Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Feb 21, 2024 at 1:28 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    A headhouse is the room you go into before you go into a greenhouse. I'm sure there's a reason for the name but I've never cared to investigate.
    AKA - single user bathroom.
    Or, if you're adventurous:
    Unfortunately that doesn't fit our standard.
    I should change it.
    I'm more likely to be found in the new 1200 square foot smoker that's in the building that'll be finished soon. :laugh:
    ndoldman59, PzTank, 308savage and 7 others like this.
  2. Feb 21, 2024 at 1:34 PM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    I mean yes, but he could just get a small outdoor sub panel and separate out the two loads, assuming the feed from the main panel is the correct size.
  3. Feb 21, 2024 at 1:37 PM
    cory02taco
    Cory
    Maine
    8008135 ?
  4. Feb 21, 2024 at 1:43 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    no, still lacking the Neutral line and the Lines are probably not large enough for the 15 amps plus the load of the AC unit
  5. Feb 21, 2024 at 1:52 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    It's not in the budget right now to redo the whole system, but I've got some extra rebar and wire in the garage from a previous project. I think I can use that to create a new ground below this box, and I can add one in the barn where the wire comes out. I took some other pics so y'all can see what I'm working with. There's plenty of excess at the barn end, so I'm going to try and pull a few inches back toward the house after the next rain. I'm sure it's not to code and I didn't do it!:notsure:
    The only work I've done out here is to swap out the dirt dobber encrusted outlet for a new one. The only thing plugged in out here is a charger for my generator.
    ndoldman59, PzTank, wilcam47 and 2 others like this.
  6. Feb 21, 2024 at 2:03 PM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Best option:
    run a new 20A 12/2 line from the panel and stub out next to the AC line, put a duplex box with an outdoor GFCI outlet there then run from that to the shed, then clean-up the wiring in the shed
  7. Feb 21, 2024 at 2:04 PM
    cory02taco
    Cory
    Maine
    I don’t know how I missed the neutral, but you’re right on there.
  8. Feb 21, 2024 at 2:14 PM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    After noon all
    Late to the shop today
    @six5crèéd have the talk, I have them regularly with my son, and one way with my dad now as he passed 20 yr ago, we were close and regularly had good talks more after I moved out we used to grab a burger and chat. Then when i was in need of it most he was gone. It has been tough but I am trying to be the best I can to my 2 kids and my wife.
  9. Feb 21, 2024 at 2:39 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Ok, there's so much here I don't even know where to start. Honestly this all needs ripped out. I know it isn't in the budget, but wow! o_O
  10. Feb 21, 2024 at 2:48 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I was kind of surprised the VA inspector didn't flag it. I suppose he didn't care being it went to an out building.
    Now I'm confused I though I was short the Ground wire, not the Neutral wire...:notsure:
  11. Feb 21, 2024 at 2:50 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Some day it will get ripped out for a proper setup, today I'm just concerned with making sure that shorting wire doesn't catch the house on fire.
  12. Feb 21, 2024 at 2:54 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    You have a neutral. See the white wire that is connected to a bar with the strands (and the ground wire wrapped around). Those twist of aluminum wire go back to the main which likely has grounds and neutrals bonded.
    six5crèéd[OP] and RustyGreen like this.
  13. Feb 21, 2024 at 2:55 PM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    most outdoor 240V AC/Heat Pump are 2 hot legs (120V ea) and a ground (newer inverters might have neutrals, IDK)
    who ever added the line out to the shed did an illegal bootstrap of the neutral to ground to make it work so a AC repair tech could get a shock touching the frame of the AC unit as it is now
  14. Feb 21, 2024 at 3:07 PM
    cory02taco
    Cory
    Maine
    I guess after thinking a bit that’s the biggest issue, the barn receptacle. IF that a/c unit is straight 240, a guy could just delete that receptacle circuit and be fine. No neutral needed. Then like you said earlier, add a separate 120v gfci to pick up the a/c service receptacle, daisy it to the barn and be fine.
  15. Feb 21, 2024 at 3:11 PM
    cory02taco
    Cory
    Maine
    He’s missing a dedicated neutral from the panel. The bare aluminum shouldn’t carry current.
  16. Feb 21, 2024 at 3:14 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    The bare aluminum is attached to the neutral bus in the panel, I almost bet on it.
  17. Feb 21, 2024 at 3:21 PM
    cory02taco
    Cory
    Maine
    0% of the time you are allowed to run a bare conductor as a neutral conductor. I agree with you that it is acting as a neutral in this configuration because the receptacle load (120v) needs a neutral, therefore current can flow on that bare aluminum, which isn’t great. A dedicated neutral from the panel (white insulated conductor) as Craig pointed out is missing. Like I mentioned earlier if you were to delete the 120v load on that circuit, you wouldn’t need a neutral. Just 2 hots and a ground.
  18. Feb 21, 2024 at 3:25 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I guess you explained it better what I was trying to say :laugh:
    Nothing is done right here so I am betting it's not run like it's supposed to.
  19. Feb 21, 2024 at 3:28 PM
    cory02taco
    Cory
    Maine
    I’ll take that as a compliment I suck at explaining things! Hard to say what’s in the mind of some of these installers sometimes. I hope @KRAMERICA gets it sorted!
  20. Feb 21, 2024 at 3:29 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I've been up since 2am so words are not my strong point at this point in making a point right now. :rofl:
