Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
How do you rinse when brushing your teeth?
  1. Mouth under spigot
    26.1%
  2. Hand(s)
    34.8%
  3. Cup
    17.4%
  4. I don’t rinse
    21.7%
  1. Dec 10, 2024 at 2:53 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    :eek:
  2. Dec 10, 2024 at 2:55 PM
    Tacoma Mike
    Southern Maine
    contagious…lol
  3. Dec 10, 2024 at 2:56 PM
    Tiedie
    David
    WFOY
    Didn't make it into the building on the side where they are making pipe sorry. I did get to work by myself today when I got there Dr appointment. Stacked coils of poly-pipe and taped so loose pieces up for the grinder.
  4. Dec 10, 2024 at 2:57 PM
    Gen1TacoLady
    Gen1TacoLady Local favorite
    Pond Princess
    Washington County, MD
    '95 Red Tacoma
    :eek::eek::eek:
    Can I have some? :fingerscrossed:
  5. Dec 10, 2024 at 2:59 PM
    Tiedie
    David
    WFOY
    Coming tomorrow here, I'll pipe it up to you IMG_20241210_141151276_HDR.jpg.
  6. Dec 10, 2024 at 3:13 PM
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    :yes::yes::yes::fistbump:
  7. Dec 10, 2024 at 4:20 PM
    BussinGus
    BussinGus Well-Known Member
    2019 cement double cab sport
    Literally! :rofl:
  8. Dec 10, 2024 at 6:28 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    :rofl::rofl:
    six5crèéd[OP] and PzTank like this.
  9. Dec 10, 2024 at 7:53 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    do you have pictures?
    i seem to end up fixing most hydraulic and plumbing issues at work very few others seem to be able to figure out...
  10. Dec 10, 2024 at 7:55 PM
    soundman98
    NW Indiana
    a co-worker says he has a major problem with them digging up grubs in his yard....
  11. Dec 10, 2024 at 8:27 PM
    soundman98
    NW Indiana
    being that it's a dual-acting cylinder, it really should be a power up and power down circuit, with an additional float section-- either a chain connection for a physical float, or a electronic/mechanical bypass enable in the hydraulics.
    the bigger trucks i build all have dual acting lift cylinders, where most electric-powered units like western or boss are all currently single-acting (with one hose for lift), with gravity down, though all of those have an electronic float circuit as well as a chain float..
    sorry, i replied before realizing i was still another day behind.
    loosen both lift cylinder hoses at the cylinder(no more than 1 turn!). when you bump up/down, fluid should spray out--that would indicate your hoses, control, and pump are all working correctly, and it would also bleed out your lines. you can also play with swapping the left/right solenoid wire over to the lift section solenoid and then run left/right as up/down if you're not getting the fluid spill. i had one a while back that the controller itself went bad on only one section.
    as far as bleeding, the owners manual is the appropriate process. the physics is that air is lighter and more compressible than hydraulic fluid. by running 'several times' as they say, it compresses and atomizes the air, and then circulates it out of the cylinder and back to the reservoir. my companies policy is to run lift and lower stages fully 10 times to circulate the air out--same as that manuals 'several'. in small systems like that, 10 times is usually enough, though larger brand new and bone-dry cylinders can sometimes take around 20 times to really work all the air out.
    and with no load on the cylinder like that, you can also take off the hoses, and the cylinder should power up/down using air from an air compressor with a basic rubber-tip blow gun.
  12. Dec 10, 2024 at 9:29 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Thank you for the suggestions. Forecast is for freezing rain turning to heavy rains and 1-3 inches of rain through tomorrow with 20-30 mph winds so I will not be looking at the plow tomorrow. Oh yeah, no garage either. I can get better pics as well. Getting home after dark sucks.
  13. Dec 10, 2024 at 11:39 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Well men, it was a good run... Shop nightwatchman again. :pout:
    I was good & tired, went to bed at 10:30 anticipating a fair nights sleep -- and popped awake at 2 AM.
    :annoyed:
  14. Dec 10, 2024 at 11:40 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    On the positive, good morning Wrenchmen :hattip:
    I hope you read this after your alarm goes off. :fingerscrossed:
  15. Dec 11, 2024 at 2:45 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    I did. I hate when I wake up in the middle of the night and can’t sleep.
  16. Dec 11, 2024 at 2:45 AM
    POOLGUY
    JEFF
    ALABAMA
    Good morning shop men and ladies, have a great and blessed day.
  17. Dec 11, 2024 at 3:09 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Good morning all
    Have a great day
  18. Dec 11, 2024 at 3:19 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Early morning satellite sshtuff, just showing why SpaceX is taking over, they've got one spotter in the back and one guy up front steering this rig remotely. Scheduled to launch Friday afternoon and here I am looking at it Wednesday morning....
    :burnrubber::burnrubber:
    mit88, 308savage, RustyGreen and 10 others like this.
  19. Dec 11, 2024 at 3:21 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Mother nature has Alzheimer’s..
    Good morning everyone :hattip:
    Might be time to invest in some galoshes? :anonymous:
  20. Dec 11, 2024 at 3:23 AM
    PzTank
    Above the Notches
    They’re not using a Cybertruck :eek::rofl:
    They have a similar rig out in Boca Chica that ferries the Starship booster from the production site to the pad. Crazy to see the dude with the controller just walking along with it…
