Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
Electrical outlet cover screws MUST be......
  1. Horizontal
    10.7%
  2. Vertical
    46.4%
  3. Not matching, ain't nobody got time for that
    17.9%
  4. Over torqued so the fake plastic cracks, then back off just a tad
    42.9%
Multiple votes are allowed.
  1. Jun 20, 2024 at 1:17 PM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    Mine's a Kioti as well, it's one size down from yours I think. It's a 2008 with 900 hours. The first or second year the horn quit. At the time, my secretary's husband worked at a car wreckers and gave me one off a truck. I hate to say it, but that's all it's needed outside of routine maintenance.
    I compared the Kioti and Kubota pretty closely as well, and came to the same conclusion as you did. Better built for less money. Zero regrets.
  2. Jun 20, 2024 at 1:20 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    :hattip:
  3. Jun 20, 2024 at 1:50 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    My current mower is 17yo and I'm planning on giving it to my kid when I buy the acre next door. I want something a little beefier (and newer) and I'll be mowing 2 acres total. I do not want a zero turn. This was on sale for Father's Day for $2699 so I figure this fall it may go on sale again. :notsure:
    Anyhow, any opinions? Pros? Cons? Suggestions? Staying under $3k would not only make me happy, but it would also make her less unhappy. :laugh:
    https://www.tractorsupply.com/tsc/p...-fr-engine-hydrostatic-transmission-960430342
    :popcorn:
  4. Jun 20, 2024 at 2:07 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    My opinion if you’re cutting more than an acre of grass, you’ll want something with a wider deck. Maybe a 54” or 60”, with a 46” deck I think you’d be out there all day.
  5. Jun 20, 2024 at 2:15 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I have cub cadet 54"
  6. Jun 20, 2024 at 2:22 PM
    wilcam47
    Will
    Bourbon state
    If they can pay for gas...they prob can afford that bill. Still a lot of money though
  7. Jun 20, 2024 at 2:32 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I get that, and I appreciate it, but I love to mow so I don't mind it taking awhile. And I'm considering mowing the new acre a little taller and possibly just mowing it evey other time.
  8. Jun 20, 2024 at 3:10 PM
    BussinGus
    You may be able to get it at that price off sale of you talk to the manager. Mention you saw it for that price and you'd rather not wait for the next sale, and they might go for it.
    Hydrostatic trans for sure. Don't leave home without it.
    Some manufacturers will ballpark acres per hour the machine will cut. You should take it with a grain of salt, but it will give you an idea. I'm guessing 2 acres @ 5 ish mph will take you about 2.5 hours with minimal trees and terrain.
    I know you said you don't want one, but, if you have a lot of trees or other obstacles, I would seriously consider a zero turn. It'll change your life.
    I would look at the spindles, deck linkage, and other maintenance items to see how beefy they are and if they are easy to grease, adjust, clean, remove, etc. Belly mounted decks are a pita to clean and service blades, but I think they're all pretty equal in that respect.
    The reinforced deck perimeter is a good idea if done right. I did that to one of my previous mowers after bending the stamped deck into the blade from rubbing along a retaining wall.
    FWIW, my mower has a different Kawasaki engine, but knock on wood (again) it's been a great engine.
    Something that's handy for me is the way the deck height works. I have a pedal that when pressed raises and locks the deck for driving around when not mowing. When I am mowing, I can press that pedal to raise the deck 2-3 inches without it locking if there's a high spot I don't want to scalp, rock, child, etc. Long way of saying, if the deck is easy to raise and lower on the fly, you may find it helpful.
    I'll stop rambling now. :anonymous:
  9. Jun 20, 2024 at 3:16 PM
    BussinGus
    Treated myself today. :)
    I have a heck of a time seeing while welding so I figured I'd try something different. :notsure:
  10. Jun 20, 2024 at 4:14 PM
    Tacoma Mike
    Southern Maine
  11. Jun 20, 2024 at 4:15 PM
    Tacoma Mike
    Southern Maine
    I did too. Thought I would have to give it up. Bought an adjustable and saved my ass.
  12. Jun 20, 2024 at 4:28 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Not rambling at all, thank you!!
    I think deck quality (thickness) may be my number one concern, its somewhat sandy here and the sand ate right thru the deck of my first mower, I mow taller now (and my grass is thicker) so I no longer have that problem, but its still a concern.
    My yard has 11 trees, the new acre has almost none, so obstacles are not much of an issue.
    I appreciate your response!!
    :fistbump:
  13. Jun 20, 2024 at 4:41 PM
    PzTank
    Above the Notches
    Funny, I read through a few pages and thought I was here :rofl:
  14. Jun 20, 2024 at 4:49 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    The theme is different, but the good times are the same! :thumbsup:
  15. Jun 20, 2024 at 5:42 PM
    wilcam47
    Will
    Bourbon state
  16. Jun 20, 2024 at 6:22 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :anonymous::anonymous::anonymous:
    :turtleride:
  17. Jun 20, 2024 at 6:58 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Troubles seeing? Get some GOOD work lights. Good means bright, work lights are on stands that can be adjusted to suit the work position.
    If you can't see, you can't weld!
  18. Jun 20, 2024 at 7:01 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I have a TS348XD with 24 hp. Biggest difference is a welded sheet steel deck vs a formed thinner deck. I also have diff lock lol. Great tractor. I use it a lot for pulling a small dump trailer and mowing the higher stuff. I have a slightly bigger tractor for the garden. Seat is comfortable and Kawasaki engine just purrs.
  19. Jun 20, 2024 at 7:24 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I had the same experience.
    The only difference is I'm a special kind of stupid.
    I had no idea where the money was going. I just went to work for 26 years. I never touched a thing. I worked with guys that would push their money into fixed accounts at the hint of a depression. I figured there was more money in there than I contributed, so I did nothing.
    I was asked if I wanted to take a buyout during the down turn.
    I said why?
    I was shown my balance. I had no idea it grew that much. (Thank-you, wife).
    After learning that, I said...see, ya!
  20. Jun 20, 2024 at 7:24 PM
    BussinGus
    Agreed, welding outside in the sun, I could see much better. I should use a light. I have one, but I need to make a solid adjustable base for it, or mount it at my welding table. New project!
