Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. May 29, 2024 at 5:10 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Wrong gas piping too! :facepalm:
  2. May 29, 2024 at 5:12 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    This guy had the same idea too o_O
    https://www.reddit.com/r/Decks/s/suGlUUj4Xh
  3. May 29, 2024 at 5:18 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  4. May 29, 2024 at 5:21 AM
    wilcam47
    Will
    Bourbon state
    :eek:o_Oif you plan on putting a pool up there you will need more posts
    :anonymous:
    o_Oo_Oo_O
  5. May 29, 2024 at 5:39 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I heard it was the bruncle…
  6. May 29, 2024 at 5:41 AM
    wilcam47
    Will
    Bourbon state
    :wink:
  7. May 29, 2024 at 5:42 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Or the cusband...
  8. May 29, 2024 at 5:45 AM
    PzTank
    Above the Notches
    Legit Overhead Door question- in a snowy climate, would you consider steel or fiberglass for a large, 16’ garage door? Either will be on an opener so weight’s not an issue. I’m more concerned about rust and any other considerations you might come up with. Thanks!
  9. May 29, 2024 at 5:48 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    We got both of those here in Pennsylvania... :anonymous:
  10. May 29, 2024 at 5:49 AM
    wilcam47
    Will
    Bourbon state
    Which ever is insulated?i dunno...but a house we rented in Idaho had aluminum panels steel frame. But was uninsulated..was real cold in garage.
  11. May 29, 2024 at 5:49 AM
    wilcam47
    Will
    Bourbon state
    Prob more here
  12. May 29, 2024 at 5:53 AM
    PzTank
    Above the Notches
    Good point, this is an unheated Carraige House. I wasn’t thinking of insulated because it would be the only component in the whole building that would be :rofl:
  13. May 29, 2024 at 5:54 AM
    wilcam47
    Will
    Bourbon state
    :rofl:so that wouldnt matter then:rofl::rofl:
  14. May 29, 2024 at 5:55 AM
    wilcam47
    Will
    Bourbon state
    I think the aluminum would be lighter. Less work for the opener over time
  15. May 29, 2024 at 5:56 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Clopay garage door's they have insulation ones. Most garage door manufacturer's make insulated door panels. Just get the most insulated one you can afford and if you want to put more in the panel then home depot has the sheets for you.
  16. May 29, 2024 at 6:00 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I'd go with whichever is cheapest, either should hold up well.
  17. May 29, 2024 at 7:24 AM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    Ours are insulated aluminum.
    Edit: I see you don't need insulation. I'd be concerned about rust with steel, especially if salt is afoot. :bananadead:
  18. May 29, 2024 at 7:48 AM
    PzTank
    Above the Notches
    Yeah, that’s a concern. It’s a north facing door we clean off completely but even then, dents and scratches take their toll.
  19. May 29, 2024 at 7:59 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Insulated is a better built door. Much more resistant to dents. That's what I went with on my garage, albeit it's only 9' wide and 6'9" tall.
  20. May 29, 2024 at 8:07 AM
    PzTank
    Above the Notches
    :hattip:
    Steel?
