Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
Electrical outlet cover screws MUST be......
  1. Horizontal
    10.3%
  2. Vertical
    44.8%
  3. Not matching, ain't nobody got time for that
    17.2%
  4. Over torqued so the fake plastic cracks, then back off just a tad
    44.8%
Multiple votes are allowed.
  1. Jul 1, 2024 at 4:32 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Morning all just getting caught up on like 3 pages. @koditten I have a 9000 BTU in my garage attached to the house installed cost me $3000 from my electric co-op. Like others said make sure you get it rated for the freezing temperatures.
    I got mine with the hyper heat for extra low temperature. It's been great the filters only get cleaned every 6 months. You could put it in yourself I would guess.
  2. Jul 1, 2024 at 4:34 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Any ideas how to do it yourself termite control? I found a couple boards in the shop that have them and need to knock em out.
  3. Jul 1, 2024 at 4:39 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I used this in my basement:
    https://www.amazon.com/dp/B01HDYAOY..._1_9&amp=&crid=RDQSHX14BH77&sprefix=bora+care
    Makes 2 gallons. I mixed it with hot water in a pump sprayer. It's a sticky mess, but I think it works. Haven't seen any Frass on the floor since then.
    mit88, Cwopinger, RustyGreen and 2 others like this.
  4. Jul 1, 2024 at 4:41 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    mit88, Cwopinger, RustyGreen and 3 others like this.
  5. Jul 1, 2024 at 5:00 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    This is some of the damage. Has not progressed any since spraying
    It will need a new 2x10 sistered as there is some slight sagging, but I need 16' and that's a little difficult to get to the house.
    The spray will leave a reside, as seen here on the wiring.
    Also will mess with your copper pipes, but being in the shop I doubt you have those.
    I'm not worried as I am planning on re-piping the house to up the size of the pipe.
    mit88, Cwopinger, RustyGreen and 5 others like this.
  6. Jul 1, 2024 at 5:02 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    :anonymous: :spending:
    mit88, Cwopinger, RustyGreen and 4 others like this.
  7. Jul 1, 2024 at 5:03 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Gotta keep the world moving! I don't mind. I've even worked Christmas before to repair some equipment since we had the downtime.
    mit88, RustyGreen, PzTank and 3 others like this.
  8. Jul 1, 2024 at 5:08 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Tell me what you all think of this, it makes 30 gallons and says it can be sprayed on wood.
    After finding some termites Saturday I got to looking around in the shop and there are a few places where they are and I kind of want to spray every board in the shop.
    https://www.domyown.com/premise-termiticide-p-315.html
    Active Ingredient Imidacloprid 21.4%
    Target pests Subterranean Termites, Drywood Termites, Dampwood Termites, Carpetner Ants, other Wood-Infesting Insects
    For use in In and around basements, attics, crawl spaces, hallow block foundations or voids, around wells or cisterns, or direct application to damaged wood
    Pet safe Yes, when used as directed
    Yield Approx. 30 Gallons
    Formulation Professional Product
    NOT FOR SALE TO AK, CA, ID, NY, PR
    AZ, CO, CT, MA, MD, ME, NJ, NV, NY, RI (Restricted To licensed Applicators Only)
    Shipping Weight 0.71 lbs
    Manufacturer Envu (Formerly Bayer) (Mfg. Number: 2584607)
    EPA Registration 432-1331
    StayinStock, RustyGreen and PzTank like this.
  9. Jul 1, 2024 at 5:10 AM
    FastEddy59
    Eddie
    Termites :notsure: Cockroach barely survive here.
    BussinGus, RustyGreen, PzTank and 2 others like this.
  10. Jul 1, 2024 at 5:14 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Looks to be more toxic than the Boracare. Looks like minimal uses inside on wood? Price looks good, but I have pets and cannot risk it.
  11. Jul 1, 2024 at 5:16 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Happy Canada Day !!
  12. Jul 1, 2024 at 5:17 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That's the biggest thing, got a cat that stays in the shop at night.
  13. Jul 1, 2024 at 5:19 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hmm, it does say pet safe when used as directed. Would probably need to relocate her till it all dries. I might pick some up for exterior treatment.
  14. Jul 1, 2024 at 5:19 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  15. Jul 1, 2024 at 5:23 AM
    FastEddy59
    Eddie
  16. Jul 1, 2024 at 5:23 AM
    wilcam47
    Will
    Bourbon state
    :rofl::rofl:
  17. Jul 1, 2024 at 5:37 AM
    PzTank
    Above the Notches
    Land Yacht!
    Excellent point!
    @koditten , check your electric company for any offers they might have. We did that for our heat pump water heater , good deal on the package and our bill dropped significantly!
  18. Jul 1, 2024 at 5:43 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    When I get home and open the doors she usually goes outside and lays down. With the heat it won't take long to dry so that makes me feel better about her.
  19. Jul 1, 2024 at 5:46 AM
    wilcam47
    Will
    Bourbon state
    Whoever drives that has kids that dont know they have siblings....
  20. Jul 1, 2024 at 5:53 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    More than likely that's the truth. They can't figure out why they look similar though :rofl:
