Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Feb 5, 2025 at 8:56 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    They know you are good go to employee, you can handle it! :D
  2. Feb 5, 2025 at 8:57 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Now I feel like a single phase guy livin’ in a 3 phase world. :pout:
    Mornin’ Gent :hattip:
    @ the Dr.‘s office…I’m throw in’ codes. :goingcrazy:
  3. Feb 5, 2025 at 9:03 AM
    mit88
    Planet earth
    All I can do in this case is turn off the switch. :rofl:
  4. Feb 5, 2025 at 9:13 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    :facepalm:
    :rofl:
  5. Feb 5, 2025 at 9:17 AM
    FastEddy59
    Eddie
    Glad it wasn’t me who sparked it. :rofl:
    mit88, StayinStock, NoOne and 4 others like this.
  6. Feb 5, 2025 at 9:31 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    This would be the doctor if I had a check engine light :eek:
  7. Feb 5, 2025 at 9:33 AM
    FastEddy59
    Eddie
    :anonymous: My cold light is permanently on.
    How big is the pile of chips/salvage? :notsure:
  8. Feb 5, 2025 at 9:36 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Chips are light weight today, knee deep in plastic :D
  9. Feb 5, 2025 at 9:38 AM
    FastEddy59
    Eddie
    Place in ‘Berta made lots of teflon rings. I did not now the salvage was valuable. Just piles of it waitin’ to be sent back to TX for reprocessing.
  10. Feb 5, 2025 at 10:28 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    A residential service is generally billed with no restrictions or surcharges - you can use everything whenever you want.
    A commercial service, either single or three phase usually has a "demand" charge.
    This is a multiplier that is usually applied to the whole month.
    You could not run production for 29 days and on the 30th day start something large and it would be applied to the whole month.
    Most here know that electric motors pull more amps when starting up than running, 2 to 3 times the nameplate full load is a reasonable estimate.
    Ex: A one horsepower motor (like a table saw) will use about 15 amps at full load when operating on 120 volts.
    That same motor will demand around 45 amps for a short time when starting up.
    This is where that "surge" rating comes in on generators.
    A 15 amps electric heater on the other hand has no startup spike, it uses 15 amps as soon as you turn it on.
    Transformers are expensive and the utility company wants to be compensated for providing you the ability to operate your equipment.
    To be continued
  11. Feb 5, 2025 at 10:38 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Demand charge part 2
    Now imagine the demand of starting a 50 horsepower air compressor or a 1000 horsepower chiller. :eek:
    The utility has equipment to measure your demand and surcharges you based on your highest peak.
    To get back to the wood shop, if one large machine is already running the demand point is already established, if a second machine is started it pushes that point higher.
    At the way back job I ran an industrial cooling water power house. We were told our demand ran on a quarter hour interval.
    If I started a chiller at 8:01 we paid demand until 8:15 - 14 minutes, if I started at 8:14 the meter reset at 8:15 so only 1 minute demand.
    mit88, StayinStock, PzTank and 3 others like this.
  12. Feb 5, 2025 at 10:42 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Demand part 3
    The garage used to be a body shop decades ago, I was charged demand. :mad:
    After a year or two I called them up and they agreed I wasn't doing commercial work and removed it.
    However, if I go over 700kwh two months in a row they would put it back on.
    That is why I have the big gas power air compressor when needed.
    mit88, StayinStock, NoOne and 5 others like this.
  13. Feb 5, 2025 at 11:54 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    It’s both illuminating and re-volting at the same time…
  14. Feb 5, 2025 at 1:08 PM
    FastEddy59
    Eddie
    :anonymous::lalala:
    Could be far more.
  15. Feb 5, 2025 at 1:15 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Ya'll just aint wired for it. :rolleyes:
  16. Feb 5, 2025 at 1:17 PM
    FastEddy59
    Eddie
    :rimshot:
  17. Feb 5, 2025 at 1:21 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    It definitely wasn't sheared from being loose. The flywheel is gouged from the bolt heads being over tightened. No bolt heads inside the bell housing.
  18. Feb 5, 2025 at 5:56 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Machine list from a dusty memory:
    1000 ton Trane
    700 ton Trane - 3 of them
    582 ton ? Carrier - had a dual compressor, ran one or both
    186 ton ? Carrier - 2 of them, originally they had variable displacement compressors and VF drives the size of refrigerators, either might have been ok but the software of the day couldn't make them work happily together, both "features" were bypassed.
    All 3 Carriers were field test machines -- AKA: the company got a smokin' deal probably... :rolleyes:
    And...
    A wonderful gadget called a Teco-Chill with a V 12 or 16 ? Caterpillar engine running on natural gas driving a 750 ton chiller - serial number 1.
    It would run reliably for weeks and then at the moment you really needed the damn thing the software would hiccup. :mad: - :rocket: - :rant: - :frusty:
    The company & Tocogen got into a :duel: so they walked away from it.
    Slashaar, 1buzzbait, mit88 and 5 others like this.
  19. Feb 5, 2025 at 6:14 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    The D in VFD is drive.
    :anonymous:
  20. Feb 5, 2025 at 6:21 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :oops:
    Edited so I look less dumb... :pout:
