Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Mar 17, 2025 at 6:01 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
  2. Mar 17, 2025 at 6:05 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :eek::eek::annoyed::annoyed:
  3. Mar 17, 2025 at 6:06 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  4. Mar 17, 2025 at 6:08 AM
    wilcam47
    Will
    Bourbon state
    NoOne, RustyGreen, PzTank and 2 others like this.
  5. Mar 17, 2025 at 6:22 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :facepalm:
  6. Mar 17, 2025 at 6:23 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hey, I've been on my best behaviour; I had to let one in :rofl:
  7. Mar 17, 2025 at 6:31 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    who's gone tow with a bumper hitch?
    soundman98, PzTank, mit88 and 4 others like this.
  8. Mar 17, 2025 at 6:34 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    @six5crèéd I got the easy-out out. Bad news is that the mag drill migrated during milling and took out a quarter of my threads, and the rest of the original bolt isn't coming out of the threads either (looks cross-threaded). So I guess I'm just over-boring and heli-coiling. I've never done a heli-coil before and any tips and tricks would be much appreciated.
    I started with a 1/8" Carbide endmill, then stepped up to a 8mm (minimum thread diameter). I setup the drill the 2nd time with a bushing to center it, then removed the bushing so the endmill wouldn't eat it. I guess at some point it walked though.
    soundman98, mit88, RustyGreen and 4 others like this.
  9. Mar 17, 2025 at 6:36 AM
    Slashaar
    Josh
    Kansas City, MO
    You looked into how much data mining car manufacturer's sell off nowadays? Nissan was even found to be recording if you did the deed in the vehicle.
  10. Mar 17, 2025 at 6:37 AM
    Slashaar
    Josh
    Kansas City, MO
    That receiver is rated for about 12 oz now.
  11. Mar 17, 2025 at 6:53 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    We don't use heli-coils, they have special taps and such. We use these threaded inserts, you can get them in a lot of sizes. It tells you what size drill and tap to use for them, the drill size is bigger than normal. Here's McMasters list, scroll down to the metric sizes.
    Click on the part # then on product detail, it tells you everything.
    https://www.mcmaster.com/products/t...3~/black-phosphate-steel-key-locking-inserts/
    soundman98, NoOne, PzTank and 4 others like this.
  12. Mar 17, 2025 at 7:01 AM
    Slashaar
    Josh
    Kansas City, MO
    Unfortunately, Nissan uses an M10x1.0 thread for their 350z flywheel bolts.
    PzTank, RustyGreen, wilcam47 and 2 others like this.
  13. Mar 17, 2025 at 7:07 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Since you have to get a new bolt anyway.........:D
  14. Mar 17, 2025 at 7:09 AM
    wilcam47
    Will
    Bourbon state
  15. Mar 17, 2025 at 7:25 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    :popcorn:
    NoOne, PzTank, mit88 and 3 others like this.
  16. Mar 17, 2025 at 7:36 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Love it.
    A fully over-engineered solution with hours dedicated to a task that'd typically take 10 minutes.
    What really tops it off is the pristine equipment, lawn, clothing, gloves and surgically clean sketchers work boots.
    Nice work fellas.
  17. Mar 17, 2025 at 7:39 AM
    wilcam47
    Will
    Bourbon state
    :rofl: just thumbs up and subscribe
  18. Mar 17, 2025 at 7:39 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    It's a deadly combination, like playing the hand grenade lottery and hoping you don't win.
    soundman98, PzTank, mit88 and 3 others like this.
  19. Mar 17, 2025 at 7:46 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Do tell me more..the friends were staying with the wife drives an Armada, which looking at it either has a recessed hitch covered in plastic or no hitch at all.
    Do you just throw your hands up and go guess I'll just eventually have to get newer vehicles with that data mining prerogative OR just go totally the other way and buy only older vehicles?
    Society will probably look at ya funny but I've never let society determine my next move. Hearing crap like that makes me want to daily an 85 c/k 1500 and go back to flip phones.
    NoOne, PzTank, RustyGreen and 4 others like this.
  20. Mar 17, 2025 at 7:49 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    :anonymous:
