Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
How do you rinse when brushing your teeth?
  1. Mouth under spigot
    26.1%
  2. Hand(s)
    34.8%
  3. Cup
    17.4%
  4. I don’t rinse
    21.7%
  1. Apr 26, 2025 at 10:37 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    That looks sturdy, but heavy. How thick is the plate on that thing, looks to heavy for most SxS?
  2. Apr 26, 2025 at 10:38 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    Tool companies sure know how to trigger their targeted consumers’ want. And I amid that guilt!
  3. Apr 26, 2025 at 10:42 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Installed a air dryer on my air compressor last night.
    :fingerscrossed: no leaks :fingerscrossed::pray:
    I also introduced a new member to my air ratchet family. Extended reach 1/4" driver. It should come in handy for a few projects I've got lined on the SD.
    Also :fingerscrossed: no leaks hear either :fingerscrossed: :pray:
  4. Apr 26, 2025 at 10:47 AM
    mit88
    Planet earth
    Then take the stand home :anonymous::rofl::fistbump:
  5. Apr 26, 2025 at 11:06 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
  6. Apr 26, 2025 at 1:34 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Windy and drizzling outside, so of course I went and tore down the floppy section of fence and set some 3" drill stem as the new posts.. I'll put the fence back up tomorrow after concrete is set up. Using exhaust clamps and angle iron for the brackets20250426_124255.jpg
  7. Apr 26, 2025 at 5:18 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    got my scrap taken in this morning, was tired of looking at it. made a spectacular $45!
    then burned the rest of the morning taking care of some bank stuff, which always takes too long with stuffy people behind desks.
    the bank trip time-suck left me in a daze/funk that sucked the motivation out of the rest of the day.
    so i cracked out the riding mowers and started digging into them to at least figure out the model numbers and parts i need..
    riding mowers are a whole other breed of 'safety' to me!
    it's funny, the first dozen links/video's that pop up when i try to figure out the location of all the safety switches, are all about the location and how to bypass them...
    the Sears started almost right away, fortunately it was put into indeterminate storage without fuel, but is missing an air filter, and a way for the crank case vent to get to the intake. but once i had it running quite a while, and ran a little seafoam through, i shut it off and now it doesn't start at all. no crank, no click of any sort. i suspect something safety switch related somewhere, or the key switch took a dump. i'm still planning on a new carb, spark plug, and oil change for it to make the best of everything. the choke doesn't work right, i think i'm missing a linkage, will likely add a separate choke control. it's the roughest of the bunch, but with it lacking a mower deck, the one i want for myself the most...
    the troy-built only runs on starting fluid. the gas smelled old, and i tried dumping some new gas in to dilute the old stuff. even ran it for a while on starting fluid to try to get it to suck some new gas/detergents through the system with no luck. now the fuel leaks out through the carb, but won't run(i just learned all these carbs have an electronic shutoff through the bottom bolt, which is clearly not working here). another carb/plug/oil change.
    and the ariens never even tried starting. the plug is majorly fouled, and my spark tester showed it has a weak spark. yet another carb/plug/oil change, likely a coil pack as well.
    and the most expensive part, all 3 need new tires, with the troy-built and ariens having swapped a front wheel on incompatible axle shafts, so need to dig into fixing the bearing surfaces on those as well.
  8. Apr 26, 2025 at 5:36 PM
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    You would need big trailer
    Will see if we can make a arrangement when the honey is back
  9. Apr 26, 2025 at 5:43 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    needs a Coyote engine in it.
    you gonna have tons zucchini
  10. Apr 27, 2025 at 3:16 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Good morning everyone, I hope you have a pleasant Sunday :hattip:
  11. Apr 27, 2025 at 3:25 AM
    Jtcmedic
    Jeff
    Florida
    2014 prerunner sr5
    Morning all have a great day
  12. Apr 27, 2025 at 3:28 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Morning all :pccoffee:
    Mother wants a ceiling fan in her room, so I picked up everything I needed at Lowe's after work yesterday since it's only a couple miles up the road. There never was a fixture up there, right now the switch just controls an outlet, so a trip into the attic for me. However, yesterday evening I went down into the basement to grab a wobble-pop out of the fridge and noticed water all over the floor. Oh now what!? Water heater pressure relief valve decided to leave the chat and is dripping pretty bad. So I have to make ANOTHER trip back to the store, I think the Home Depot is closer. Put a bucket under there temporarily. I was planning on painting some trim this weekend, even bought the $95/gallon paint last week, but people and stuff keep changing my plans! :annoyed:
  13. Apr 27, 2025 at 3:43 AM
    Tacoma Mike
    Southern Maine
    $95 ???
  14. Apr 27, 2025 at 3:47 AM
    Tacoma Mike
    Southern Maine
    Morning
    M.DOG is done..
    Now to start the other set to fulfill my barter..
  15. Apr 27, 2025 at 3:48 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  16. Apr 27, 2025 at 3:53 AM
    Tacoma Mike
    Southern Maine
  17. Apr 27, 2025 at 3:57 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I worked at a building supply that sold Benjamin Moore and was around for the rollout of that product. I think we sold it for $55 a gallon back in 2013.
    It's not a "true" trim paint, but the stuff I have been using while it looks good, takes overnight for each coat to dry and takes 3 coats to cover the old wood trim even with a good primer. I want to be done in a couple days and not worry about it. I'll gladly pay the premium for that.
  18. Apr 27, 2025 at 5:15 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Gm recalling 877k+ 6.2 liter V8's made from 21-24 in Silverados, Sierras, Tahoe, Yukon, Escalade etc...not a good sign for them.
    six5crèéd[OP], mit88, NoOne and 4 others like this.
  19. Apr 27, 2025 at 5:17 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Honestly pretty much every manufacture is having some pretty serious issues right now. Even Toyota is dropping the ball pretty hard.
  20. Apr 27, 2025 at 5:42 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
