Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
How do you rinse when brushing your teeth?
  1. Mouth under spigot
    28.0%
  2. Hand(s)
    32.0%
  3. Cup
    16.0%
  4. I don’t rinse
    24.0%
  1. Apr 27, 2025 at 4:21 PM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Fescue is what the road crews toss in with hay after they finish a road project...water it in once and it might grow on asphalt...should get nice results.
  2. Apr 27, 2025 at 6:44 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I'll have to see if my store has some of that.
  3. Apr 27, 2025 at 6:58 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
  4. Apr 27, 2025 at 7:02 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    I have several… quick release to replace.
  5. Apr 27, 2025 at 7:06 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    But straight or 90° ??
    PzTank, 1buzzbait, mit88 and 3 others like this.
  6. Apr 27, 2025 at 7:10 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The muffler clamps are a good idea - fast, easy & cheap! :thumbsup:
  7. Apr 27, 2025 at 7:17 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    BOTH! Why not Zoidberg?
    If I HAD to pick one over the other… straight.
  8. Apr 27, 2025 at 7:31 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I only have the one air gauge right now, so it's one or the other and at $40 just for the chuck I'm not buy another one just to sit in a drawer.
  9. Apr 27, 2025 at 7:36 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    I have a flexzilla whip after the gauge with a quick release. I have several different air chucks… long double sided, short latch, 90, straight, etc.
  10. Apr 27, 2025 at 7:38 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Hmmm, I hadn't really thought about putting a qd on the end of the gauge hose.
  11. Apr 27, 2025 at 7:47 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    You can even put it where you chose hose or not. There are plenty of connector designs and barrel types.
  12. Apr 27, 2025 at 7:53 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    In 1972 the manufacturers started using the "net" (as installed) numbers versus the "gross" (Dyno) numbers used prior.
    The numbers I gave were for the 390 engines used in passenger cars and mild factory hot rods.
    The FE family also had 427 & 428 cubic inch models with the 428 being installed in large cars and "gentleman's performance" cars like the Galaxie 7 liter which was marked as "the quickest quiet car or the quietest quick car".
    And then there was the 427.
    These were really race engines that were available to the public producing 400 to over 500 HP in various versions. In the 60's all the domestic manufacturers were building factory race cars available to the public.
    The 1964 song "The Little Old Lady from Pasadena" contains the line:
    "But parked in a rickety old garage
    There's a brand new shiny red super stock Dodge"
    That was a real thing, you could go down to the dealer and order a race car, put plates on it and drive away, what a time.
    :burnrubber:
    In 1970 Congress passes the first major Clean Air Act, requiring a 90 percent reduction in emissions from new automobiles by 1975. President Nixon establishes EPA, and the new agency is given broad responsibility for regulating motor vehicle pollution. New cars must meet EPA emission standards for hydrocarbons (HC), carbon monoxide (CO), nitrogen oxide (NOx).
    As usual the regulators used the logic of "if it is easy to say it must be easy to do" - things don't work that way in maufacturing... :ballchain:
    Auto manufacturers really didn't have much tech beyond relays & ported vaccum switches to work with.
    At the same time, tougher crash standards like 5 mile per hour bumpers and door impact beams were mandated so the manufacturers were really busy as a one legged man in an @$$ kicking contest trying to comply. :goingcrazy::goingcrazy::goingcrazy:
    Lowering compression and retarding ignition timing "helped" meet the new regulations at the cost of severely reducing performance and dramatically increasing fuel consumption, remember the new "safer" cars were heavier too. :facepalm:
    soundman98, PzTank, 1buzzbait and 7 others like this.
  13. Apr 27, 2025 at 7:59 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :rofl:
  14. Apr 27, 2025 at 8:07 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    When I worked time was more important than money ( :eek: ) so I often bought hardware I knew I had (somewhere :rolleyes: ) just to get the job done.
    Now I have spent some time organizing and consolidating so I "go shopping" in the archives before I start a job, often I have all the hardware already in stock.
  15. Apr 27, 2025 at 8:10 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    This afternoon/evening was service day for Mrs Greens car.
    Oil change, fluids checked, tire rotation, brake inspection.
    It shouldn't come as a surprise to y'all that Mrs Green is a few years past being a teenager, you wouldn't think it looking at the inside of her car however. :rolleyes:
    soundman98, PzTank, Hunterdc1 and 6 others like this.
  16. Apr 27, 2025 at 8:27 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    When I plan a pool job, I generally buy everything I need for that job even though I know I have half the parts in my truck. That way I have parts for the unexpected job.
    soundman98, PzTank, 1buzzbait and 4 others like this.
  17. Apr 27, 2025 at 8:29 PM
    POOLGUY
    JEFF
    ALABAMA
    Mine stuffs the door pockets with used paper notes.
  18. Apr 28, 2025 at 1:11 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Funny, I hadn’t heard of these before and was just contemplating the same choice.
    I’m trying to think of when my straight chuck didn’t work and can’t think of any, so I’m going to go with the straight chuck. What do you recall?
    If you can wait a few days, I should be getting my order from them sometime this week, if they send a return customer discount code, I’ll post it here.
    In the meantime, good morning everyone, that weekend sure did pass quickly :hattip:
  19. Apr 28, 2025 at 3:13 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Morning all :pccoffee:
    Hope everyone has a good week :thumbsup:
    I guess I need to trim some shrubs and mow the lawn again. Despite the little rain it's growing rapidly o_O
  20. Apr 28, 2025 at 3:25 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    Didn’t you expect to get help from the pond lady? :D
