. Feb 2, 2024 at 9:01 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Pending another plane issue, in 13 hours we'll be boarding for, on paper, an 11 hour flight.
  4. Feb 2, 2024 at 9:18 AM
    Hunterdc1
    Brrrrother
    13 8 lug ltz gasser
    Let us know what it's like flying into the future.
  5. Feb 2, 2024 at 9:18 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    :eek:
    Seems like you flew out there yesterday…
    Good luck on the return :plane:
    308savage, RustyGreen, mit88 and 3 others like this.
  6. Feb 2, 2024 at 9:19 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Wife was cooking dinner Wednesday night and went to grab a bowl from under the sink. Goes, "Uh, I think the sink is leaking?" Everything's wet under there so I pull everything out, throw a towel down and grab a flashlight. Leaking from the disposal, from the casing, right next to where the cord goes in for power. Welp, honey, how long till dinner is done? "about 30-45 minutes." I'll be back...
    Came home, ate dinner than fought the old one out (I have no plumbing skills to speak of) spent 30 minutes scraping the old seal off, put in a new seal and Insinkerator Quiet Model. 9 year warranty and it's pretty dang quiet. Went from an old one of the same brand with 1/2 HP to the new one with 3/4 HP. POWER! :rofl: New one went in fairly quick although it's tough juggling the thing in one hand while trying to turn the flange with my other. Luckily the new elbow lined up PERFECTLY to the existing plumbing so I didn't even have to fuss with cutting pipe. $300 I hadn't planned on spending, but it's there and will be there for a good long time. Now I just have to refinish the inside of the dang cabinet.... :bananadead:
  7. Feb 2, 2024 at 9:21 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Look at the tensile strength of this snow!!
    Vmax88, 80yotaguy, BussinGus and 9 others like this.
  8. Feb 2, 2024 at 9:43 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Same here, this one is a Reid trailer and he has the title.
    RustyGreen[QUOTED] and mit88 like this.
  9. Feb 2, 2024 at 10:26 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I'll be sure to rake the living room floor and put the axles back under it.
    :fistbump:
    80yotaguy, BussinGus, Tiedie and 5 others like this.
  10. Feb 2, 2024 at 10:38 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    :thumbsup: At least you didn't have to spend the in home service cost for the plumber.
  11. Feb 2, 2024 at 11:03 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Safe travels :plane:
    :pray::pray:
    :fingerscrossed::fingerscrossed:
  12. Feb 2, 2024 at 11:06 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Yesterdays good deal added to the supply. :rolleyes:
    If it was 30 degrees warmer I might actually apply the wax to the truck -- but probably not...
    80yotaguy, PzTank, BussinGus and 8 others like this.
  13. Feb 2, 2024 at 11:29 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Don’t forget to air up the tars so she sits level :)
    Slashaar, PzTank, BussinGus and 7 others like this.
  14. Feb 2, 2024 at 11:38 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    yep, even small utility trailers are expensive and almost double price from Few years ago
  15. Feb 2, 2024 at 11:57 AM
    cory02taco
    Cory
    Maine
    Those cheapie ones from Lowe’s have gone nuts. A 6ish by 10 one was a little over $3000 when I looked at it a few weeks ago!
  16. Feb 2, 2024 at 1:01 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Ironically I had a garborator under the sink when I first moved in my house. Un-hooked that thing ASAP. It was locked up anyways so there was no value to it. It was completely removed when I replaced the sink.
  17. Feb 2, 2024 at 1:21 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I edited last post. To went here today.
    Gotta check on those passes they expire sometime.
  18. Feb 2, 2024 at 1:30 PM
    koditten
    Kirk
    Central Michigan
    I was always told the best auto wax was the one you actually used...
    80yotaguy, PzTank, BussinGus and 4 others like this.
  19. Feb 2, 2024 at 1:30 PM
    koditten
    Kirk
    Central Michigan
    Please do. It's warming up and we want to get out more!
    RustyGreen and six5crèéd[OP] like this.
  20. Feb 2, 2024 at 1:40 PM
    Tiedie
    David
    WFOY
    Ok just looked and good from Jan. 8 - March 14, 2024 good for the grounds and some off house and annual pass.
    Keep up with me and I can get them to you. Or meet up at the front gate entrance. A date has to be set up.
