Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Nov 4, 2024 at 3:20 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Good morning manly men, another day working on the GMC. :rolleyes:
    Getting closer to the finish line, rocker panels are welded in plus 1-1/2 cab corners -- that is when I ran out of MIG gas Friday.
    With a little luck & determination by the end of the day there will be some paint going on this clunker. :fingerscrossed:
    I hope y'all have a fulfilling day as well.
  2. Nov 4, 2024 at 3:20 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I kinda am the oil man now. :laugh:
    Only work I hired out is when a line for one of the heaters sprung a pin hole leak Christmas day. I was able to get a guy out the next day and repair it. He showed me how to drain, fill, and purge the system. It'll happen again with the way the heat registers are. I can solder copper pipe fine, it was the drain and fill I was clueless on. That was a 2 hour and $500 lesson I'll remember the rest of my life o_O
    Yes, $500. $200 service call (o_O) $100 an hour, and $50 for one 3/4 coupling, elbow, and 1' of pipe o_O
    soundman98, mit88, FastEddy59 and 9 others like this.
  3. Nov 4, 2024 at 3:21 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I sure did!!! Already sent out a couple of bags.
    Thank you!! :fistbump:
    mit88, 308savage, PzTank and 3 others like this.
  4. Nov 4, 2024 at 3:23 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Did you get it back or are you...
    soundman98, mit88, PzTank and 4 others like this.
  5. Nov 4, 2024 at 3:24 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I got 3/4 of a bag of Peat Moss I can send ya to add some nutrients to that mud! :yes:
    FastEddy59, 308savage, PzTank and 5 others like this.
  6. Nov 4, 2024 at 3:26 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    @StayinStock I think we can direct drop ship crushed up river pipe from the factory with free shipping via flatbed.:thumbsup:
    308savage, PzTank, Cwopinger and 4 others like this.
  7. Nov 4, 2024 at 3:27 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :anonymous:
    soundman98, PzTank, Cwopinger and 3 others like this.
  8. Nov 4, 2024 at 3:28 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Free shipping you say??
    soundman98, 308savage, PzTank and 4 others like this.
  9. Nov 4, 2024 at 3:28 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The burner set up is key, you just can't eyeball an oil burner, it needs to be done with gauges to hit the clean and efficient optimum.
    At one point I was considering buying a Bacharach Fyrite kit, instead I just call a burner man with 50+ years using one.
    soundman98, mit88, PzTank and 6 others like this.
  10. Nov 4, 2024 at 3:35 AM
    Tiedie
    David
    WFOY
    This too is all boxed up and ready for the prize whse.
    Waiting on the labels from @StayinStock
    soundman98, mit88, FastEddy59 and 7 others like this.
  11. Nov 4, 2024 at 3:42 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I think at this point I can eyeball it enough to keep it going for a couple more years. I want to eventually update to a propane boiler, so I got some years to save up for :goingcrazy:
  12. Nov 4, 2024 at 3:49 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    That should put smiles on alot of faces!!! :fistbump:
    soundman98, PzTank, Cwopinger and 2 others like this.
  13. Nov 4, 2024 at 3:55 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :facepalm:
  14. Nov 4, 2024 at 3:58 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    :notsure:
    I've never personally seen anybody use those fancy tools on boilers around here. Yes there's the C02 thing to worry about, I know. I've got a monitor right in there and it has never gone off "0".
  15. Nov 4, 2024 at 4:25 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Good morning shop crew, have a great, safe and blessed Monday.
  16. Nov 4, 2024 at 4:46 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The problem is you have never seen a professional set up an oil burner.
    Damn near anybody with a passing understanding of how the burner works can change a nozzle, filter, electrodes & tinker with the air band and make it "work".
    Doing an actual setup or efficiency test with the proper gauges, either an old style Fyrite kit or with modern digital ones is key to hitting that efficiency number and perhaps more important making the burner operate clean.
    With an oil boiler the clean burn is especially important as the more the build up in the passages accumulated the more efficiency is lost and the faster more build up accumulates -- making the boiler fire longer which stresses the heat transfer surfaces (premature wear) and wasting your heating dollars.
    Also cleaning one up that is all sooted up is a miserable, filthy job. :annoyed:
    Here are some of the things tested for a proper tune up:
    First: Remove all access covers brush clean & vac out all passages.
    Inspect combustion chamber liner.
    A proper "soot vac" is used, that crap will pass right through a regular shop vac.
    Flue gas test:
    Carbon Monoxide (CO)
    Carbon Dioxide (CO2)
    Oxygen (02)
    Stack temperature - Too high is obviously dangerous, too low leaves deposits (condensation too) in the chimney and can break down masonry chimney liners over time.
    Smoke test - reduces pollution & checks for correct combustion
    Flue draft reading
    Over fire draft reading
    Inspect/adjust the barometric draft control
    By the book a pump pressure test is also to be performed as it allows the calculation of the actual fuel delivered by the nozzle, although this is not usually done unless there is a problem.
    Using all the above information the tech can now adjust the burner, obviously this is a balancing act between all adjustments and readings to achieve the end goal of a smooth light off, quiet operation and a clean burn.
    So, just how does one eyeball all that? :boink:
    soundman98, cory02taco, mit88 and 9 others like this.
  17. Nov 4, 2024 at 4:51 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Good morning friends! Hope you all had a great weekend and have an awesome Monday :hattip:
  18. Nov 4, 2024 at 4:52 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    It was 12:25 at my house, I was up putting 2 Bostun butts on the smoker :)
  19. Nov 4, 2024 at 5:11 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Information overload :goingcrazy:
  20. Nov 4, 2024 at 5:12 AM
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    Good morning shop crew. I hope it was a good weekend for all of you.
