Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Apr 5, 2025 at 5:39 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    how critical is the ballance need to be?
    maybe a retaining ring plate that bolts through?
    edit. I like Rusty's method
  2. Apr 5, 2025 at 5:56 PM
    MGMDesertTaco
  3. Apr 5, 2025 at 6:00 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've done that several times...and it works perfectly.
    Unfortunately, it takes 35-40 minutes to drill all those rivets.
    I'm looking for a way to speed things up.
    Gotta make the doll hairs...
  4. Apr 5, 2025 at 6:52 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Just realized I missed yours. :facepalm:
    Thank you!
    Thank you!
  5. Apr 5, 2025 at 7:55 PM
    Gen1TacoLady
    Gen1TacoLady Local favorite
    Pond Princess
    Washington County, MD
    '95 Red Tacoma
  6. Apr 5, 2025 at 7:57 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Thank you!
  7. Apr 5, 2025 at 8:04 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    if you can find a washer with the same ID as the OD of the bearing, it would be possible to weld that to the pulley, and then use a punch right near the washer ID edge to re-secure the bearing to it.
    alternatively, and best-case, if you have a hydraulic shop press, i would just press the bearings out(the second picture shows the factory die pinches to retain the bearing on the press-in side), then press the new bearings in and possibly re-crimp them with some carefully-placed chisel blows.
  8. Apr 5, 2025 at 8:12 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Steel ring and weld it on?
    https://customironworks.com/accessories-c-174/rings-steel-c-174_37/40901-p-442.html
  9. Apr 5, 2025 at 8:19 PM
    soundman98
    NW Indiana
    i feel like that would be too fat, and the rounded nature of that ring might offer too much movement. almost needs a ring made out of keystock.
    something more like this, but it still might be too fat and sit proud of the bearing surface.
    https://customironworks.com/accessories-c-174/rings-steel-c-174_37/s40902-516-p-1780.html
    but the biggest issue is that supplier sells by OD, and the ID is the critical dimension in this situation-- and being that they only measure based on OD, i'm suspicious that ID would likely have some variance to it, which could spell lots of extra work.
  10. Apr 6, 2025 at 12:46 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    A little late but.....
  11. Apr 6, 2025 at 12:52 AM
    mit88
    Planet earth
    Thank for sharing the alternative :101010:
  12. Apr 6, 2025 at 3:29 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Good morning everyone, I hope you have a pleasant Sunday :hattip:
    Finally did our taxes, hopefully there’s someone still there so I can get my $3.50 back :rofl:
  13. Apr 6, 2025 at 3:41 AM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    @Fargo Taco happy yesterday birthday
    Morning all have a great day
  14. Apr 6, 2025 at 5:24 AM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Thank you, thank you!
  15. Apr 6, 2025 at 7:55 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
  16. Apr 6, 2025 at 8:27 AM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Thank you!
  17. Apr 6, 2025 at 9:48 AM
    soundman98
    NW Indiana
    being single, i only get about $0.76 back. every year i debate doing taxes every other year just to make it worth my time.
  18. Apr 6, 2025 at 9:49 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hmm, that's odd. I file single (obviously) and always seem to get a decent chunk back. o_O
  19. Apr 6, 2025 at 9:53 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Happy Sunday all! Couple projects today. Putting some urethane on some lumber for the porch
    and trying my hand at smoking a brisket
    fingers crossed it won’t be terrible!
  20. Apr 6, 2025 at 9:54 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    wont be if yer cookin lo-n-slo
