Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
How do you rinse when brushing your teeth?
  1. Mouth under spigot
    28.6%
  2. Hand(s)
    38.1%
  3. Cup
    19.0%
  4. I don’t rinse
    14.3%
  1. Sep 9, 2024 at 10:45 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Stand in the back.
  2. Sep 9, 2024 at 10:47 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    BussinGus, RustyGreen, mit88 and 5 others like this.
  3. Sep 9, 2024 at 10:52 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    They're not people, they're just little kids...:hattip:
  4. Sep 9, 2024 at 10:54 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :annoyed::annoyed:i think @six5crèéd has a story...:annoyed:
  5. Sep 9, 2024 at 10:56 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
  6. Sep 9, 2024 at 11:07 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  7. Sep 9, 2024 at 11:39 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I got kicked out of an email I've been using for years for signing up for stuff and got a lot of spam email to it.
    I finally got logged back in to it today, had 3,918 emails and 99.9% of them were spam....I hope, cause I figured if I hadn't seen them in close to 3 years I didn't need to now so I deleted them all.
    RustyGreen, mit88, Cwopinger and 8 others like this.
  8. Sep 9, 2024 at 12:36 PM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Can’t wait to start fabbing bumpers
  9. Sep 9, 2024 at 12:41 PM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    sounds, looks like a deer tick to me...
  10. Sep 9, 2024 at 1:04 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Ok shop crew I have a job! Start at orientation Tuesday morning at 8.
    My new employer is IPEX plastics in Asheville NC formally Silver-Line plastics.
  11. Sep 9, 2024 at 1:30 PM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Oh do they make the grey PVC conduit and fittings? We use IPEX conduit bodies all the time.
  12. Sep 9, 2024 at 1:50 PM
    cory02taco
    Cory
    Maine
    Good afternoon everyone, I’m having a mechanical problem and I’m hoping I can get some ideas, maybe some guidance.
    So I put a clutch in my 2013 6 speed Tacoma a month or so ago. I had the flywheel machined at the local Carquest, I do not know how much was removed, but the flywheel didn’t look that bad but it had been slipping so I knew it needed to be done. I installed a southbend stage 1 clutch which is actually made by exedy.
    After it was all back together I noticed a vibration. It is very noticeable at idle, with the truck in gear or in neutral, clutch pedal depressed or out all the way. It gets worse at 1500rpm, and even worse at 2200. The other issue is the engagement. It’s basically an inch off the floor. I’ve put about 300 miles or so on it since install, and it’s come up a touch, but not at all where I think it should be, in the middle of pedal travel.
    I guess my question is where do I start? I’ve pulled the transmission back apart and have the pressure plate sitting on the bench. Do I need to line up the weight on the pressure plate with the drilled holes on the flywheel? Is the flywheel itself out of wack because of the machining?
    I did use all new bolts on the flywheel, torqued them all to spec in 3 steps. Same with the pressure plate.
    I also noticed the throw out bearing had a longer overall length than the stock one. Does this affect the engagement? I think it would but I’m having a hard time wrapping my head around it.
    Having said all of that, the clutch does grip well, and doesn’t slip at all. I pulled my 3000lb boat last weekend and it had 0 issues, other than those listed here.
    Any insight you guys could provide would be incredible.
    @Tacoma Mike maybe you can tell me how I f-ed it up!
  13. Sep 9, 2024 at 1:55 PM
    Tiedie
    David
    WFOY
    Probably they make PVC pipe and PEX pipe ant this plant but I know they have a facility in Lawton OK too been there for delivery and pickup.
  14. Sep 9, 2024 at 2:07 PM
    wilcam47
    Will
    Bourbon state
    Is there adjustment rod on the clutch? If not id say the throw out bearing length would affect the clutch pedal travel if the fork doesnt sit in same spot. As for the clutch it should be balanced with the flywheel, if its off balance that would give you vibes. Thats just my general knowledge
    RustyGreen, Cwopinger, PzTank and 3 others like this.
  15. Sep 9, 2024 at 2:13 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Sorry to hear
  16. Sep 9, 2024 at 2:25 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Very sorry to hear
  17. Sep 9, 2024 at 3:27 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Wife went to a staff meeting at church so supper was on me, hot dogs and hash browns in the shop it is.
  18. Sep 9, 2024 at 3:28 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Hopefully Mike can point you in the right direction, I’ve never ran into a vibration after having flywheels machined or new clutch installs. :sorry:
  19. Sep 9, 2024 at 3:30 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    The heck, diesel is over $4 a gallon here o_O
  20. Sep 9, 2024 at 3:42 PM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
