Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Apr 5, 2025 at 6:56 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Mighty flat out there. o_O
    @Fargo Taco
    I hope your birthday cake is tall & you have a good day. :)
  2. Apr 5, 2025 at 8:42 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
  3. Apr 5, 2025 at 8:53 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
  4. Apr 5, 2025 at 9:13 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Thank you, thank you!
  5. Apr 5, 2025 at 9:46 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    six5crèéd[OP], mit88, NoOne and 5 others like this.
  6. Apr 5, 2025 at 10:49 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Happy Birthday, I hope you have a stupendous day!
    :cheers:
  7. Apr 5, 2025 at 12:12 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    I came late to the party, but happy birthday @Fargo Taco I hope you have a great day.
    Couldn’t ask for nicer weather here..think I will go to the gun range. Downside of living in the city is that people frown at you for setting up a 200 yard range down the middle of the street. Hahaha
  8. Apr 5, 2025 at 12:24 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Thank you!
    Thank you! I'd say there's still some cake left but there was never going to be cake. :laugh:
  9. Apr 5, 2025 at 12:26 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Not if they are like minded neighbors
  10. Apr 5, 2025 at 12:38 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    So let's say you find yourself needing a hole saw 1/2" smaller than the one you have...
    :confused:
    Not a problem if you happen to have a table attachment for the band saw.
    Final finish the size with a file.
    Expand the center hole as needed with a Unibit, add a few pop rivets and done.
  11. Apr 5, 2025 at 12:57 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    How is that for slick :cool:
    $7 on Amz.
  12. Apr 5, 2025 at 1:02 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    The Cake Is A Lie!
  13. Apr 5, 2025 at 1:10 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Suggestion time:
    I rebuild these mower decks often. In most cases they need new idler pulleys. The bearings are pretty low quality as well as the bearings only have a thimble of grease in them.
    I can take the riveted pulleys apart easy by drilling out the rivits. Install a new bearing and weld back together. It's kind of labor intensive, but saves me $20-30. The bearings are only $4 each when you buy in bulk.
    I'm experimenting by grinding down the bearing retaining lip and popping out the old bearing. Takes about 4 minutes to do this.
    My question:
    Does anyone have a suggestion on how to rebuild the retaining lip.
    This will save a lot of money and time.
    I'm good with a MIG welder, so something that can be welded to the pulley then easily beat down onto the bearing race to clamp it secure is what I need.
    I hope I've been able to describe what I'm looking for.
    Posting this to a couple different threads to increase number of peeps that can offer ideas .
  14. Apr 5, 2025 at 1:16 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    What about grinding from the two sides leaving a tab on both ends in the middle… bend up, insert bearing and then bend tabs back down?
  15. Apr 5, 2025 at 1:26 PM
    koditten
    Kirk
    Central Michigan
    Can't hurt to try. I'll give it a whirl tomorrow to see how rigid it is.
    Thanks!
  16. Apr 5, 2025 at 2:01 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    I regret to say I never finished that game. :oops:
  17. Apr 5, 2025 at 5:22 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Depending on what you’re using to cut, could possibly do quarters for 4 tabs if needed.
    If you need to remake the retainer, consider using conduit and a steel pipe bullnose (rounded taper) or a swedge (size taper between sizes). Cut off what you need… weld. Ready to make more!
  18. Apr 5, 2025 at 5:32 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Evening shop, been a busy day. Fixed the exhaust leak on the chevelle...
    That gasket was toast.
    And started putting our left over roofing metal up as a ceiling in the garage.
  19. Apr 5, 2025 at 5:35 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I drilled the spot welds and replaced them with bolts & nylocks, probably didn't need all 8.
  20. Apr 5, 2025 at 5:37 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    That metal brightens it right up, good idea!
