Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Feb 21, 2024 at 9:58 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Looks like a maze. "walk through the building without going to the same place twice" :smash:
    ndoldman59, PzTank, KRAMERICA and 3 others like this.
  2. Feb 21, 2024 at 10:10 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Kind of what I was going for.
    When I number plans, I try to never leave you at a dead end. I want there to be some kind of logic that will lead you to the room you're looking for.
    Sometimes that's not exactly easy to do.
    ndoldman59, PzTank, 80yotaguy and 4 others like this.
  3. Feb 21, 2024 at 10:36 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I thought that was the path the robot vacuum would take.
    :anonymous:
    -J
    PzTank, BussinGus, KRAMERICA and 4 others like this.
  4. Feb 21, 2024 at 10:47 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  5. Feb 21, 2024 at 11:03 AM
    Fargo Taco
    Fargo
    2019 TRD Pro
    My dog couldn't care less about our Roomba.
    ndoldman59, PzTank, BussinGus and 7 others like this.
  6. Feb 21, 2024 at 11:05 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :D
  7. Feb 21, 2024 at 12:19 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Perfection is realizing that no one is perfect. Acceptance is realizing that everyone makes mistakes, and that is ok. Striving for perfection is ok, as long as you realize that you will never achieve it. Acceptance will give you peace of mind. Everyone makes mistakes. I try to hold myself accountable and not make mistakes but accept that part of life is learning from mistakes. Only you know what is inside of you and what you need. I would encourage you to have those "tough" conversations. And I would also encourage you to have someone to act as a sounding board after the "tough" conversations are over. We rarely have insight regarding ourselves, even if we are good at "seeing" and understanding others. My favorite advice to give is this:
    Often people in your life will criticize you and beat you down. Don't be one of them.
    scocar, ndoldman59, zimmmtaco and 8 others like this.
  8. Feb 21, 2024 at 12:23 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  9. Feb 21, 2024 at 12:56 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Lots of interestingly labeled rooms "headhouse" o_O & "gender neutral toilet" :pout: stand out.
    Then I found this... :eek:
    ndoldman59, Vmax88, PzTank and 9 others like this.
  10. Feb 21, 2024 at 1:04 PM
    koditten
    Kirk
    Central Michigan
    Is the Lactation room labeled #80085?
    ndoldman59, PzTank, 80yotaguy and 8 others like this.
  11. Feb 21, 2024 at 1:05 PM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    Dang! Your found @Fargo Taco 's office!
  12. Feb 21, 2024 at 1:05 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So, I hate to break this to you, but this an illegal tap and a fire hazard along with completely against code. They used UF cable so that's somewhat good. Only solution to this is to run a new line from your main panel to the building. I understand this has been like this for a long time, but the corrosion going on. There is no cheap fix to this and be somewhat proper.
  13. Feb 21, 2024 at 1:09 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    And yous guys call me dirty! I didn't even see that one :rofl:
    ndoldman59, PzTank, 80yotaguy and 6 others like this.
  14. Feb 21, 2024 at 1:11 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I figured you would be along shortly... :rofl:
    :fistbump:
    ndoldman59, PzTank, BussinGus and 6 others like this.
  15. Feb 21, 2024 at 1:11 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Shortly is right... :pout:
    PzTank, 80yotaguy, BussinGus and 5 others like this.
  16. Feb 21, 2024 at 1:15 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
  17. Feb 21, 2024 at 1:16 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    ... move over ...
    :pout::pout:
  18. Feb 21, 2024 at 1:17 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Go check out the "Breeding Laboratory Non-Clean" and you might end up with more. :D
  19. Feb 21, 2024 at 1:18 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Let's just hope he's not the next "test subject" o_O
  20. Feb 21, 2024 at 1:24 PM
    SACTOWN
    Greg
    :rofl::rofl::rofl::rofl:
