Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Sep 1, 2024 at 7:17 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Cant say ive seen a truck version.
  2. Sep 1, 2024 at 7:33 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Damn, you mean cars actually last long enough in Michigan to get suspension work? o_O
  3. Sep 1, 2024 at 8:06 AM
    wilcam47
    Will
    Bourbon state
    You wouldnt know you trade them in too quick....:rofl::rofl::rofl::rofl:;):fistbump:
  4. Sep 1, 2024 at 8:10 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    :anonymous:
  5. Sep 1, 2024 at 8:14 AM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Ole big guns to the rescue!!!!
    Also, I’m impressed with this Pittsburgh breaker bar.
  6. Sep 1, 2024 at 8:32 AM
    wilcam47
    Will
    Bourbon state
    Nice buck on game cam. Decent for my little area.
    BussinGus, mit88, Cwopinger and 10 others like this.
  7. Sep 1, 2024 at 10:15 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So guy came and looked at the boiler today. We fired it up and he did a quick air adjustment and it was good. Thing was actually choking for air and burning funny. Over-fueling a little bit so I'm gonna order a slightly smaller nozzle. So, for the price of a nozzle, I'm set! :D
  8. Sep 1, 2024 at 10:23 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I believe all Challenger lifts are ALI certified. :thumbsup:
    If you are replacing the floor look at the Challenger in ground lifts:
    https://www.challengerlifts.com/car-lift-category/inground-lifts/
    The biggest problem with a lift in a smaller space is when you are not using it the thing is huge. With the in ground units you only have the arms to stumble over, not the columns.
    These modern in ground lifts are way different that the single post units from days gone by. They offer full access just like an above ground lift and all the works are contained in a polymer tub so there is no chance of losing hydraulic oil into the ground.
    Notice both the floor plate lift lift you posted and this in ground unit have 3 stage front & rear arms, a very nice luxury to have. :)
    My lift has the arms configured as below, this would be looking at the drivers side with the vehicle pulled in.
    In addition to being 3 stage both front & rear, the front arm can be positioned closer to straight out from the column when lifting a front drive car or more forward when lifting larger cars or trucks.
  9. Sep 1, 2024 at 10:25 AM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    I know this is off-topic but I think it’s pretty cool.
    The two big industrial burner/flare/thermal oxidizer manufacturers here in Tulsa., They both are metal 3-D printing their combustion nozzles now to get better flow design and burner characteristics out of them.
    It’s just crazy to think that we can 3-D print exotic metals like it’s nothing nowadays, of course yeah you gotta have about $3 million to buy the machine
  10. Sep 1, 2024 at 10:25 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I have 2 of these rated 2 tons each:
  11. Sep 1, 2024 at 10:26 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    All this fancy lift talk and I'm here like...
    :pout:
    BussinGus, Squirt, mit88 and 13 others like this.
  12. Sep 1, 2024 at 10:26 AM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    I was watching a video last night about using the two post lifts and he mentioned that these jacks are mandatory for any home shop using a two post lift
  13. Sep 1, 2024 at 10:27 AM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    I’m still there too lol and after just two hours of work last night on the ground, my body shot now
  14. Sep 1, 2024 at 10:27 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Pretty sure there is no set topic here. Goes from shop to home life in the matter of a post :laugh:
  15. Sep 1, 2024 at 10:29 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I use ramps for the most of it, only thing real high is the truck.
  16. Sep 1, 2024 at 10:56 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Agree.
    My floor is probably at least 60 years old and was plenty thick -- on the other hand... :confused:
    Mohawk is the most expensive lift in the industry, they also have the toughest specifications for concrete.
    The lift sits on a giant block of concrete 14' x 4'
    12" thick
    around 8500 pounds
    keyed under the original slab
    reinforced with rebar
    pinned into the original slab all the way around every 12"
    done by the best masonry contractor in town
    it ain't goin' nowhere. :D
  17. Sep 1, 2024 at 11:00 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :yes:
  18. Sep 1, 2024 at 11:07 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I don't use them all the time - say for a routine oil change, tire rotation & brake inspection for example.
    If it is a job with heavy work like my friends GMC that is currently up there with no bed, exhaust or fuel tank and missing a large chunk of the frame :frusty: then absolutely.
    With a stand under the front & rear of the frame that truck is solid as a bridge up above our heads.
    :benchpress:
  19. Sep 1, 2024 at 11:08 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Great place isn't it. :):)
  20. Sep 1, 2024 at 11:46 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
